Home » Archived » Buckminster » weird problem with update(Buckminster Aggregator)
| weird problem with update [message #526871] |
Tue, 13 April 2010 07:20  |
There back after some nice parental leave!
I have a reoccuring problem that keeps popping up.
scenario:
We have an corporate user who have an fresh install ( Eclipse 3.5.0)
He presses the search for updates and gets notified of eclipse 3.5 SR2 from our internal updatesite which we have published with the buckminster aggregator.
install goes ok for SR2, restart and tries to install more things, it lists all the metadata about all that is on the updatesite, (probably cached from first visit) he tries to install more things but gets an "no repository found" for all of the IUs he needed.
user files an error and we have to look at it.
What happened? seems after SR2 is installed all the updatesites for SR2 is exposed in the window->preferences->install/update->available software sites. We get around 20-30 more sites directly after the install of SR2. To start we only had our own which was pre configured. Now when the user is trying to install from our internal update site it tries to go through the proxy and cannot find anything. No idea why it does this. How do i know its trying to go through the proxy? cause the only solution is to add an exception to the "proxy bypass" internal domain names which do the trick.
any tips on how i can debug this closer? i enabled tracing with
-Dorg.apache.commons.logging.Log=org.apache.commons.logging. impl.SimpleLog
-Dorg.apache.commons.logging.simplelog.showdatetime=true
-Dorg.apache.commons.logging.simplelog.log.httpclient.wire.h eader=debug
-Dorg.apache.commons.logging.simplelog.log.org.apache.common s.httpclient=debug
-Dorg.apache.commons.logging.simplelog.log.httpclient.wire=d ebug
but it writes nothing when this problem occurs telling me the problem is before it got all the way down to the http layer it seems. Sometimes this seems very random, an update in progress can be halted and and exited with it cannot find the files it needs, although they are on the update site, there is no problem with the webserver, nor the network all is internal.
no idea if this belongs here or in another place, if it does please move this or point me to where it belongs!
TIA
David
| Re: weird problem with update [message #526886 is a reply to message #526871] |
Tue, 13 April 2010 08:02   |
How did the user get the "fresh Eclipse 3.5.0"? Was it downloaded from
Eclipse, or was it created from the in-house repository you created?
If it came from Eclipse, this instance will know where the installed
components came from.
To create a clean in-house distribution that never goes outside you need
to create the distribution from the p2 site that you have aggregated and
mirrored behind your firewall.
- henrik
> scenario:
> s.httpclient=debug
> is internal.
> TIA
> David
| Re: weird problem with update [message #526902 is a reply to message #526886] |
Tue, 13 April 2010 09:06   |
The 3.5.0 is packed with some msi utility outside my control. We just give them the folder structure and they make sure to unpack it in the right spot etc.
Basically just an unzip of the zip when 3.5.0 was created with some tweaks from us, splash screen, default update site preconfigured, and an jre to go along with it.
the problem we get is this:
An error occurred while collecting items to be installed
session context was:(profile=SDKProfile, phase=org.eclipse.equinox.internal.provisional.p2.engine.pha ses.Collect, operand=, action=).
No repository found containing: osgi.bundle,se.surf.zz.ant.eclipse.gallery.plugin,3.1.3
No repository found containing: org.eclipse.update.feature,se.surf.zz.ant.eclipse.gallery.pl ugin,3.1.3
No repository found containing: osgi.bundle,se.surf.zz.ant.eclipse.workspace.plugin,3.1.0
No repository found containing: org.eclipse.update.feature,se.surf.zz.ant.eclipse.workspace. plugin,3.1.0
indicating it cannot find these on the server but they are there.
the tracing mean while spits out this multiple times:
Tue Apr 13 14:17:20 CEST 2010 - [Worker-6] AbstractProxyProvider#select result for [http://download.eclipse.org]
type: HTTP host: surf.se port: 8080 user: null password: null reqAuth: false source: WINDOWS_IE dynamic: false
Tue Apr 13 14:18:15 CEST 2010 - [Worker-0] AbstractProxyProvider#select result for [http://eclipse-update.surf.se]
Tue Apr 13 14:18:15 CEST 2010 - [Worker-0] AbstractProxyProvider#select result for [http://download.eclipse.org]
Tue Apr 13 14:18:16 CEST 2010 - [Worker-0] AbstractProxyProvider#select result for [http://download.eclipse.org]
before it finally croaks and gives this error message above. To me it looks like its trying to use the proxy, but why on an internal adress?
the internal adress is reachable trough the dns etc.
ideas?
| Re: weird problem with update [message #526923 is a reply to message #526902] |
Tue, 13 April 2010 09:49   |
ok, I still wonder how you created the Eclipse IDE that was in the
folder structure that was wrapped using MSI - did you use the director
to install it from the repository you created? If not, it will contain
links back to eclipse.org (because it will contain meta data information
from eclipse.org repositories that it will check if they are up to date,
etc.).
- henrik
> right spot etc.
> ideas?
| Re: weird problem with update [message #527166 is a reply to message #527119] |
Wed, 14 April 2010 05:50  |
Maybe someone else can come up with a better solution, but here are some
ideas...
- Create your own 3.5.0 distro and tell people to use that (it is easier
than it sounds).
- DNS, change routing so requests go to your internal site instead of
eclipse.
- Figure out exactly how to surgically clean installed 3.5.0 from
references to eclipse.org and replace with references to your site. (Not
recommended, know people that have tried this and given up).
I am not a proxy expert, so I don't know if there are any other options
available to you in that area.
- henrik
On 4/14/10 9:38 AM, David wrote:
> Henrik Lindberg wrote on Wed, 14 April 2010 09:22
>> Just removing update sites from "available sites" is not enough. You
>> have to make the initial install yourself - i.e create your own eclipse
>> distro. Don't use the zip you get from eclipse.
>> - henrik
> Right now there is no option as 3.5.0 is already out long time ago and
> we are more looking head for 3.6 so that will be then.
> For this particular problem we got with the update right now there is no
> way out?
> Basically everyone has to add the exception to the proxy and go from there?
> -Dave
Current Time: Sat Nov 01 03:02:36 EDT 2025
Powered by FUDForum. Page generated in 0.25926 seconds
