Home » Archived » Buckminster » about.mappins and Buckminster 3.6
about.mappins and Buckminster 3.6 [message #542467] Thu, 24 June 2010 19:47 Go to next message
After upgrading my Buckminster / Hudson combo to 3.6, I encountered a bug (well, atleast I think so):
I'm trying to override the new default about.mappings action, i.e. I wish to use my own buildFile instead of the predefined buildFileId.
When I add the buildFile via alterActorProperties I get an exception that having both is not allowed; however I can't remove the buildFileId either.
Trying to remove it leads to:
org.eclipse.buckminster.core.common.model.ImmutablePropertyE xception: buildFileId
at org.eclipse.buckminster.core.common.model.ExpandingPropertie s.remove(ExpandingProperties.java:391)
at org.eclipse.buckminster.core.cspecext.model.AlterAttribute.p erformPropertyAlterations(AlterAttribute.java:68)
at org.eclipse.buckminster.core.cspecext.model.AlterAction.alte rActorProperties(AlterAction.java:91)
at org.eclipse.buckminster.core.cspecext.model.AlterAction.alte rAttribute(AlterAction.java:82)
at org.eclipse.buckminster.core.cspecext.model.CSpecExtension.a lterCSpec(CSpecExtension.java:111)
at org.eclipse.buckminster.core.cspec.AbstractResolutionBuilder .applyExtensions(AbstractResolutionBuilder.java:132)
at org.eclipse.buckminster.pde.cspecgen.PDEBuilder.build(PDEBui lder.java:70)
at org.eclipse.buckminster.core.ctype.AbstractComponentType.get Resolution(AbstractComponentType.java:316)
at org.eclipse.buckminster.core.ctype.AbstractComponentType.get Resolution(AbstractComponentType.java:201)
at org.eclipse.buckminster.core.resolver.LocalResolver.fromPath (LocalResolver.java:163)
at org.eclipse.buckminster.core.resolver.LocalResolver.fromPath (LocalResolver.java:184)
at org.eclipse.buckminster.core.metadata.MetadataSynchronizer.r efreshProject(MetadataSynchronizer.java:313)
at org.eclipse.buckminster.core.metadata.MetadataSynchronizer$M etadataRefreshJob.run(MetadataSynchronizer.java:126)
at org.eclipse.core.internal.jobs.Worker.run(Worker.java:54)
Is this a feature or a bug? If it is a feature, how am I supposed to override the default about.mappings action??
Re: about.mappins and Buckminster 3.6 [message #542480 is a reply to message #542467] Thu, 24 June 2010 23:34 Go to previous messageGo to next message
Sounds like a bug. Please log a bugzilla issue and supply the info...
- henrik
> buildFileId either.
> buildFileId
> lder.java:70)
- henrik
Re: about.mappins and Buckminster 3.6 [message #542493 is a reply to message #542467] Fri, 25 June 2010 00:59 Go to previous messageGo to next message
Hi Philipp,
I doubt this is a regression. Can you verify that this used to work in earlier versions?
> either.
This sounds like a bug. Can you please report it using our bugzilla? The workaround for now is to remove the action
altogether and then add it again. This should work since removes are executed before new additions are added.
HTH,
- thomas
> buildFileId
> lder.java:70)
Re: about.mappins and Buckminster 3.6 [message #542502 is a reply to message #542467] Fri, 25 June 2010 02:42 Go to previous messageGo to next message
3.5 apparently didn't have a default about.mappings action, so I didn't have to overwrite anything.
Basically, all I want to do is replace a second token besides the @build@ in the about.mappings
Re: about.mappins and Buckminster 3.6 [message #542512 is a reply to message #542467] Fri, 25 June 2010 03:26 Go to previous messageGo to next message
Bugzilla created: https://bugs.eclipse.org/bugs/show_bug.cgi?id=317922
Thanks for your time!
Re: about.mappins and Buckminster 3.6 [message #542986 is a reply to message #542493] Mon, 28 June 2010 02:39 Go to previous messageGo to next message
Thomas Hallgren wrote on Fri, 25 June 2010 00:59
Unfortunately that doesn'r work either.
Using:
	<alterActions>
		<remove name="about.mappings"/>
		<private name="about.mappings" actor="ant">
			<actorProperties>
				<property key="buildFile" value="build/about_mappings.ant"/>
				<property key="targets" value="replace.tokens"/>
			</actorProperties>
			<properties>
				<property key="build.id" value="${BUILD_ID} (r${SVN_REVISION})"/>
				<property key="version" value="${VERSION}"/>
			</properties>
			<prerequisites>
				<attribute alias="action.input" name="raw.about.mappings"/>
			</prerequisites>
			<products alias="action.output" base="${buckminster.output}/temp/">
				<path path="about.mappings"/>
			</products>
		</private>
	</alterActions>
I get Problem during meta-data refresh: CSpec net.sf.logsaw.rcp has no action, group, or local artifact named about.mappings
Re: about.mappins and Buckminster 3.6 [message #543283 is a reply to message #542986] Mon, 28 June 2010 19:26 Go to previous messageGo to next message
Hi Philipp,
I think you've misinterpreted the cspex syntax. It's an extension of the cspec and the <alterActions> is about altering
or removing existing actions, not about adding them. That's done using a normal <actions> element. Your example attempts
to first remove and then alter the same action.
Try something like this:
<actions>
<actorProperties>
</actorProperties>
<properties>
</properties>
<prerequisites>
</prerequisites>
</products>
</private>
</actions>
<alterActions>
</alterActions>
The order is not significant. A remove is always executed before an add.
Thomas Hallgren
>> The workaround for now is to remove the action altogether and then add
> Using:
> <alterActions>
> <actorProperties>
> </actorProperties>
> <properties>
> </properties>
> <prerequisites>
> </prerequisites>
> </products>
> </private>
> </alterActions>
Re: about.mappins and Buckminster 3.6 [message #543295 is a reply to message #542467] Mon, 28 June 2010 20:50 Go to previous message
Hi Thomas, that did the trick! Many thanks for the pointer Smile
Kind regards,
Philipp
Previous Topic:Groovy support, Eclipse 3.6
Next Topic:qaulifier replacement property
Current Time: Fri Sep 26 03:48:26 EDT 2025
Powered by FUDForum. Page generated in 0.24681 seconds
