populate target platform [message #522327] |
Mon, 22 March 2010 07:25  |
I use a buckminster headless "import" command (pointing to a mspec) in
order to populate my target platform.
Now I want to add a prebuild 3rd party feature to my target platform.
How do I do that?
I tried several approaches whitout success:
1. add the 3rd party feature to the rmap that will be used by the mspec
while the "import" is taking place. But I couldn't figure out, how to
add a provider to the rmap for a prebuild 3rd party feature
2. I try to add a second "import" command, but you can only reference to
mspec files. But how to make a mspec if I only have the prebuild
feature in a zip file? - Without p2 update site?
Any ideas?
Kind regards, Alain.
Re: populate target platform [message #522395 is a reply to message #522355] |
Mon, 22 March 2010 10:34   |
The simplest fix for that is then probably to add a site.xml file so that you get a legacy style update site, i.e.
albireo/site.xml
albireo/features
albireo/plugins
and then use the 'p2' reader type (or 'eclipse.import' in 3.5) in conjunction with URL using the file protocol.
HTH,
- thomas
On 03/22/2010 02:24 PM, Alain Helfenstein wrote:
> Hi Thomas
> Thanks for your answer.
> No, they are not available on a update site.
> They just resides on my harddisk as a folder with the following structure:
> albireo/features
> albireo/plugins
> Regards, Alain.
> Thomas Hallgren schrieb:
>> Hi Alain,
>> Your feature holds references to other features and/or plugins. Where
>> do they reside in relation to the feature? Are they available on an
>> update site (legacy or p2) ?
>> - thomas
>> On 03/22/2010 12:25 PM, Alain Helfenstein wrote:
>>> Hi
>>> How do I do that?
>>> mspec files. But how to make a mspec if I only have the prebuild feature
>>> Any ideas?
Re: populate target platform [message #524599 is a reply to message #522395] |
Thu, 01 April 2010 10:47  |
Hi Thomas
It worked on my local machine whitout any problems. I think the site.xml
is even not needen.
But on the build server I get the following error (havin the site.xml in
the folder):
ERROR [0002] : Unable to resolve Installable Unit
org.eclipse.albireo.core 0.0.3.v20081031 in repository
file:///D:/test/test/data/albireo
ERROR: Unable to resolve Installable Unit org.eclipse.albireo.core
0.0.3.v20081031 in repository file:///D:/test/test/data/albireo
ERROR: Errors and Warnings
org.eclipse.core.runtime.CoreException: Errors and Warnings
at
org.eclipse.buckminster.runtime.BuckminsterException.wrap(Bu ckminsterException.java:109)
at
org.eclipse.buckminster.core.materializer.MaterializationJob .internalRun(MaterializationJob.java:175)
at
org.eclipse.buckminster.core.materializer.MaterializationJob .run(MaterializationJob.java:144)
Contains: [0002] : Unable to resolve Installable Unit
The file really exists, because if I remove the file, then another error
message will be displayed.
The rmap looks like this:
<searchPath name="albireo">
<provider readerType="eclipse.import"
componentTypes="osgi.bundle,eclipse.feature" mutable="false" source="false">
<uri format="file:///D:/test/test/data/albireo"/>
</provider>
</searchPath>
And the site.xml looks like this:
<site>
<feature url="features/org.eclipse.albireo_0.0.3.v20081031.jar"
id="org.eclipse.albireo" version="0.0.3.v20081031">
<category name="albireo"/>
</feature>
<feature url="features/org.eclipse.albireo.sdk_0.0.3.v20081031.jar"
id="org.eclipse.albireo.sdk" version="0.0.3.v20081031">
</feature>
<feature
url="features/org.eclipse.albireo.source_0.0.3.v20081031.jar "
id="org.eclipse.albireo.source" version="0.0.3.v20081031">
</feature>
<category-def name="albireo" label="albireo">
<description>
albireo
</description>
</category-def>
</site>
Any idea about this?
Thanks a lot for your help, Alain.
> albireo/site.xml
> albireo/features
> albireo/plugins
> HTH,
> - thomas
>> Hi Thomas
>> structure:
>> albireo/features
>> albireo/plugins
>> Regards, Alain.
>>> Hi Alain,
>>> - thomas
>>>> Hi
>>>> How do I do that?
>>>> reference to
>>>> feature
>>>> Any ideas?
FUDForum. Page generated in 0.07893 seconds
