Code Completion doesn't find many PHP functions 2.1 does [message #547405] |
Fri, 16 July 2010 12:02  |
After submitting a bug related to Ubuntu 10.04 and Eclipse colors (tooltips are invisibile because black on black with the default ubuntu theme)
they asked me to see if 2.2 solve the problem.
Really it solve 1/2 problem, but with the 2.2 all-in-one I lose some functions in code completion., e.g. checkdnsrr(), dns_get_record() , getmxrr()...
So, I go back on 2.1 (I only renamed the dir) and following the declaration (CTRL+click on checkdnsrr) I see where it is defined:
/opt/eclipse/plugins/org.eclipse.php.core_2.1.1.v20090921-11 00/Resources/language/php5/standard.php
the same file where you can find sleep(), bin2hex(), strtoupper(), strpos() and many other common functions.
With the 2.2, the same file is inside org.eclipse.php.core_2.2.0.v20100616-1900.jar
and I suppose PDT don't enter the jar archive.
But why strtolowe(), sleep(), etc., have code completion while checkdnsrr() and others, haven't?
So I follow definition with 2.2 with CTRL+click on strtolower() and it goes on completely other path:
workspace/.metadata/.plugins/org.eclipse.php.core/__language __/1b4486b - standard.php
So finally I discovered that changing project PHP version from "5.1/5/2" to 5.3, make CA able to find checkdnsrr()
But checkdnsrr() is also present on PHP4
http://de.php.net/manual/en/function.checkdnsrr.php
so it must be a bug, isn't it?
FUDForum. Page generated in 0.04511 seconds
