Home » Archived » Buckminster » Migrating source builds from PDE, product issue
Migrating source builds from PDE, product issue [message #543844] Wed, 30 June 2010 14:02 Go to next message
Hi guys,
Here's my basic situation. I'm aiming to migrate from my PDE based athena build to one that's all bucky. But my motivating task is to get a product based build using Bucky. My PDE based update site build (finally) works, and I have working product builds as well -- however, those products don't include the source that I've defined ad that shows up in my update site. My current issue is how to get my source feature builds working under buckminster. I've found one bug on it but frankly having a hard time figuring out what steps I need to take to get it to work.
https://bugs.eclipse.org/bugs/show_bug.cgi?id=244850
What is the best practice here? Is there anyway to simply use my current approach which has the sourcetemplateFeature, generate.feature@foo.bar.source=foo.bar, etc.. ? I'm kind of loath throw out something that is working now..
Second, I seem to have run into another edge case. In this case I get an error that doesn't make sense to me, and buckminster can't find the bundle.
Problem during meta-data refresh: CSpec org.eclipse.amp.doc, attribute bin.includes_0 already defines the path plugin.xml
No component named org.eclipse.amp.doc:osgi.bundle$0.8.0.qualifier is known to Buckminster
Here, I have multiple products defined that refer to features.
One thought that I had was to do some kind of end run around the whole issue of building the update site. Since I have a working Update site, would it make and sense to just use my .product and point Buckminster to an update site(s) that already exists?
cheers,
Miles
Re: Migrating source builds from PDE, product i ssue [message #543885 is a reply to message #543844] Wed, 30 June 2010 18:31 Go to previous messageGo to next message
Your problem sounds like there may be issues with the
bundle/feature/product meta data. Any warning markers?
- henrik
Miles Parker <milesparker@gmail.com> wrote:
> Hi guys,
> get it to work.
> mailto:generate.feature@foo.bar.source=foo.bar, etc.. ? I'm kind of
> bundle.
> cheers,
> Miles
- henrik
Re: Migrating source builds from PDE, product i ssue [message #543887 is a reply to message #543885] Wed, 30 June 2010 19:16 Go to previous messageGo to next message
Henrik Lindberg wrote on Wed, 30 June 2010 18:31
Nope, not with that. I mean I have the usual externalization warnings and what not but I've pretty carefully dealt with any packaging issues. As I say, a full headless PDE (hudson) based releng build works, so if there were issues they would most likely (hah!) have come up.
One gigantic caveat.. and you might already be aware of this -- but if you define a source feature as recommended for PDE builds, there are always errors in the feature.xml. This is because you need to have includes for the source features but they don't actually exist in the workspace environment -- they're only generated at runtime. I never have liked that approach but as I say AFAICT that's the only way to do it "correctly".
Re: Migrating source builds from PDE, product i ssue [message #543890 is a reply to message #543887] Wed, 30 June 2010 19:37 Go to previous messageGo to next message
I was asking because I have seen a couple of issues lately where the
cause was having empty, and in another one, incorrect meta data.
One recent issue was also about using "non standard names for source
features" - "Some of the source features in the the projects use
non-standard names (defined in the respective build.properties files).
Buckminster ignores these definitions and thus generates source features
with standard names. The problem is that the non-standard feature names
are referenced from other features and they are naturally not found."
Also check this: "The MANIFEST.MF file in the bundle is missing the
standard "Manifest-Version" header, which confuses Buckminster to a
point that it is not able to build the bundle correctly. " and, I have
also seen that without correct manifest declaration there are fewer/no
warnings errors for meta data problems - but some tools (like PDE)
builds it anyway.
- henrik
> "correctly".
Re: Migrating source builds from PDE, product issue [message #543941 is a reply to message #543844] Thu, 01 July 2010 03:14 Go to previous messageGo to next message
Hi Miles,
The source/bundle source generation is turned on by default so the
features and bundles should be generated without much additional work.
There are some things to remember.
Ensure that the src.includes in the build.properties of your bundles and
features contains something. Have it appoint files like the about.html
or license.html. Do not include the feature.properties or
plugin.properties since they will be generated (and contain slightly
different settings).
The source features should be published to the site automatically but
there are two things that you might want to consider:
1. Adding the source features to a category. If you don't, they will not
show up in the install wizards unless you uncheck the "Group items by
category". You can use our site definition feature [1] (the one we
perform site.p2 action on) as an example on how to do this. The magic is
in the category.xml:
2. You might want to create an SDK feature, i.e. a feature that installs
both the bundles and their generated sources. You do that by listing the
source features as 'included features' of the SDK feature. This will
generate some warnings from the PDE compiler since it doesn't know that
the features exists but those warnings can be ignored. You can even
create an SDK feature that includes the generated source of itself.
Kind Regards,
Thomas Hallgren
[1]
http://dev.eclipse.org/svnroot/tools/org.eclipse.buckminster /trunk/org.eclipse.buckminster.site.eclipse/
On 06/30/2010 08:02 PM, Miles Parker wrote:
> Hi guys,
> work.
> cheers,
> Miles
Re: Migrating source builds from PDE, product issue [message #544162 is a reply to message #543941] Thu, 01 July 2010 16:48 Go to previous messageGo to next message
Thomas Hallgren wrote on Thu, 01 July 2010 03:14
OK..that makes sense. I just realized that I was doing my manual PDE product builds with that turned off because I was having similar issues so I'm not sure if that's even a Buckminster issue. As I said, it works perfectly for Update Site builds but I guess its too much to expect for product builds to work the same way.. ;( (Again, not a buckminster issue.)
That's funny (not as in haha) because I recently got rid of all of my includes of src because apparently that's best practice. So basically I have to add something back in as an artificial kick. Wow.
The source features should be published to the site automatically. You can use our site definition feature [1] (the one we
perform site.p2 action on) as an example on how to do this...
Yep, I've done all of that. I have a custom Cataegory.xml that handles that.
I wonder if the src includes weirdness is the issue. I'll try that, thanks. Smile
Re: Migrating source builds from PDE, product i ssue [message #544163 is a reply to message #543890] Thu, 01 July 2010 16:51 Go to previous messageGo to next message
Henrik Lindberg wrote on Wed, 30 June 2010 19:37
Right, always worth double checking. I went back through again and looked for any oddities. A few things to clean up a bit but everything seems correct.
All of my source features are generated so that should n't be an issue...?
[Updated on: Thu, 01 July 2010 16:53] by Moderator
Re: Migrating source builds from PDE, product issue [message #544167 is a reply to message #543844] Thu, 01 July 2010 17:25 Go to previous messageGo to next message
Oh, and what about this one..
Ideas?
Re: Migrating source builds from PDE, product issue [message #544170 is a reply to message #543844] Thu, 01 July 2010 17:38 Go to previous messageGo to next message
OK, coincidence..? The one source project that is showing up in my (non-buckminster) builds? The one that I couldn't take:
src.includes = src/
out of because it was a third party inclusion that I couldn't modify it.
All because I actually followed the PDE warning of:
"Source folders should not be added to the src.includes list because they are included by default in source builds."
Now it looks like I have to go back and modify all of those files again.
Grrrr...
Re: Migrating source builds from PDE, product issue [message #544172 is a reply to message #543844] Thu, 01 July 2010 17:47 Go to previous messageGo to next message
I think I forgot the actual error I'm getting. When I try to do the export I get:
/Developer/eclipse/configuration/org.eclipse.osgi/bundles/81 9/1/.cp/org/eclipse/buckminster/pde/antscripts/build.xml:208 : org.eclipse.core.runtime.CoreException: Unable to extract feature.xml or a valid OSGi bundle manifest from /Volumes/Resources/Developer/builds/tmp/amp/org.eclipse.amp. amf.acore.editor_0.8.0-osgi.bundle/source.jar/${bundle.id}_$ {bundle.version}.jar
Which doesn't make any sense, since ..acore.editor is a plugin, not a feature. I've done a search across .xml .properties and*.MF and it isn't being referred to anywhere that it should be.
Re: Migrating source builds from PDE, product issue [message #544176 is a reply to message #543844] Thu, 01 July 2010 18:02 Go to previous messageGo to next message
OK this is weird.. I looked at the actual bundle (I have to admit that I'm still having a hard time mapping "OSGi bundle" to "plugin" when reading these messages) and it contains jar and src.jars like:
${bundle.id}_${bundle.version}.jar
the other one's are as expected i.e. myplugin_x.x.0.quailifier.jar.
So that's a lead anyway.. but I can't see anything unusual about the plugin in question itself. I'll have to take a closer look at the feature dependencies.
Re: Migrating source builds from PDE, product issue [message #544179 is a reply to message #543844] Thu, 01 July 2010 18:14 Go to previous messageGo to next message
OK, the o.e.amp.doc error has gone away..not sure exactly why but I won't worry about it..now I just get a lot of
"E No component named org.eclipse.datatools.enablement.ibm.feature:eclipse.feature /[1.0.0,raw:MpM)(!(eclipse.p2.optional=false)) is known to Buckminster.."
But I take it I don't need to worry about those.
On the actual P2 site build issue, I noticed one other data point..the bundle in question is showing up in the log twice..
[start org.eclipse.amp.amf.acore.editor:osgi.bundle$0.8.0.qualifier #eclipse.build]
[end org.eclipse.amp.amf.acore.editor:osgi.bundle$0.8.0.qualifier #eclipse.build]
[start org.eclipse.amp.amf.acore.editor:osgi.bundle$0.8.0.qualifier #bundle.jar]
[end org.eclipse.amp.amf.acore.editor:osgi.bundle$0.8.0.qualifier #bundle.jar]
All other bundles are showing up just once. What's the significance of this "bundle.jar" and why might it be happening?
[Updated on: Thu, 01 July 2010 18:15] by Moderator
Re: Migrating source builds from PDE, product issue [message #544185 is a reply to message #544179] Thu, 01 July 2010 18:39 Go to previous messageGo to next message
That looks like an optional dependency with range 1.0.0 to infinity on a
bundle that is not found.
> #eclipse.build]
> #eclipse.build]
> #bundle.jar]
> #bundle.jar]
Maybe there are two bundles with the same name and version?
- henrik
Re: Migrating source builds from PDE, product issue [message #544190 is a reply to message #544185] Thu, 01 July 2010 19:04 Go to previous messageGo to next message
Henrik Lindberg wrote on Thu, 01 July 2010 18:39
Yeah, its a BIRT thing..there are like a few hundred of these things that are included as optional dependencies so if you have a BIRT dependency you get them as well...I don't think its a concern.
No definitely not. This is one of my project's plugins and it only appear in my workspace. And I don't understand why it is having a bundle.jar created for it but the rest are all eclipse.build. I've searched through all my build files to make sure that there isn't some kind of stray reference somewhere.
Re: Migrating source builds from PDE, product issue [message #544197 is a reply to message #544190] Thu, 01 July 2010 19:53 Go to previous messageGo to next message
Maybe it is installed in the IDE or TP at the same time as being
available as source in the workspace?
(Trying to find a reason why it is reported more than once... how is
this bundle different from other bundles that are also yours)
- henrik
Re: Migrating source builds from PDE, product i ssue [message #544200 is a reply to message #543890] Thu, 01 July 2010 20:27 Go to previous messageGo to next message
builds it anyway.
I'll be damned. I have over 100 separate MANIFEST.MFs so I didn't manually inspect them all. (You shouldn't have to, that's what the IDE is for, right? Wink) I just looked for trouble spots but somehow I missed this one. When I did an exhaustive compare with a working plugin, guess what was missing from the offending plugin?
Re: Migrating source builds from PDE, product i ssue [message #544201 is a reply to message #544200] Thu, 01 July 2010 20:28 Go to previous messageGo to next message
By the way, totally off-topic, but has anyone figured out how to do a search for files that *don't* contain a given string such as Manifest-Version? I don't think you can do it with regexp. I could do it with grep, but that doesn't help for Eclipse editing.
Re: Migrating source builds from PDE, product i ssue [message #544204 is a reply to message #544200] Thu, 01 July 2010 21:39 Go to previous messageGo to next message
Good news!
I would also like the IDE to be able to flag this.
This was a quite recent discovery, maybe we can add a better error
message in Buckminster to keep you from guessing what could be wrong.
- henrik
>> builds it anyway.
> is for, right? ;)) I just looked for trouble spots but somehow I missed
Re: Migrating source builds from PDE, product i ssue [message #544205 is a reply to message #544201] Thu, 01 July 2010 21:49 Go to previous messageGo to next message
Perhaps something like...
Do two searches a) something that finds all manifests, b) search for
"Manifest-Version"
View as list, select all, copy, paste into a file
compare the two files
Unfortunately, there is no regexp pattern for "start of file" in Eclipse
file search.
- henrik
Re: Migrating source builds from PDE, product i ssue [message #544206 is a reply to message #544205] Thu, 01 July 2010 21:59 Go to previous messageGo to next message
Yes that makes sense. I just remembered another technique I've used which is to just do the search for matching ones and then do show in package explorer for all of them. Then you can pick out by inspection the projects that don't have a file with the correct bits.
Henrik Lindberg wrote on Thu, 01 July 2010 21:49
"Manifest-Version"
file search.
- henrik
Re: Migrating source builds from PDE, product issue [message #544209 is a reply to message #543941] Thu, 01 July 2010 22:30 Go to previous messageGo to next message
Thomas, where do I specify the category.xml to use? O does that just need to be at the base of the feature dir like it is in PDE?
Anyway now that I'm past the other issues, the p2.site is failing with:
: java.lang.IllegalArgumentException
No other information than that.
Re: Migrating source builds from PDE, product issue [message #544210 is a reply to message #543941] Thu, 01 July 2010 22:46 Go to previous messageGo to next message
Thomas, one more question, please see below..
As I mentioned I have this already -- its actually not an SDK feature, its an enveloping source feature that includes the source features themselves as well as docs.
But its strange -- the problem that I'm having is that it looks like Buckminster is creating a dependency to the (as far as I can tell imaginary) org.eclipse.amp.source.source.feature instead, or at least putting that in the metadata. I have org.eclipse.amp.source.feature defined as a dependency and it appears in the build dir, but if I select the Source to install in P2, it shows that source id as org.eclipse.amp.source.source.feature.
Re: Migrating source builds from PDE, product issue [message #544212 is a reply to message #544209] Thu, 01 July 2010 23:16 Go to previous messageGo to next message
Miles Parker wrote on Thu, 01 July 2010 22:30
I think I've resolved this one. Apparently something didn't like something in my category.xml file. (It works for regular PDE build but it probably isn't exactly right in this context.)
Re: Migrating source builds from PDE, product issue [message #544248 is a reply to message #544179] Fri, 02 July 2010 02:38 Go to previous messageGo to next message
> #eclipse.build]
> #eclipse.build]
> #bundle.jar]
> #bundle.jar]
This is the start/end of two different actions on the same bundle as it is the expected behavior. It should be the same
for all bundles.
First it performs the Eclipse workspace build (i.e. the build that is defined in your .project files). This produces the
..class files, copies .properties etc. Everything that normally happens when the incremental build kicks in in your IDE.
This is the #eclipse.build. After that, it performs the #bundle.jar. That is the action that creates the actual jar to
be published.
- thomas
Re: Migrating source builds from PDE, product issue [message #544249 is a reply to message #544210] Fri, 02 July 2010 02:38 Go to previous messageGo to next message
That doesn't sound right. Can you please enter a bugzilla for that?
Thomas Hallgren
Re: Migrating source builds from PDE, product issue [message #544250 is a reply to message #544176] Fri, 02 July 2010 02:41 Go to previous messageGo to next message
Exactly where do you find these files? Adjacent to the actual source in your workspace or in the build output?
- thomas
Re: Migrating source builds from PDE, product issue [message #544456 is a reply to message #544250] Fri, 02 July 2010 13:58 Go to previous messageGo to next message
Thomas Hallgren wrote on Fri, 02 July 2010 02:41
> ..it contains jar and src.jars like:
- thomas
In the build output. But I determined that this was due to the fact that my MANIFEST.MF didn't have Manifest-Version.
Re: Migrating source builds from PDE, product issue [message #545188 is a reply to message #543844] Tue, 06 July 2010 22:34 Go to previous message
As a final note to all of this, I'm pretty sure that the issue was that my docs and source feature -- the one that includes the generate.feature directives -- ends in ".source". So perhpas there is an assumption somwehere in Buckminster's magic for discovering the source features. When I changed the name (to "doc.all") the issue above seems to have gone away but if I change it back I have problems. Luckily, it doesn't actually matter to me what the feature id is. Smile
Previous Topic:Can't install headless 3.6
Next Topic:Buckminster 3.6: URI is not hierarchical
Current Time: Thu Jul 24 15:52:31 EDT 2025
Powered by FUDForum. Page generated in 0.09373 seconds
