| Autoboxing and Nullpointer [message #524083] |
Tue, 30 March 2010 11:44  |
could someone please explain me, why the following snippet produces a NullPointerException:
public class Main {
System.out.println(getDouble());
Double d1 = true ? getDouble() : new Double(0);
System.out.println(d1);
Double d2 = true ? getDouble() : 0;
System.out.println(d2);
public static Double getDouble() {
return null;
The output is:
null
null
Exception in thread "main" java.lang.NullPointerException
at Main.main(Main.java:9)
Apparently it has to do with autoboxing, but is this the right behaviour?
I'm using Eclipse Galileo for RCP/Plug-in Developers, Build id: 20090920-1017
Thank you in advance,
Rudi
| Re: Autoboxing and Nullpointer [message #524320 is a reply to message #524083] |
Wed, 31 March 2010 05:26  |
On 3/30/2010 9:44 AM, Rudi wrote:
> Hello,
> public class Main {
> public static void main(String[] args) {
> return null;
> The output is:
> null
> null
> 20090920-1017
> Rudi
While the ternary operator in Java has understandable problems for which
I lodge no particular complaint (despite being an old C guy who uses
this construct copiously), in this case, it's the null returned from
getDouble() that leads to the exception and not the ternary operation's
innate grumpiness, no?
Russ
FUDForum. Page generated in 0.09553 seconds
