Home » Archived » Buckminster » Buckminster fails to find bundles
Buckminster fails to find bundles [message #520344] Thu, 11 March 2010 21:50 Go to next message
During my build Buckminster fails to find some bundles which are pretty much the same in nature as other bundles that have been successfully located. I even created a word by word locator just to find these bundles, but nothing helps. This is the error I am getting:
org.apache.log4j:eclipse.feature/[1.2.14.v200701080905,1.2.1 4.v200701080905]: No provider was found that could resolve the request
ERROR [0000] : No suitable provider for component org.apache.log4j:eclipse.feature/[1.2.14.v200701080905,1.2.1 4.v200701080905] was found in resourceMap file:/home/akravets2/.hudson/jobs/buckminster.job/workspace/ totaltrader/build/com.totaltrader.site/site.rmap
ERROR [0000] : No suitable provider for component org.apache.log4j:eclipse.feature/[1.2.14.v200701080905,1.2.1 4.v200701080905] was found in searchPath totaltrader
ERROR [0000] : Resolution attempt ended with exception: Provider local( file:///home/akravets2/.hudson/jobs/buckminster.job/workspac e/totaltrader/org.apache.log4j): Missing CSpec source required by component type eclipse.feature
ERROR Provider local( file:///home/akravets2/.hudson/jobs/buckminster.job/workspac e/totaltrader/org.apache.log4j): Missing CSpec source required by component type eclipse.feature
org.apache.commons:eclipse.feature/[1.0.0.v200701071427,1.0. 0.v200701071427]: No provider was found that could resolve the request
ERROR [0000] : No suitable provider for component org.apache.commons:eclipse.feature/[1.0.0.v200701071427,1.0. 0.v200701071427] was found in resourceMap file:/home/akravets2/.hudson/jobs/buckminster.job/workspace/ totaltrader/build/com.totaltrader.site/site.rmap
ERROR [0000] : No suitable provider for component org.apache.commons:eclipse.feature/[1.0.0.v200701071427,1.0. 0.v200701071427] was found in searchPath totaltrader
ERROR [0000] : Resolution attempt ended with exception: Provider local( file:///home/akravets2/.hudson/jobs/buckminster.job/workspac e/totaltrader/org.apache.commons): Missing CSpec source required by component type eclipse.feature
ERROR Provider local( file:///home/akravets2/.hudson/jobs/buckminster.job/workspac e/totaltrader/org.apache.commons): Missing CSpec source required by component type eclipse.feature
What is the nature of this error?
Also, how does Buckminster decide what is the eclipse.feature and osgi.bundle. I have two similar bundles org.jdom and or.apache.log4j, first is treated as bundle and second as feature.
thanks,
Alex
[Updated on: Thu, 11 March 2010 21:56] by Moderator
Re: Buckminster fails to find bundles [message #520406 is a reply to message #520344] Thu, 11 March 2010 23:58 Go to previous messageGo to next message
Hi Alex,
From the looks of it, the resolver isn't trying to find bundles. It's looking for features. It fails because it doesn't
find the feature.xml at the specified locations.
HTH,
- thomas
On 03/12/2010 03:50 AM, Alex wrote:
> Hello,
> Quote:
> thanks,
> Alex
Re: Buckminster fails to find bundles [message #520407 is a reply to message #520344] Thu, 11 March 2010 23:58 Go to previous messageGo to next message
Hi Alex,
It looks to me like the component type is wrong. The error message says:
org.apache.log4j:eclipse.feature/...: No provider was found
I think that there is no feature for org.apache.log4j, only a bundle. The
same applies to the other artifacts that cannot be resolved. Can you check
your dependencies?
Achim
Alex wrote:
> Hello,
> but nothing helps. This is the error I am getting: Quote:
> thanks,
> Alex
Re: Buckminster fails to find bundles [message #520501 is a reply to message #520407] Fri, 12 March 2010 11:13 Go to previous messageGo to next message
Thanks Thomas and Achim,
Yeah, that's what I thought, but wasn't sure completely.
thanks,
Alex
[Updated on: Fri, 12 March 2010 13:26] by Moderator
Re: Buckminster fails to find bundles [message #520549 is a reply to message #520501] Fri, 12 March 2010 09:22 Go to previous messageGo to next message
Hi Alex,
The log4j bundle itself is ok. It's rather the component that references it
seems to look for a *feature* named org.apache.log4j, rather than a bundle.
Do you have a CSPEC somewhere that depends on org.apache.log4j?
Achim
> May be you can take a look at my manifest to see what's wrong?
> Manifest-Version: 1.0
> Bundle-ManifestVersion: 2
> Bundle-Name: %pluginName
> Bundle-SymbolicName: org.apache.log4j
> Bundle-Version: 1.2.14.v200701080905
> Bundle-Vendor: %providerName
> Bundle-Localization: plugin
> Export-Package: org.apache.log4j;version="1.2.14",
> org.apache.log4j.chainsaw;version="1.2.14",
> org.apache.log4j.config;version="1.2.14",
> org.apache.log4j.helpers;version="1.2.14",
> org.apache.log4j.jdbc;version="1.2.14",
> org.apache.log4j.jmx;version="1.2.14",
> org.apache.log4j.lf5;version="1.2.14",
> org.apache.log4j.lf5.util;version="1.2.14",
> org.apache.log4j.lf5.viewer;version="1.2.14",
> org.apache.log4j.lf5.viewer.categoryexplorer;version="1.2.14 ",
> org.apache.log4j.lf5.viewer.configure;version="1.2.14",
> org.apache.log4j.net;version="1.2.14",
> org.apache.log4j.nt;version="1.2.14",
> org.apache.log4j.or;version="1.2.14",
> org.apache.log4j.or.jms;version="1.2.14",
> org.apache.log4j.or.sax;version="1.2.14",
> org.apache.log4j.spi;version="1.2.14",
> org.apache.log4j.varia;version="1.2.14",
> org.apache.log4j.xml;version="1.2.14"
> Bundle-ClassPath: log4j-1.2.14.jar
> Bundle-RequiredExecutionEnvironment: J2SE-1.4
> thanks,
> Alex
Re: Buckminster fails to find bundles [message #520553 is a reply to message #520344] Fri, 12 March 2010 14:31 Go to previous message
Hi Achim,
Yes, that was exactly the problem, and after fixing it everything worked perfectly. Buckminster rocks!
thanks for your help!
Alex
Previous Topic:Buckminster and fragments and unit tests
Next Topic:buckminster headless subversive support not working
Current Time: Sat Jul 26 02:53:33 EDT 2025
Powered by FUDForum. Page generated in 0.04945 seconds
