Home » Archived » Buckminster » ERROR [0001] : The import junit cannot be resolved
ERROR [0001] : The import junit cannot be resolved [message #537134] Tue, 01 June 2010 08:42 Go to next message
Hi all,
I have a project with 'Java BuildPath' - Libraries - JUnit4 - junit.jar. This references to a local file.
In my case to Eclipse plugin c:\eclipse-3.1.5.-6\plugins\org.junit4_4.5.0.v20090824
There are more Libraries definied such as junit.
In Buckminster IDE its OK.
But in buckminster headless I get following error:
How can I resolve my Problem to work in IDE and headless? Have I to customize dependencies?
Any ideas?
Rainer
Re: ERROR [0001] : The import junit cannot be resolved [message #537255 is a reply to message #537134] Tue, 01 June 2010 12:48 Go to previous messageGo to next message
Hello Rainer,
did you install the headless support for junit?
Axel
Rainer wrote:
> Hi all,
> This references to a local file. In my case to Eclipse plugin
> c:\eclipse-3.1.5.-6\plugins\org.junit4_4.5.0.v20090824 There are more
> Libraries definied such as junit. In Buckminster IDE its OK.
> Any ideas?
> Rainer
Re: ERROR [0001] : The import junit cannot be resolved [message #538948 is a reply to message #537255] Wed, 09 June 2010 03:38 Go to previous messageGo to next message
I use buckminster headless 1.1.350.r11410 (3.5)
How can I install support for junit?
If I use buckminster headless 1.2.0.r11458 (Eclipse 3.6) then I get following error:
ERROR [0001] : java.lang.NoSuchMethodError: org.eclipse.buckminster.core.resolver.NodeQuery.getRevision( )J
Why J at last character?
How can I fix my problems?
any ideas?
Rainer
Re: ERROR [0001] : The import junit cannot be resolved [message #538993 is a reply to message #538948] Wed, 09 June 2010 05:13 Go to previous messageGo to next message
On 06/09/2010 09:38 AM, Rainer wrote:
> Hi
You can't. Not in 3.6. But do you really need to install it? From the printout it seems like your target platform is
lacking the bundle. You only need to install it if you plan to actually run the JUnit tests.
> following error:
The internal name used by the NoSuchMethodError includes the return type and J is internal Java lingo for long.
Reinstall using a 3.6 product as well as a 3.6 features. You can't mix them.
Thomas Hallgren
Re: ERROR [0001] : The import junit cannot be resolved [message #538994 is a reply to message #538993] Wed, 09 June 2010 05:44 Go to previous message
>> Hi
Uh, I meant to write "not in 3.5". Sorry...
- thomas
Previous Topic:Headless build: The import junit cannot be resolved
Next Topic:Standalone build with buckminster
Current Time: Fri Jul 25 21:39:35 EDT 2025
Powered by FUDForum. Page generated in 0.38752 seconds
