Home » Archived » OHF » Submit document failure using the OHF
Submit document failure using the OHF [message #516276] Tue, 23 February 2010 08:32 Go to next message
Hi !
I'm trying to submit a document on a repository using OHF, but I have the following error :
org.eclipse.ohf.ihe.common.ws.OHFSOAPException: Error Sending SOAP Message  [Caused by java.net.SocketException: Socket retries exhausted.]
        at org.eclipse.ohf.ihe.common.ws.AbstractOHFSOAPSender.executeSend(AbstractOHFSOAPSender.java:253)
        at org.eclipse.ohf.ihe.common.ws.AbstractOHFSOAPSender.send(AbstractOHFSOAPSender.java:363)
        at org.eclipse.ohf.ihe.common.ws.AbstractOHFSOAPSender.send(AbstractOHFSOAPSender.java:384)
        at org.eclipse.ohf.ihe.xds.soap.AbstractXDSSoapClient.send(AbstractXDSSoapClient.java:148)
        at org.eclipse.ohf.ihe.xds.source.B_Source.submit(B_Source.java:166)
        at testohf.MyXDSManager.putDocument(MyXDSManager.java:104)
        at testohf.Main.main(Main.java:28)
Caused by: java.net.SocketException: Socket retries exhausted.
        at org.eclipse.ohf.ihe.atna.transport.TransporterImpl.createSocket(TransporterImpl.java:306)
        at org.eclipse.ohf.ihe.atna.transport.TransporterImpl.getSocket(TransporterImpl.java:100)
        at org.eclipse.ohf.ihe.atna.agent.AtnaAgent.getSocket(AtnaAgent.java:223)
        at org.eclipse.ohf.ihe.common.ws.AbstractOHFSOAPSender.configureTransportProtocol(AbstractOHFSOAPSender.java:195)
        at org.eclipse.ohf.ihe.common.ws.AbstractOHFSOAPSender.executeSend(AbstractOHFSOAPSender.java:228)
        ... 6 more
Here is my code :
            // création de l'objet transaction qui servira par la suite
            SubmitTransactionData txnData = new SubmitTransactionData();
            // création du document CDA à partir de l'url du fichier
            Document clinicalDocument = new Document(urlDocument, DocumentDescriptor.CDA_R2);
            // ajout du document ainsi créé à la transaction
            String docEntryUUID = txnData.addDocument(clinicalDocument);
            // récupération d'une partie des metadonnées du document pour les compléter
            DocumentEntryType docEntry = txnData.getDocumentEntry(docEntryUUID);
            // ajout de métadonnées concernant l'identifiant du patient
            CX patientId = Hl7v2Factory.eINSTANCE.createCX();
            patientId.setIdNumber(patientIdNumber);
            patientId.setAssigningAuthorityUniversalId("1.3.6.1.4.1.21367.2005.1.1");
            patientId.setAssigningAuthorityUniversalIdType("ISO");
            docEntry.setPatientId(patientId);
            // récupération d'une autre partie des métadonnées du document pour les compléter
            SubmissionSetType subset = txnData.getSubmissionSet();
            CodedMetadataType contentTypeCode = MetadataFactory.eINSTANCE.createCodedMetadataType();
            contentTypeCode.setCode("Consult");
            // contentTypeCode.setDisplayName("Consult");
            subset.setContentTypeCode(contentTypeCode);
            // définition de l'url du repository dans lequel on va envoyer le document
            URI repositoryUri = URI.create(repositoryUrl);
            B_Source source = new B_Source(repositoryUri);
            AtnaAgentFactory.getAtnaAgent().setAuditRepository(repositoryUri);
            // définition du proxy
            System.setProperty("http.proxySet", "true");
            System.setProperty("http.proxyHost", proxyHost);
            System.setProperty("http.proxyPort", proxyPort);
            // identification de l'auteur de la requête
            AtnaAgentFactory.getAtnaAgent().setInitiatingUser(putDocumentInitiatingUser);
            // exécution de la requête pour envoyer le document vers le repository
            XDSResponseType xdsresponsetype = source.submit(txnData);
            System.out.println("xdsresponsetype : " + xdsresponsetype);
        } catch (MetadataExtractionException ex) {
            Logger.getLogger(Main.class.getName()).log(Level.SEVERE, null, ex);
        } catch (SubmitTransactionCompositionException ex) {
        } catch (FileNotFoundException ex) {
        } catch (IOException ex) {
        } catch (OHFSOAPException ex) {
            Logger.getLogger(MyXDSManager.class.getName()).log(Level.SEVERE, null, ex);
        } catch (Exception ex) {
Does someone know what I did wrong ?
Thanks for your help ...
Re: Submit document failure using the OHF [message #517982 is a reply to message #516276] Tue, 02 March 2010 11:20 Go to previous messageGo to next message
For information, OHF has been replaced by OHT ... I asked the same question on the OHT forum :
https://iheprofiles.projects.openhealthtools.org/ds/viewMess age.do?dsForumId=212&dsMessageId=14122
Re: Submit document failure using the OHF [message #588339 is a reply to message #516276] Tue, 02 March 2010 11:20 Go to previous message
Previous Topic:Sample creating a CDA r2 message
Next Topic:Eclipse UOMo
Current Time: Thu Jul 24 23:28:52 EDT 2025
Powered by FUDForum. Page generated in 0.08456 seconds
