Format of target.os, target.ws, target.arch if not * [message #544385] |
Fri, 02 July 2010 10:05  |
I would like my p2 site to be generated with 3 of the
platform/window/architecture combinations, not all, to reduce the size.
These values seem to be "all" (*) or 1 (win32 .. etc)
Is there some format that will allow the selection of 3? In the PDE
build you could do this using the format:
configs=win32,win32,x86 & linux,motif,x86
Thanks in advance!
Here is the ant file snippet we are using for this step:
<buckminster command="perform">
<args>
<arg value="-Dbuckminster.output.root=${REMOVED}/${package.dir}/p2 "/>
<arg
value="-Dbuckminster.temp.root=${REMOVED}/${package.dir}/buildtmp "/>
<arg value="-Dsite.pack200=false"/>
<arg value="-Dcbi.include.source=false"/>
<arg value="-Dtarget.os=*"/>
<arg value="-Dtarget.ws=*"/>
<arg value="-Dtarget.arch=*"/>
<arg value="-Dqualifier.replacement.*=generator:buildTimestamp"/ >
<arg
value=" -Dgenerator.buildTimestamp.format='${build.qualifier.correct ed}' "/>
<arg value="REMOVED.site#site.p2"/>
</args>
</buckminster>
Re: Format of target.os, target.ws, target.arch if not * [message #544437 is a reply to message #544385] |
Fri, 02 July 2010 12:11  |
Hi Scott,
There is currently no format to allow several combinations. It's likely that this will be added as part of the fix for
https://bugs.eclipse.org/bugs/show_bug.cgi?id=286637
Thomas Hallgren
> Thanks in advance!
> <args>
> <arg value="-Dbuckminster.temp.root=${REMOVED}/${package.dir}/buildtmp "/>
> <arg
> </args>
> </buckminster>
FUDForum. Page generated in 0.25673 seconds
