Home » Archived » Buckminster » Call action after action completes
Call action after action completes [message #542444] Thu, 24 June 2010 17:03 Go to next message
After I call create.product action I need to remove some files from a plugin that was build. I was thinking of creating an action that calls ant script to do this, but not sure where to call this action after create.product finishes. Action I want to call is remove.j2ee. Here is my cspex file:
<cspecExtension xmlns:com="http://www.eclipse.org/buckminster/Common-1.0"
	xmlns="http://www.eclipse.org/buckminster/CSpec-1.0">
	<actions>
		<!-- actions that removes j2ee.jar from common -->
		<public name="remove.j2ee" actor="ant">
			<actorProperties>
				<property key="cleanUp" value="build/cleanUp.xml" />
				<property key="targets" value="removeJ2ee" />
			</actorProperties>
		</public>
		<public name="create.product" actor="ant">
			<actorProperties>
				<property key="buildFile" value="build/product.ant" />
				<property key="targets" value="create.product" />
				<property key="removej2ee" value="remove.j2ee" />
			</actorProperties>
			<properties>
				<property key="profile" value="iitProfile" />
				<property key="iu" value="iit.product" />
			</properties>
			<prerequisites alias="repository">
				<attribute name="site.p2" />
			</prerequisites>
			<products alias="destination" base="${buckminster.output}">
				<path path="integrationtools.${target.os}.${target.arch}/" />
			</products>
		</public>
		<public name="create.product.zip" actor="ant">
			<actorProperties>
				<property key="buildFileId" value="buckminster.pdetasks" />
				<property key="targets" value="create.zip" />
			</actorProperties>
			<prerequisites alias="action.requirements">
				<attribute name="create.product" />
			</prerequisites>
			<products alias="action.output" base="${buckminster.output}">
				<path
					path="integrationtools.${target.ws}.${target.os}.${target.arch}.zip" />
			</products>
		</public>
	</actions>
</cspecExtension>
Also, is this the right approach or there is easier/better way to do this?
thanks,
Alex
Re: Call action after action completes [message #542457 is a reply to message #542444] Thu, 24 June 2010 18:10 Go to previous messageGo to next message
I am on a small device right now and can't really make sense of the XML.
But the general approach is to call your command and have it require the
original.
Using a cspex it should be possible to rename the original as well -
thus making it possible to use the original name for your decorating
action and thus hiding the fact from other callers that extra logic was
inserted.
- henrik
Alex <camokatu@gmail.com> wrote:
> Hello,
> my cspex file:
> <cspecExtension
> <actions>
> <actorProperties>
> </actorProperties>
> </public>
> <actorProperties>
> </actorProperties>
> <properties>
> </properties>
> </prerequisites>
> </products>
> </public>
> <actorProperties>
> </actorProperties>
> </prerequisites>
> <path
> path=" integrationtools.${target.ws}.${target.os}.${target.arch}.zi p "
> </products>
> </public>
> </actions>
> </cspecExtension>
this?
thanks,
Alex
- henrik
Re: Call action after action completes [message #542672 is a reply to message #542457] Fri, 25 June 2010 11:19 Go to previous messageGo to next message
Yes, that's the obvious solution, but is there way to "inject" some actions into other actions similar to what happens in <prerequisites> element, but after the action finishes?
thanks,
Alex
Re: Call action after action completes [message #542775 is a reply to message #542672] Fri, 25 June 2010 20:35 Go to previous messageGo to next message
Not that I am aware of (sorry). Someone else may have some other clever
tricks up their sleeve...
In b3 it is possible to advise the build logic to inject behavior
before/after/around a builder (comparable to Buckminster action). This
is specified and implemented, but there is still a lot of work remaining
before building with b3.
A solution that may be easier to implement in Buckminster would be "on
completion of action x run action y with result of x as 'prerequisite'"
Contributions are welcome ;)
- henrik
Re: Call action after action completes [message #542782 is a reply to message #542775] Fri, 25 June 2010 22:54 Go to previous message
Thanks Henrik,
Contributions are welcome Wink
I am just getting comfortable with buckminster, haven't dived too much in the code yet, but this is a good opportunity to do that.
thanks,
Alex
Previous Topic:Suppress build warnings
Next Topic:P2 site without macosx support with filters
Current Time: Sun Jun 15 07:32:45 EDT 2025
Powered by FUDForum. Page generated in 0.07021 seconds
