Home » Archived » Buckminster » NoSuchMethodError with current 3.6 build
NoSuchMethodError with current 3.6 build [message #507677] Thu, 14 January 2010 01:04 Go to next message
With the current 3.6 build from the update site, I get
~/buckminster$ buckminster/buckminster resolve my.mspec
ERROR [0001] : java.lang.NoSuchMethodError: org.eclipse.buckminster.core.resolver.NodeQuery.getRevision( )J
INFO: TAG-ID 0001 = Query for foo.bar:buckminster
Also, there seems to be no feature for the JUnit plugin. It's included in the Emma feature, but a separate JUnit feature would probably be nice.
Carsten
Re: NoSuchMethodError with current 3.6 build [message #507741 is a reply to message #507677] Thu, 14 January 2010 08:58 Go to previous messageGo to next message
I assume you're using Subclipse or Subversive? If that's the case, the problem is caused by a
version mismatch between our update sites at eclipse.org and cloudsmith. I'll fix that later today.
Thomas Hallgren
Carsten Reckord wrote:
> Regards,
> Carsten
Re: NoSuchMethodError with current 3.6 build [message #507742 is a reply to message #507741] Thu, 14 January 2010 09:04 Go to previous messageGo to next message
Yes, I'm using Subversive. I'll try again tomorrow or on the weekend then, thanks :)
> Regards,
> Thomas Hallgren
Re: NoSuchMethodError with current 3.6 build [message #544726 is a reply to message #507677] Mon, 05 July 2010 07:37 Go to previous messageGo to next message
I just created a p2 repo consisting of the buckminster helios headless product + subversive connectors using the b3 aggregator.
Then, I installed the product using the p2 director.
When running buckminster (using hudson+buckminster plugin), I still get that error...
Re: NoSuchMethodError with current 3.6 build [message #544770 is a reply to message #544726] Mon, 05 July 2010 09:15 Go to previous messageGo to next message
Hi Erdal,
What repositories are you using? The correct URL's are:
http://download.eclipse.org/tools/buckminster/headless-3.6
http://download.cloudsmith.com/buckminster/external-3.6
- thomas
> that error...
Re: NoSuchMethodError with current 3.6 build [message #544871 is a reply to message #507677] Mon, 05 July 2010 14:48 Go to previous messageGo to next message
Hi Thomas,
I have pointed the aggregator to
and
(as described on the downloads page of buckminster).
So, I might have taken the wrong url for the svn connectors...
I will try the your suggestion and report back...
Re: NoSuchMethodError with current 3.6 build [message #544946 is a reply to message #507677] Tue, 06 July 2010 03:48 Go to previous message
OK!
The update sites you provided seem to work.
Maybe, the update site provided on the buckminster download page is not in sync with the helios release...
Previous Topic:Product and Features in same project..?
Next Topic:Include optional dependencies
Current Time: Tue Jun 17 07:11:13 EDT 2025
Powered by FUDForum. Page generated in 1.41162 seconds
