Home » Language IDEs » C / C++ IDE (CDT) » /bin/sh: arm-none-linux-gnueabi-g++: not found(can not compile with arm using eclipse)
/bin/sh: arm-none-linux-gnueabi-g++: not found [message #539902] Mon, 14 June 2010 05:10 Go to next message
I am trying to use the arm-none-linux-gnueabi-g++
I have the toolchain downloaded, and i add it to my path
echo $PATH
/home/toolchain/arm-2008q1/bin:/usr/local/sbin:/usr/local/bi n:/usr/sbin:/usr/bin:/sbin:/bin:/usr/games
I also can run the command arm-none-linux-gnueabi-g++ from the command line,
inside eclipse i went to project build settings
and changed the gcc to arm-none-linux-gnueabi-gcc
also g++ to arm-none-linux-gnueabi-g++
However when i try to build, i get the error
any clue on what is missing?
Re: /bin/sh: arm-none-linux-gnueabi-g++: not found [message #540006 is a reply to message #539902] Mon, 14 June 2010 10:59 Go to previous messageGo to next message
Did your change your $PATH after Eclipse was started? I guess Eclipse has not the current PATH settings. You have to either restart Eclipse or completely logout and then login (depends how you start Eclipse).
Re: /bin/sh: arm-none-linux-gnueabi-g++: not found [message #540019 is a reply to message #540006] Mon, 14 June 2010 11:34 Go to previous messageGo to next message
i had to change the $PATH inside eclipse to make it work
inside environment.
i restarted eclipse many times before doing that and it didnt work until i change it manually again inside eclipse.
Re: /bin/sh: arm-none-linux-gnueabi-g++: not found [message #540087 is a reply to message #540019] Mon, 14 June 2010 16:30 Go to previous messageGo to next message
Did you change the PATH variable in .bashrc our in .bash_profile? These files are only read when you login. That's why Eclipse (or any other program) will not see your changes to the PATH variable.
Re: /bin/sh: arm-none-linux-gnueabi-g++: not found [message #540143 is a reply to message #540087] Tue, 15 June 2010 03:20 Go to previous messageGo to next message
Yes i changed the file but i did not log out, before using eclipse
thank you i think that was the problem Smile
Re: /bin/sh: arm-none-linux-gnueabi-g++: not found [message #894660 is a reply to message #540143] Mon, 09 July 2012 23:04 Go to previous messageGo to next message
Hi guys,
I'm new to eclipse and embedded systems and came accros the same problem. I am trying to run the tutorial provided here:
[can't post links - youtube "beaglebone c++" and you find the video]
Unfortunately I am stuck with the compiling process of the first eclipse example. I added includes and library paths as described and when I try to "Build All" I get this:
**** Build of configuration Debug for project beaglebone ****
make all
Building file: ../src/beaglebone.cpp
Invoking: GCC C++ Compiler
arm-linux-gnueabi-g++ -I/usr/arm-linux-gnueabi/include/c++/4.4.7 -O0 -g3 -Wall -c -fmessage-length=0 -MMD -MP -MF"src/beaglebone.d" -MT"src/beaglebone.d" -o "src/beaglebone.o" "../src/beaglebone.cpp"
/bin/sh: 1: arm-linux-gnueabi-g++: not found
make: *** [src/beaglebone.o] Error 127
**** Build Finished ****
I googled the problem, found this thread and still don't know what to do exactely. Can you please extend on the solution provided here by giving me the noob-rundown of how to change the $PATH variable? What are the steps?
Otl
Re: /bin/sh: arm-none-linux-gnueabi-g++: not found [message #1101627 is a reply to message #894660] Wed, 04 September 2013 14:30 Go to previous message
@ Otl
Did u find any solution to your issue of setting path? ...please can you share
Previous Topic:Debugger dies during initialization on OSX 10.6
Next Topic:Adding project reference programmatically.
Current Time: Mon Jun 16 07:15:12 EDT 2025
Powered by FUDForum. Page generated in 0.08348 seconds
