Home » Archived » Buckminster » headless build fails resolving plugins
headless build fails resolving plugins [message #533803] |
Mon, 17 May 2010 03:44  |
I run buckminster headless to build a project which requires Xpand
importtargetdefinition and import runs fine, however the following "build" fails resolving the Xpand plugins...
buckminster.bat -consoleLog -L DEBUG -data file:///W:/Buckminster_SopasGenerator build
Error: file W:\Buckminster_SopasGenerator\CodeGen\META-INF\MANIFEST.MF, line 24: Bundle 'org.eclipse.emf.mwe.utils' cannot be resolved
Error: file W:\Buckminster_SopasGenerator\CodeGen\META-INF\MANIFEST.MF, line 25: Bundle 'org.eclipse.xtend' cannot be resolved
Error: file W:\Buckminster_SopasGenerator\CodeGen\META-INF\MANIFEST.MF, line 22: Bundle 'org.eclipse.emf.mwe.core' cannot be resolved
Error: file W:\Buckminster_SopasGenerator\CodeGen\META-INF\MANIFEST.MF, line 23: Bundle 'org.eclipse.xpand' cannot be resolved
Do you have any idea why buckminster headless can not resolve them ?
As an indication, the same error msgs is also displayed in the Eclipse IDE (non headless) but after a "clean" or "build project" the plugins are found and the msg disapears.
I looked into the plugin registry and the relevant plugins are inactive after the startup of the IDE and just go activated after "build" in the IDE>
however how can I achieve this in buckminster headless ?
am I on the wrong path ? is there any sample ?
thanks,
Bernhard.
Re: headless build fails resolving plugins [message #533925 is a reply to message #533803] |
Mon, 17 May 2010 09:37   |
Hi Bernhard,
Do you get the same errors if you use the --thorough option?
- thomas
On 05/17/2010 09:44 AM, Bernhard Merkle wrote:
> IDE>
> thanks,
> Bernhard.
Re: headless build fails resolving plugins [message #534028 is a reply to message #533925] |
Mon, 17 May 2010 14:40   |
Hi Thomas
if i use build --thorough the error remains the same unfortunately.
is there any example of buckminster using also xpand (e.g. b3 ?).
Maybe I could use that as a example/template project ?
What I am puzzeled is that the error is also in eclipse IDE first.
Then when I do a rebuild the bundles are started. How does bucky handle
that ?
thanks again for your help
Berni.
C:\ide\ibm\buckminster-headless-3.5>buckminster.bat -consoleLog -L DEBUG
-data file:///W:/Buckminster_SopasGenerator build --thorough
!SESSION 2010-05-17 20:36:04.156
eclipse.buildId=unknown
java.version=1.6.0_20
BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=de_DE
Framework arguments: -L DEBUG build --thorough
Command-line arguments: -consoleLog -L DEBUG -data
!ENTRY org.eclipse.buckminster.runtime 0 293 2010-05-17 20:36:05.671
!MESSAGE build '--thorough'
build '--thorough'
line 26: Bundle 'org.eclipse.emf.mwe.core' cannot be resolved
line 27: Bundle 'org.eclipse.xpand' cannot be resolved
line 28: Bundle 'org.eclipse.emf.mwe.utils' cannot be resolved
line 29: Bundle 'org.eclipse.xtend' cannot be resolved
On 17.05.2010 15:37, Thomas Hallgren wrote:
> Hi Bernhard,
> - thomas
>> Hi,
>> IDE>
>> thanks,
>> Bernhard.
Re: headless build fails resolving plugins [message #534030 is a reply to message #534028] |
Mon, 17 May 2010 14:54   |
Hi Bernhard,
The error seems to stem from the PDE Manifest builder. You can turn them into warnings by using a preference setting for
that compiler on an empty workspace that you zip up and then use as a template workspace. Perhaps that can be used as a
workaround.
I don't know why some plug-ins doesn't get activated before you build in the IDE but I promise I'll bring that up with
the PDE team if you can provide a reproducible use-case in a bugzilla.
- thomas
On 05/17/2010 08:40 PM, Bernhard Merkle wrote:
> Hi Thomas
> that ?
> Berni.
> build '--thorough'
>> Hi Bernhard,
>> - thomas
>>> Hi,
>>> IDE>
>>> thanks,
>>> Bernhard.
Re: headless build fails resolving plugins [message #534050 is a reply to message #534030] |
Mon, 17 May 2010 15:44  |
okay. I use now the warning-instead-of-error workaround. Thanks !
Actually it can be activated project specific so i do not need to create
the template workspace (I prefer to have it only in that project).
thanks again for your help. I will try to create a reproducable use-case
and file a bugzilla (probably next week).
thanks,
Berni.
On 17.05.2010 20:54, Thomas Hallgren wrote:
> Hi Bernhard,
> into warnings by using a preference setting for that compiler on an
> Perhaps that can be used as a workaround.
> the IDE but I promise I'll bring that up with the PDE team if you can
> - thomas
>> Hi Thomas
>> that ?
>> Berni.
>> build '--thorough'
>>> Hi Bernhard,
>>> - thomas
>>>> Hi,
>>>> IDE>
>>>> thanks,
>>>> Bernhard.
Current Time: Wed Jul 23 14:53:52 EDT 2025
Powered by FUDForum. Page generated in 0.03281 seconds
