Home » Archived » Buckminster » Product IU generated to require org.eclipse.core.runtime bundles
Product IU generated to require org.eclipse.core.runtime bundles [message #535435] Sun, 23 May 2010 09:49 Go to next message
I noticed that my product IU is generated to depend on
org.eclipse.core.runtime, org.eclipse.core.jobs, and
org.eclipse.core.contenttype even though none of my bundles/features
require anything in those bundles. If I install my product-level feature
alone, they don't get pulled in; if I install the product IU, they do
get pulled in (because content.xml lists them as required).
Does anyone know why this is happening (I'm not sure when it started but
I could swear it only started recently -- I'm using the latest 3.6
code)? Is there a way to avoid it? Any insight would be greatly
appreciated. Thanks!
--Peter
Re: Product IU generated to require org.eclipse.core.runtime bundles [message #535780 is a reply to message #535435] Tue, 25 May 2010 11:03 Go to previous messageGo to next message
Btw I confirmed that PDE Export of the product does the right thing --
no extra dependencies are added. Sadness... :-(
On 5/23/10 9:49 AM, Peter Nehrer wrote:
> --Peter
Re: Product IU generated to require org.eclipse.core.runtime bundles [message #536047 is a reply to message #535780] Wed, 26 May 2010 14:24 Go to previous messageGo to next message
FWIW -- I ended up moving my *.product files out of features and into a
releng project, then implementing custom build steps to create my
product configurations using p2.publish.product. I wish I didn't have to
resort to that -- Buckminster provides a very elegant solution (if I
were able to figure out how to get it to do what I need it to do).
--Peter
>> Hi,
>> --Peter
Re: Product IU generated to require org.eclipse.core.runtime bundles [message #536067 is a reply to message #536047] Wed, 26 May 2010 16:15 Go to previous messageGo to next message
Peter,
It would help if you could add a bugzilla and attach a sample that can be used to reproduce the problem (and eventually
verify it's been fixed).
Thomas Hallgren
> --Peter
>>> Hi,
>>> --Peter
Re: Product IU generated to require org.eclipse.core.runtime bundles [message #541011 is a reply to message #536067] Fri, 18 June 2010 00:52 Go to previous message
Thomas,
I submitted a bugzilla to track this:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=317263
Examples are attached. Thanks.
--Peter
Previous Topic:Generating feature version suffixes
Next Topic:More than one rootRequest in the cquery-file?
Current Time: Mon Jun 16 10:30:01 EDT 2025
Powered by FUDForum. Page generated in 0.04176 seconds
