Home » Eclipse Projects » Buckminster dev » eclemma version
eclemma version [message #518138] Tue, 02 March 2010 23:04 Go to next message
Our org.eclipse.buckminster.emma bundle has dependency constraint on eclemma.core that prevents it from using the latest
1.4.3. Is that deliberate (IP related) or is it for other reasons?
If it's IP related, is it time for a new CQ?
Thomas Hallgren
Re: eclemma version [message #518338 is a reply to message #518138] Wed, 03 March 2010 15:23 Go to previous messageGo to next message
That's IP related. I though "Better safe than sorry," so I restricted the
version to the one that has been approved. Given that there's only been one
fix in 1.4.3 [1] I'm not sure if we should push for a new CQ. Let's not
waste the precious IP resources at the foundation and wait until there's
either
a) significant benefit in upgrading to a new version
b) a serious bugfix that we need to pass on to our users.
Achim
[1] http://www.eclemma.org/changes.html
> eclemma.core that prevents it from using the latest 1.4.3. Is that
> Regards,
> Thomas Hallgren
Re: eclemma version [message #518371 is a reply to message #518338] Wed, 03 March 2010 12:28 Go to previous messageGo to next message
Hi Achim,
I think that might be a tad to restrictive. The IP controls what we can deliver from our update site but that doesn't
mean that we must restrict the version range. I think we can control that using the releng cquery.
If eclemma uses version semantics similar to ours (API remains stable unless major or minor number changes), then I
suggest we use the range [1.4.0,1.5.0) to avoid conflicts as much as possible.
My concern is that we don't provide the full eclemma from our update site. If someone installs eclemma with ui and all
into their IDE, they will get 1.4.3. Subsequent attempts to install Buckminster will then fail (as I just experienced).
> either
> Cheers,
> Achim
I agree that this fix doesn't motivate a new CQ.
- thomas
Re: eclemma version [message #518692 is a reply to message #518371] Thu, 04 March 2010 13:37 Go to previous message
Hi Thomas,
Okay, I was under the impression that this dependency declaration also
controls what we're providing in our p2 repo. If you can make sure that we
don't violate IP by erroneously including 1.4.3 in our repo, please feel
free to adjust the dependency declaration to [1.4.2,1.5.0). Even
[1.4.2,2.0.0) should work.
Achim
> Hi Achim,
> deliver from our update site but that doesn't mean that we must restrict
> unless major or minor number changes), then I suggest we use the range
> If someone installs eclemma with ui and all into their IDE, they will get
> just experienced).
>> either
>> Cheers,
>> Achim
> - thomas
Previous Topic:Re: [buckminster-dev] Downloading source jars
Next Topic:[buckminster-dev] Project meta data is out of date for tools.buckminster
Current Time: Sat Jul 19 13:19:20 EDT 2025
Powered by FUDForum. Page generated in 0.05147 seconds
