Home » Archived » Buckminster » headless update from 3.5.0 to 3.5.2
headless update from 3.5.0 to 3.5.2 [message #528426] Tue, 20 April 2010 09:31 Go to next message
I tested to do an headless update of an eclipse 3.5.0 product to Eclipse 3.5.2 via the command:
eclipsec.exe -application org.eclipse.equinox.p2.director -repository http://server/staging/galileo -installIU org.eclipse.sdk.ide -destination c:/eclipse3.5 -profile SDKprofile
this worked as it said:
Installing org.eclipse.sdk.ide 3.5.2.M20100211-1343.
Operation completed in 94046 ms.
fine! until i started it and went to help->about
and it said:
Version: 3.5.0
Build id: I20090611-1540
huh?
if i look at installation details in the tab "installation details" it says:
Eclipse SDK 3.5.2.M20100211-1343 org.eclipse.sdk.ide
if i look in the tab features it says:
Eclipse Project SDK
Version: 3.5.0.v20090423-7Q7bA7DPQ1SM6OYQ7wKYJhI-z-xZJCmLTBRhtZ0o61b1 z
and finally if i look in the configuration tab it says:
eclipse.application=org.eclipse.ui.ide.workbench
eclipse.buildId=M20100211-1343
seems something did not get right in the update? or is this something i can ignore?
Best regards
David
Re: headless update from 3.5.0 to 3.5.2 [message #528540 is a reply to message #528426] Tue, 20 April 2010 16:44 Go to previous messageGo to next message
Hi David,
I'm not sure why the update isn't reflected in the about box. It sure seems like the update did happen. I suggest you
enter a bugzilla for this (RT/Equinox/p2).
Thomas Hallgren
> and it said:
> Version: 3.5.0
> huh?
> says:
> Eclipse Project SDK
> can ignore?
> Best regards
> David
Re: headless update from 3.5.0 to 3.5.2 [message #528604 is a reply to message #528540] Wed, 21 April 2010 05:09 Go to previous message
Thanks Thomas,
https://bugs.eclipse.org/bugs/show_bug.cgi?id=309897
/Dave
Previous Topic:Unable to update a feature
Next Topic:Changes to director in buckminster?
Current Time: Fri Jul 25 10:25:46 EDT 2025
Powered by FUDForum. Page generated in 0.40374 seconds
