Home » Archived » Buckminster » solving java.lang.OutOfMemoryError: "Java heap space"
solving java.lang.OutOfMemoryError: "Java heap space" [message #521177] Tue, 16 March 2010 12:19 Go to next message
Today I encountered a Java heap space problem, just want to share the solution.
I kept on getting "java.lang.OutOfMemoryError: Java heap space" in my free style job (running buckminster build command).
So I added -Xms1024m to my hudson startup call:
java -Xms1024m hudson.war
Still the same problem. After messing around with all those vm arguments -Xms512m -Xmx512m -XX:PermSize=512m -XX:MaxPermSize=512m I saw in my task manager that there is another java task running.
Buckminster is running in its own JVM, which totally makes sense. I was hacking around at the wrong place.
So to solve this issue, open your free style job and add -Xmx1024m to "Run Buckminster" => "Advanced Options" => "JVM Argumente"
Problem solved...
Re: solving java.lang.OutOfMemoryError: "Java heap space" [message #521200 is a reply to message #521177] Tue, 16 March 2010 13:29 Go to previous messageGo to next message
If you don't mind, could you log this as a documentation issue for
Buckminster ("troubleshooting tip Hudson out of memory")?
- henrik
> solution.
> Problem solved...
Re: solving java.lang.OutOfMemoryError: "Java heap space" [message #521235 is a reply to message #521177] Tue, 16 March 2010 16:57 Go to previous messageGo to next message
yes sure, what do you mean by "log this as a documentation issue"?
Rename this thread to "Buckminster ("troubleshooting tip Hudson out of memory")"?
greets
flavio
Re: solving java.lang.OutOfMemoryError: "Java heap space" [message #521249 is a reply to message #521235] Tue, 16 March 2010 17:32 Go to previous messageGo to next message
I mean log an issue/bug in eclipse bugzilla for
tools->buckminster->documentation.
- henrik
> memory")"?
> greets
> flavio
Re: solving java.lang.OutOfMemoryError: "Java heap space" [message #521253 is a reply to message #521249] Tue, 16 March 2010 18:36 Go to previous messageGo to next message
done that: https://bugs.eclipse.org/bugs/show_bug.cgi?id=306102
Re: solving java.lang.OutOfMemoryError: "Java heap space" [message #521308 is a reply to message #521177] Tue, 16 March 2010 23:52 Go to previous messageGo to next message
Hi Flavio,
just a little hint in case you didn't find that yourself yet:
Am 16.03.2010 17:19, schrieb Flavio Donzé:
> Problem solved...
You can also set VM arguments globally for the buckminster installation
instead of redefining them for each build job.
To do so, navigate to the 'configure hudson' page, go the Buckminster
section and enter e.g "-Xmx1024m" as additional startup parameter for
the selected buckminster installation.
Johannes
Re: solving java.lang.OutOfMemoryError: "Java heap space" [message #521340 is a reply to message #521308] Wed, 17 March 2010 06:34 Go to previous messageGo to next message
Johannesburg could you add that to the doc issue so I don't forget
- henrik
Johannes Utzig <mail@jutzig.de> wrote:
> Hi Flavio,
> > to
> > Problem solved...
> installation instead of redefining them for each build job.
> Best regards,
> Johannes
- henrik
Re: solving java.lang.OutOfMemoryError: "Java heap space" [message #521371 is a reply to message #521340] Wed, 17 March 2010 09:00 Go to previous messageGo to next message
Hi Henrik
Am 17.03.2010 11:34, schrieb Henrik Lindberg:
> - henrik
> Johannes Utzig<mail@jutzig.de> wrote:
Johannesburg? :P :)
I added a comment for the issue.
Johannes
Re: solving java.lang.OutOfMemoryError: "Java heap space" [message #521562 is a reply to message #521371] Wed, 17 March 2010 18:24 Go to previous message
IPhone autocorrect.... what can I say :)
....except sorry...
- henrik
On 3/17/10 2:00 PM, Johannes Utzig wrote:
> Hi Henrik
>> - henrik
> Johannesburg? :P :)
> Best regards,
> Johannes
Previous Topic:Update Authorized CI problem
Next Topic:error when accessing galileo update site with aggregator
Current Time: Mon Jun 16 10:33:42 EDT 2025
Powered by FUDForum. Page generated in 0.13413 seconds
