"java.lang.IllegalArgumentException: URI is not hierarchical" when switching to Buckm. 3.6 [message #534217] |
Tue, 18 May 2010 08:03  |
I have a continuous build integration of several PDE projects in Hudson, and use Buckminster for building the projects. Everything worked fine with Buckminster 3.5. But when I updated to Buckminster 3.6 (without changing other project settings; in fact, switching back to 3.5, and the build works again) the build breaks with the following error:
INFO: [start org.moduig.site:eclipse.feature$1.0.0.qualifier#create.produ ct]
[ant] C:\Tools\buckminster\buckminster-3.6-headless\plugins\org.ec lipse.equinox.launcher_1.1.0.v20100322-1720.jar
[ant] file:/c:/hudson/jobs/MoDUIG/workspace/buckminster.output/org .moduig.site_1.0.0-eclipse.feature/site.p2/
[ant] c:\hudson\jobs\MoDUIG\workspace\buckminster.output\org.modui g.site_1.0.0-eclipse.feature\moduig.win32.win32.x86
[ant] Unable to load repositories.
[ant] Application failed, log file location: C:\Tools\buckminster\buckminster-3.6-headless\configuration\ 1274182466290.log
ERROR: org.eclipse.core.runtime.CoreException: C:\Hudson\jobs\MoDUIG\workspace\Prototyp_v4\org.moduig.site\ build\product.ant:22: Java returned: 13
at org.eclipse.buckminster.ant.AntRunner.handleInvocationTarget Exception(AntRunner.java:167)
at org.eclipse.buckminster.ant.AntRunner.run(AntRunner.java:322 )
at org.eclipse.buckminster.ant.actor.AntActor.internalPerform(A ntActor.java:252)
at org.eclipse.buckminster.core.actor.AbstractActor.perform(Abs tractActor.java:186)
at org.eclipse.buckminster.core.internal.actor.PerformManager$D irectActionInvocation.execute(PerformManager.java:143)
at org.eclipse.buckminster.core.internal.actor.PerformManager.i nternalPerform(PerformManager.java:454)
at org.eclipse.buckminster.core.internal.actor.PerformManager.p erform(PerformManager.java:293)
at org.eclipse.buckminster.core.internal.actor.PerformManager.p erform(PerformManager.java:305)
at org.eclipse.buckminster.core.commands.Perform.internalRun(Pe rform.java:108)
at org.eclipse.buckminster.core.commands.WorkspaceCommand.run(W orkspaceCommand.java:91)
at org.eclipse.buckminster.cmdline.AbstractCommand.basicRun(Abs tractCommand.java:194)
at org.eclipse.buckminster.cmdline.Headless.run(Headless.java:3 17)
at org.eclipse.buckminster.cmdline.Headless.run(Headless.java:1 36)
at org.eclipse.buckminster.cmdline.Headless.start(Headless.java :156)
at org.eclipse.equinox.internal.app.EclipseAppHandle.run(Eclips eAppHandle.java:196)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:110)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:79)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:369)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:179)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAcce ssorImpl.java:39)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMe thodAccessorImpl.java:25)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java: 619)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:574)
at org.eclipse.equinox.launcher.Main.run(Main.java:1407)
at org.eclipse.equinox.launcher.Main.main(Main.java:1383)
Caused by: C:\Hudson\jobs\MoDUIG\workspace\Prototyp_v4\org.moduig.site\ build\product.ant:22: Java returned: 13
at org.apache.tools.ant.taskdefs.Java.execute(Java.java:108)
at org.apache.tools.ant.UnknownElement.execute(UnknownElement.j ava:288)
at sun.reflect.GeneratedMethodAccessor41.invoke(Unknown Source)
at org.apache.tools.ant.dispatch.DispatchUtils.execute(Dispatch Utils.java:106)
at org.apache.tools.ant.Task.perform(Task.java:348)
at org.apache.tools.ant.Target.execute(Target.java:357)
at org.apache.tools.ant.Target.performTasks(Target.java:385)
at org.apache.tools.ant.Project.executeSortedTargets(Project.ja va:1337)
at org.apache.tools.ant.Project.executeTarget(Project.java:1306 )
at org.apache.tools.ant.helper.DefaultExecutor.executeTargets(D efaultExecutor.java:41)
at org.eclipse.ant.internal.core.ant.EclipseDefaultExecutor.exe cuteTargets(EclipseDefaultExecutor.java:32)
at org.apache.tools.ant.Project.executeTargets(Project.java:118 9)
at org.eclipse.ant.internal.core.ant.InternalAntRunner.run(Inte rnalAntRunner.java:662)
at org.eclipse.ant.internal.core.ant.InternalAntRunner.run(Inte rnalAntRunner.java:495)
at sun.reflect.GeneratedMethodAccessor28.invoke(Unknown Source)
at org.eclipse.buckminster.ant.AntRunner.run(AntRunner.java:318 )
... 25 more
The log file says the following:
!SESSION 2010-05-18 13:34:25.462 -----------------------------------------------
eclipse.buildId=unknown
java.version=1.6.0_16
BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=de_DE
Framework arguments: -application org.eclipse.equinox.p2.director -artifactRepository file:file:/c:/hudson/jobs/MoDUIG/workspace/buckminster.outpu t/org.moduig.site_1.0.0-eclipse.feature/site.p2/ -metadataRepository file:file:/c:/hudson/jobs/MoDUIG/workspace/buckminster.outpu t/org.moduig.site_1.0.0-eclipse.feature/site.p2/ -destination c:\hudson\jobs\MoDUIG\workspace\buckminster.output\org.modui g.site_1.0.0-eclipse.feature\moduig.win32.win32.x86 -bundlepool c:\hudson\jobs\MoDUIG\workspace\buckminster.output\org.modui g.site_1.0.0-eclipse.feature\moduig.win32.win32.x86 -profile ModuigProfile -profileProperties org.eclipse.update.install.features=true -installIU org.moduig.application.product -p2.os win32 -p2.ws win32 -p2.arch x86
Command-line arguments: -application org.eclipse.equinox.p2.director -artifactRepository file:file:/c:/hudson/jobs/MoDUIG/workspace/buckminster.outpu t/org.moduig.site_1.0.0-eclipse.feature/site.p2/ -metadataRepository file:file:/c:/hudson/jobs/MoDUIG/workspace/buckminster.outpu t/org.moduig.site_1.0.0-eclipse.feature/site.p2/ -destination c:\hudson\jobs\MoDUIG\workspace\buckminster.output\org.modui g.site_1.0.0-eclipse.feature\moduig.win32.win32.x86 -bundlepool c:\hudson\jobs\MoDUIG\workspace\buckminster.output\org.modui g.site_1.0.0-eclipse.feature\moduig.win32.win32.x86 -profile ModuigProfile -profileProperties org.eclipse.update.install.features=true -installIU org.moduig.application.product -p2.os win32 -p2.ws win32 -p2.arch x86 -consoleLog
!ENTRY org.eclipse.equinox.p2.artifact.repository 4 1000 2010-05-18 13:34:29.181
!MESSAGE No repository found at file:file:/c:/hudson/jobs/MoDUIG/workspace/buckminster.outpu t/org.moduig.site_1.0.0-eclipse.feature/site.p2/.
!ENTRY org.eclipse.equinox.p2.engine 4 1002 2010-05-18 13:34:29.243
!MESSAGE URI is not hierarchical
!STACK 0
at java.io.File.<init>(File.java:363)
at org.eclipse.equinox.internal.p2.engine.ProfileMetadataReposi tory.getProfile(ProfileMetadataRepository.java:174)
at org.eclipse.equinox.internal.p2.engine.ProfileMetadataReposi tory. <init>(ProfileMetadataRepository.java:49)
at org.eclipse.equinox.internal.p2.engine.ProfileMetadataReposi toryFactory.load(ProfileMetadataRepositoryFactory.java:36)
at org.eclipse.equinox.internal.p2.metadata.repository.Metadata RepositoryManager.factoryLoad(MetadataRepositoryManager.java :57)
at org.eclipse.equinox.internal.p2.repository.helpers.AbstractR epositoryManager.loadRepository(AbstractRepositoryManager.ja va:713)
at org.eclipse.equinox.internal.p2.repository.helpers.AbstractR epositoryManager.loadRepository(AbstractRepositoryManager.ja va:661)
at org.eclipse.equinox.internal.p2.metadata.repository.Metadata RepositoryManager.loadRepository(MetadataRepositoryManager.j ava:96)
at org.eclipse.equinox.internal.p2.metadata.repository.Metadata RepositoryManager.loadRepository(MetadataRepositoryManager.j ava:92)
at org.eclipse.equinox.internal.p2.director.app.DirectorApplica tion.initializeRepositories(DirectorApplication.java:403)
at org.eclipse.equinox.internal.p2.director.app.DirectorApplica tion.run(DirectorApplication.java:785)
at org.eclipse.equinox.internal.p2.director.app.DirectorApplica tion.start(DirectorApplication.java:941)
!ENTRY org.eclipse.equinox.p2.core 4 0 2010-05-18 13:34:29.243
!MESSAGE Unable to load repositories.
Is that "file:file:" in the repository path correct? And if not, where can I change it? Any hints are highly appreciated.
Kind Regards,
Andre
[Update: Please note, that the white spaces in the URI are not in the original log file. The forum somehow adds them, and I just can't get rid of them ]
[Updated on: Tue, 18 May 2010 08:25] by Moderator
Re: java.lang.IllegalArgumentException: URI is not hierarchical when switching to Buckminster 3.6 [message #534243 is a reply to message #534217] |
Tue, 18 May 2010 09:17   |
Andre,
I noticed this when I first tried to use the sample product.ant file
used for building products. For me this happened because the
${repository} property used in target create.product was already a url,
but was prefixed by file: when used in arg.
All I did was change
<arg value="file:${repository}"/>
into
<arg value="${repository}"/>
for both -artifactRepository and -metadataRepository arguments.
HTH.
--Peter
On 5/18/10 8:03 AM, Andre Preussner wrote:
> Hello,
> INFO: [start
> 1274182466290.log
> ntActor.java:252)
> rform.java:108)
> tarter.java:369)
> tarter.java:179)
> ssorImpl.java:39)
> at java.lang.reflect.Method.invoke(Method.java:597)
> Utils.java:106)
> ... 25 more
> !SESSION 2010-05-18 10:28:10.284
> java.version=1.6.0_06
> -artifactRepository
> file:file:/C:/Users/d051691/.hudson/jobs/Moduig3/workspace/b
> uckminster.output/org.moduig.site_1.0.0-eclipse.feature/site .p2/
> -metadataRepository
> -destination
> C:\Users\d051691\.hudson\jobs\Moduig3\workspace\buckminster.
> output\org.moduig.site_1.0.0-eclipse.feature\moduig.win32.wi n32.x86
> -bundlepool C:\Users\d051691\.hudson\jobs\Moduig3\workspace\buckminster.
> -artifactRepository
> -metadataRepository
> -destination
> -consoleLog
> 10:28:11.792
> uckminster.output/org.moduig.site_1.0.0-eclipse.feature/site .p2/.
> !ENTRY org.eclipse.equinox.p2.engine 4 1002 2010-05-18 10:28:11.824
> !STACK 0
> tarter.java:369)
> tarter.java:179)
> ssorImpl.java:39)
> !ENTRY org.eclipse.equinox.p2.core 4 0 2010-05-18 10:28:11.829
> Kind Regards,
> Andre
FUDForum. Page generated in 0.05248 seconds
