Home » Archived » Buckminster » product.ant where can I find example ?(product.ant is not found and I do not know where to get it)
product.ant where can I find example ? [message #540289] Tue, 15 June 2010 10:32 Go to next message
Hi all,
I know it is a newbie question, but I do not manage to get an example of a product.ant.
by following the tutorial on http://www.ralfebert.de/blog/eclipsercp/rcp_builds/ (on which the link to the product.ant is not available).
I have got this error:
ERROR: org.eclipse.core.runtime.CoreException: Buildfile: /var/lib/hudson/jobs/SWIFT_V2/workspace/com.ena.swift.featur e.site/build/product.ant does not exist
Where can I find an example ?
Thank you !
Sabri.
Re: product.ant where can I find example ? [message #540293 is a reply to message #540289] Tue, 15 June 2010 10:40 Go to previous messageGo to next message
It is available from the SVN repo here:
http://dev.eclipse.org/svnroot/tools/org.eclipse.buckminster
Here is the source:
<project>
<pathconvert property="equinox.launcher.jar">
<first count="1">
<sort>
<fileset dir="${eclipse.home}/plugins"
includes="**/org.eclipse.equinox.launcher_*.jar"/>
<reverse
xmlns="antlib:org.apache.tools.ant.types.resources.comparators ">
<date/>
</reverse>
</sort>
</first>
</pathconvert>
<target name="create.product">
<property name="destination" location="${sp:destination}"/>
<delete dir="${destination}"></delete>
<makeurl property="repository" file="${sp:repository}"/>
<mkdir dir="${destination}"/>
<echoproperties ></echoproperties>
<echo message="${equinox.launcher.jar}"/>
<echo message="${repository}"/>
<echo message="${destination}"/>
<java jar="${equinox.launcher.jar}" fork="true" failonerror="true" >
<arg value="-application"/>
<arg value="org.eclipse.equinox.p2.director"/>
<arg value="-artifactRepository"/>
<arg value="file:${repository}"/>
<arg value="-metadataRepository"/>
<arg value="-destination"/>
<arg value="${destination}"/>
<arg value="-bundlepool"/>
<arg value="-profile"/>
<arg value="${profile}"/>
<arg value="-profileProperties" />
<arg value="org.eclipse.update.install.features=true" />
<arg value="-installIU"/>
<arg value="${iu}"/>
<arg value="-p2.os" />
<arg value="${target.os}" />
<arg value="-p2.ws" />
<arg value="${target.ws}" />
<arg value="-p2.arch" />
<arg value="${target.arch}" />
<arg value="-consoleLog"/>
<jvmarg value="-Declipse.p2.data.area=${destination}/p2"/>
<jvmarg value="-Declipse.p2.profile=${profile}"/>
</java>
</target>
</project>
"Sabri Skhiri" <sabri-ese@euranova.eu> wrote in message
news:hv82ta$mmo$1@build.eclipse.org...
> Hi all,
> product.ant.
> Thank you !
> Sabri.
[Updated on: Wed, 23 June 2010 07:35] by Moderator
Re: product.ant where can I find example ? [message #540344 is a reply to message #540293] Tue, 15 June 2010 14:30 Go to previous messageGo to next message
Thank you ! I got it and now I have an exception. Have you got any idea of what it could be ?
ERROR: org.eclipse.core.runtime.CoreException: /var/lib/hudson/jobs/SWIFT_V2/workspace/com.ena.swift.feature.site/build/product.ant:3: sort doesn't support the nested "antlib:org.apache.tools.ant.types.resources.comparators :reverse" element.
I use Buckminster 3.5.
Sabri.
Re: product.ant where can I find example ? [message #540418 is a reply to message #540344] Wed, 16 June 2010 02:13 Go to previous messageGo to next message
My guess is that your build is picking up an old Ant (older than 1.7). Buckminster 3.5 comes with 1.7.1. Perhaps your
environment explicitly set ANT_HOME to point to another installation?
Thomas Hallgren
> /var/lib/hudson/jobs/SWIFT_V2/workspace/com.ena.swift.featur e.site/build/product.ant:3:
> Sabri.
Re: product.ant where can I find example ? [message #541697 is a reply to message #540289] Tue, 22 June 2010 04:38 Go to previous messageGo to next message
I just tried the tutorial on http://www.ralfebert.de/blog/eclipsercp/rcp_builds/ as well and got the same error message
The solution is to remove the space at the end of the reverse element of the product.ant file. This results in
<reverse xmlns="antlib:org.apache.tools.ant.types.resources.comparators">
instead of
<reverse xmlns="antlib:org.apache.tools.ant.types.resources.comparators ">
[Updated on: Tue, 22 June 2010 04:40] by Moderator
Re: product.ant where can I find example ? [message #541720 is a reply to message #541697] Tue, 22 June 2010 06:18 Go to previous messageGo to next message
I Rene,
In what file is this?
- thomas
> same error message
> The solution is to remove the space at before the quote at the end of
> the reverse element. This results in <reverse
> instead of
Re: product.ant where can I find example ? [message #541726 is a reply to message #541720] Tue, 22 June 2010 06:37 Go to previous message
It only concerns the product.ant content Geejay posted in this thread. The file at http://dev.eclipse.org/svnroot/tools/org.eclipse.buckminster is all correct.
The problem only occurs when copy&paste the posted product.ant content.
Previous Topic:The main feature is not found when buckminster build
Next Topic:Eclipse 3.5 build with 3.4 plugins
Current Time: Sat Jul 26 18:49:44 EDT 2025
Powered by FUDForum. Page generated in 0.04644 seconds
