Home » Language IDEs » PHP Development Tools (PDT) » Eclipse crashing with PHP files
Eclipse crashing with PHP files [message #547605] Mon, 19 July 2010 03:02 Go to next message
I have Eclipse IDe for PHP developers installed (32 bit using 32 bit java).
Eclipse platform 3.6.0
EPP PHP Feature 1.3.0
I have a Drupal site that I am working on. Every time i open a php file, Eclipse crashes.
I've also installed Pydev for some python work, and that is working just perfectly.
Anyone else seen this?
Perhaps there is some compatibility issue with having php and python files open at the same time....?
Re: Eclipse crashing with PHP files [message #549439 is a reply to message #547605] Mon, 26 July 2010 11:55 Go to previous messageGo to next message
same problem here.
eclipse 3.6 with pdt, win7, and working on a drupal project.
but i also have no solution so far...
Re: Eclipse crashing with PHP files [message #550201 is a reply to message #549439] Thu, 29 July 2010 10:10 Go to previous message
as you were also using drupal, i thought that the problem might be drupal-related. so i removed the file association with *.module files and now it seems to be working again...
best,
walter
Previous Topic:Late Static Bindings
Next Topic:How to display parameter when you key in function
Current Time: Fri Jul 25 16:49:39 EDT 2025
Powered by FUDForum. Page generated in 0.06192 seconds
