Home » Language IDEs » Java Development Tools (JDT) » How to get fully qualified names of parameters of selected method
How to get fully qualified names of parameters of selected method [message #529564] Mon, 26 April 2010 08:19 Go to next message
As told by briandealwis on irc I tried using SearchEngine to find fq names of types of parameters of selected method as below but it throws more than one results :
                                SearchPattern pattern = null;
                                IJavaSearchScope scope = null;
                                CollectingSearchRequestor requestor =
                                            new CollectingSearchRequestor();
                                SearchEngine engine = new SearchEngine();
                                String[] paramTypes =
                                    Signature.getParameterTypes(
                                            selectedMethod.getSignature());
                                List<Object> results = requestor.getResults();
                                for(String s : paramTypes) {
                                    if(!isPrimitive(s)) {
                                        String readebleTypeName =
                                            Signature.toString(s);
                                        pattern = SearchPattern.createPattern(
                                                readebleTypeName,
                                                IJavaSearchConstants.TYPE,
                                                IJavaSearchConstants.DECLARATIONS,
                                                SearchPattern.R_EXACT_MATCH | SearchPattern.R_CASE_SENSITIVE);
//                                        IJavaElement clazz = selectedMethod.getParent();
                                        scope = SearchEngine.createWorkspaceScope();
//                                                new IJavaElement[]
//                                                            {clazz}, false);
                                        try {
                                            engine.search(pattern,
                                                    new SearchParticipant[] {
                                                    SearchEngine.
                                                    getDefaultSearchParticipant()},
                                                    scope, requestor,
                                                    new NullProgressMonitor());
                                        } catch (CoreException e) {
                                            e.printStackTrace();
                                        for(ListIterator<Object> it = results.listIterator(); it.hasNext();) {
                                            Object ob = it.next();
                                            if(ob instanceof TypeDeclarationMatch) {
                                                Object element = ((TypeDeclarationMatch)ob).getElement();
                                                if(element instanceof ResolvedBinaryType) {
                                                    ResolvedBinaryType rbt = (ResolvedBinaryType)element;
                                                    System.out.println("Attempt : " + rbt.getKey() + "\tName : " + rbt.getElementName());
                                                } else if(element instanceof SourceType) {
                                                    SourceType st = (SourceType) element;
                                                    System.out.println("Attempt : " + st.getKey() + "\tName : " + st.getElementName());
There is no way to resolve the exact type of the parameter used in the method definition as several types are returned. If a (java) scope is created by passing the class or just the method it rightfully returns no results as types of parameters used for testing were String, user-defined-type etc.
Also this code makes use of a lot of internal api.
Isn't there an easy way to find fq names of types of parameters of a selected method. Just as a mouse hover on a method name quickly displays in a javadoc yellow box?
Thanks much in advance.
Re: How to get fully qualified names of parameters of selected method [message #529606 is a reply to message #529564] Mon, 26 April 2010 10:15 Go to previous messageGo to next message
Try with something like that:
String signature =
Signature.getParameterTypes(selectedMethod.getSignature())[0 ];
String[][] resolvedTypeName =
selectedMethod.getCompilationUnit().resolveType(Signature.ge tSignatureSimpleName(signature));
if (resolvedTypeName != null && resolvedTypeName.length == 1) {
String fqName = resolvedTypeName[0][0];
if (fqName != null && fqName.length() > 0) {
fqName = fqName + ".";
fqName = fqName + resolvedTypeName[0][1];
So you do not even need to use a search engine.
cheers
Andreas
> pattern =
> readebleTypeName,
> scope =
> // {clazz},
> false);
> try {
> new
> SearchEngine.
> scope, requestor,
> new
> if(ob instanceof
> Object element =
> ResolvedBinaryType
> } else if(element
> SourceType st =
Re: How to get fully qualified names of parameters of selected method [message #529809 is a reply to message #529606] Tue, 27 April 2010 06:30 Go to previous messageGo to next message
Hi Andreas,
Thanks for the reply.
I couldn't locate resolveType() method for ICompilationUnit.
But I used your code as a pointer and I think I have more or less nailed it :
            try {
                ICompilationUnit cu = method.getCompilationUnit();
                String[] paramTypes = Signature.getParameterTypes(
                        method.getSignature());
                        String readebleParamTypeName = Signature.getSignatureSimpleName(s);
                        IType type = method.getDeclaringType();
                        String[][] resolvedType = type.resolveType(readebleParamTypeName);
                        if(resolvedType != null && resolvedType.length > 0) {
                            System.out.println("?? : " + resolvedType[0][0] + "." + resolvedType[0][1]);
                    } else {
                        System.out.println("?? : " + Signature.toString(s));
            } catch (JavaModelException e) {
Would be happy to know if this code can be further corrected.
Thanks.
Re: How to get fully qualified names of parameters of selected method [message #529857 is a reply to message #529809] Tue, 27 April 2010 09:27 Go to previous message
You are right, the resolveType method is located on IType and not on the
ICompilationUnit. That's how compilerless programming ends.
In your snippet looks ok for simple cases; you did not aware generic
types and array signatures.
A method handling these issues could look like: (ScoutSignature.java of
Scout Project)
private String getTypeReferenceImpl(String signature, IType type,
IImportValidator validator) throws JavaModelException {
StringBuilder sigBuilder = new StringBuilder();
int arrayCount = 0;
switch (Signature.getTypeSignatureKind(signature)) {
case Signature.WILDCARD_TYPE_SIGNATURE:
sigBuilder.append("? extends ");
sigBuilder.append(getTypeReferenceImpl(signature.substring(1 ),
type, validator));
break;
case Signature.ARRAY_TYPE_SIGNATURE:
arrayCount = Signature.getArrayCount(signature);
sigBuilder.append(getTypeReferenceImpl(signature.substring(a rrayCount),
type, validator));
break;
case Signature.BASE_TYPE_SIGNATURE:
sigBuilder.append(Signature.getSignatureSimpleName(signature ));
break;
default:
String[] typeArguments = Signature.getTypeArguments(signature);
signature = Signature.getTypeErasure(signature);
if (signature.startsWith("Q")) {
// unresolved
type.resolveType(Signature.getSignatureSimpleName(signature) );
sigBuilder.append(validator.getSimpleTypeRef(Signature.creat eTypeSignature(fqName,
true)));
else {
// resolved
sigBuilder.append(validator.getSimpleTypeRef(signature));
if (typeArguments != null && typeArguments.length > 0) {
sigBuilder.append("<");
for (int i = 0; i < typeArguments.length; i++) {
if (i > 0) {
sigBuilder.append(", ");
sigBuilder.append(getTypeReferenceImpl(typeArguments[i],
type, validator));
sigBuilder.append(">");
break;
for (int i = 0; i < arrayCount; i++) {
sigBuilder.append("[]");
return sigBuilder.toString();
In your case replace
'validator.getSimpleTypeRef(Signature.createTypeSignature(fq Name,
true))' by
'Signature.getSignatureQualifier(singleTypeSignature)+Signat ure.getSignatureSimpleName(singleTypeSignature)'
Hope it helps
Andreas
kaprasi wrote:
> Hi Andreas,
> it :
> try {
> IType type =
> } else {
> Thanks.
Previous Topic:Eclipse does not detect USB Bluetooth Device
Next Topic:How to set the src folder in program to and display it in the UI when creat Java project?
Current Time: Sun Oct 26 12:33:05 EDT 2025
Powered by FUDForum. Page generated in 0.04894 seconds
