Home » Archived » Buckminster » Headless 3.6 installation not working
Headless 3.6 installation not working [message #518661] Thu, 04 March 2010 12:23 Go to next message
I'm trying to do a headless installation (this time not behind a proxy) of 3.6.
Following the book I first did:
./director -r http://download.eclipse.org/tools/buckminster/headless-3.6 -d ../buckminster -p buckminster -i org.eclipse.buckminster.cmdline.product
Installing org.eclipse.buckminster.cmdline.product 1.2.0.r11245.
which worked fine
then I tried
./buckminster install http://download.eclipse.org/tools/buckminster/headless-3.6  org.eclipse.buckminster.core.headless.feature
which fails with
An error occurred while installing the items
[0]session context was:(profile=buckminster, phase=org.eclipse.equinox.internal.p2.engine.phases.Install, operand=null --> [R]com.ibm.icu.base 4.2.1.v20100112, action=org.eclipse.equinox.internal.p2.touchpoint.eclipse.actions.InstallBundleAction).
[0]Error while loading manipulator.
Did I do something wrong or should I report this as a bug?
Re: Headless 3.6 installation not working [message #518698 is a reply to message #518661] Thu, 04 March 2010 09:12 Go to previous messageGo to next message
Hi Patrick,
p2 doesn't like relative paths for the "-d" argument. Using an absolute path
should work.
Achim
> 3.6.
> which worked fine
> then I tried
> which fails with
> [phase=org.eclipse.equinox.internal.p2.engine.phases.Install , operand=null
> [--> [R]com.ibm.icu.base 4.2.1.v20100112,
[action=org.eclipse.equinox.internal.p2.touchpoint.eclipse.a ctions.InstallBundleAction).
Re: Headless 3.6 installation not working [message #518705 is a reply to message #518661] Thu, 04 March 2010 14:27 Go to previous messageGo to next message
Thank you very much, that was exactly the problem.
Now I'm stuck at trying to install svn support
./director -r http://download.cloudsmith.com/buckminster/external/ -d /home/build/bin/buckminster/buckminster -p Buckminster -i org.eclipse.buckminster.subversive
results in
Installing org.eclipse.buckminster.subversive 1.0.0.r10908.
Cannot complete the install because one or more required items could not be found.
 Software being installed: Buckminster Subversive Support Plug-in 1.0.0.r10908 (org.eclipse.buckminster.subversive 1.0.0.r10908)
 Missing requirement: Subversive SVN Team Provider Core Plug-in (Incubation) 0.7.8.I20090904-1300 (org.eclipse.team.svn.core 0.7.8.I20090904-1300) requires 'bundle org.eclipse.core.resources 0.0.0' but it could not be found
 Cannot satisfy dependency:
  From: Buckminster Subversive Support Plug-in 1.0.0.r10908 (org.eclipse.buckminster.subversive 1.0.0.r10908)
  To: bundle org.eclipse.team.svn.core 0.7.7
Application failed, log file location: /home/build/bin/buckminster/director/configuration/1267730715389.log
Re: Headless 3.6 installation not working [message #518714 is a reply to message #518705] Thu, 04 March 2010 14:30 Go to previous messageGo to next message
Hi Patrick,
A while back we were forced to split the external update site in two due to API differences. So you have to use:
http://download.cloudsmith.com/buckminster/external-3.6/
in conjunction with other 3.6 stuff.
HTH,
- thomas
> results in
> be found.
> /home/build/bin/buckminster/director/configuration/126773071 5389.log
Re: Headless 3.6 installation not working [message #518742 is a reply to message #518661] Thu, 04 March 2010 16:07 Go to previous messageGo to next message
This doesn't seem to work
./director -r http://download.cloudsmith.com/buckminster/external-3.6/ -d /home/build/bin/buckminster/buckminster -p Buckminster -i org.eclipse.buckminster.subversive
results in
Installing org.eclipse.buckminster.subversive 1.0.0.r11210.
 Software being installed: Buckminster Subversive Support Plug-in 1.0.0.r11210 (org.eclipse.buckminster.subversive 1.0.0.r11210)
 Missing requirement: Buckminster Subversive Support Plug-in 1.0.0.r11210 (org.eclipse.buckminster.subversive 1.0.0.r11210) requires 'bundle org.eclipse.buckminster.core 1.1.340' but it could not be found
Application failed, log file location: /home/build/bin/buckminster/director/configuration/1267736735689.log
From the files in the plugin directory it looks like
org.eclipse.buckminster.core_1.2.360.r11245.jar
is installed, so it looks like subversive plugin depends on an old version of the core.
[Updated on: Thu, 04 March 2010 16:09] by Moderator
Re: Headless 3.6 installation not working [message #518748 is a reply to message #518742] Thu, 04 March 2010 16:24 Go to previous messageGo to next message
HI Patrick,
I'll look into that. Meanwhile, I suggest you try subclipse.
Thomas Hallgren
> results in
> be found.
> /home/build/bin/buckminster/director/configuration/126773673 5689.log
Re: Headless 3.6 installation not working [message #518759 is a reply to message #518748] Thu, 04 March 2010 17:30 Go to previous messageGo to next message
Thanks for your help, subclipse seems to have the same issue
Installing org.eclipse.buckminster.subclipse 1.0.0.r11210.
 Software being installed: Buckminster Subclipse Support Plug-in 1.0.0.r11210 (org.eclipse.buckminster.subclipse 1.0.0.r11210)
 Missing requirement: Buckminster Subclipse Support Plug-in 1.0.0.r11210 (org.eclipse.buckminster.subclipse 1.0.0.r11210) requires 'bundle org.eclipse.buckminster.core 1.1.340' but it could not be found
Application failed, log file location: /home/build/bin/buckminster/director/configuration/1267741714465.log
Re: Headless 3.6 installation not working [message #518769 is a reply to message #518759] Thu, 04 March 2010 13:10 Go to previous messageGo to next message
> be found.
> /home/build/bin/buckminster/director/configuration/126774171 4465.log
Do you have the org.eclipse.buckminster.core.headless.feature installed?
- thomas
Re: Headless 3.6 installation not working [message #518772 is a reply to message #518661] Thu, 04 March 2010 18:12 Go to previous messageGo to next message
Yes, the problem seems to be a version. I already edit my top post but I guess if you read this via mail/newsboard you didn't get the changes
Re: Headless 3.6 installation not working [message #518783 is a reply to message #518772] Thu, 04 March 2010 13:46 Go to previous messageGo to next message
No, that dependency is a >= 1.1.340 so that's not the problem. Something must be amiss with your installation of the
core feature. I have no problem using the headless subclipse feature.
- thomas
Re: Headless 3.6 installation not working [message #518814 is a reply to message #518661] Fri, 05 March 2010 02:42 Go to previous messageGo to next message
I found the problem. In the book it says
... -p Buckminster ...
but it actually needs to be
... -p buckminster ...
Re: Headless 3.6 installation not working [message #518817 is a reply to message #518661] Fri, 05 March 2010 02:50 Go to previous messageGo to next message
Or to be completely correct, it has to be the same used in the first call from the directory, so that the same profile is used.
The subversive plugin works now as well, thanks again for your big help.
Re: Headless 3.6 installation not working [message #518844 is a reply to message #518814] Fri, 05 March 2010 04:36 Go to previous messageGo to next message
Can you please log an issue for buckminster documentation, and indicate
where the -p Buckminster is...
- henrik
- henrik
Re: Headless 3.6 installation not working [message #518862 is a reply to message #518844] Fri, 05 March 2010 05:25 Go to previous messageGo to next message
I checked again, and it looks like it is consistent throughout all places, both the download page and the book use Buckminster everywhere.
Re: Headless 3.6 installation not working [message #518888 is a reply to message #518862] Fri, 05 March 2010 01:42 Go to previous messageGo to next message
So, are you saying that there is no issue with documentation?
- henrik
> everywhere.
- henrik
Re: Headless 3.6 installation not working [message #518902 is a reply to message #518661] Fri, 05 March 2010 07:07 Go to previous message
Yes, the documentation is ok and correct.
Previous Topic:Building for Windows on Linux
Next Topic:Headless SVN not working with 3.6?
Current Time: Sun Jul 27 08:05:24 EDT 2025
Powered by FUDForum. Page generated in 0.05780 seconds
