Home » Archived » Buckminster » How to prevent: JRE container on the classpath is not a perfect match to the 'J2SE-1.5'
How to prevent: JRE container on the classpath is not a perfect match to the 'J2SE-1.5' [message #514858] Tue, 16 February 2010 16:51 Go to next message
I run the build on hudson on build.eclipse.org. I see these warnings:
[java] Warning: file
/opt/users/hudsonbuild/.hudson/jobs/emf-teneo-nightly/worksp ace/build/build/workspace/plugins/org.eclipse.emf.teneo.anno tations/META-INF/MANIFEST.MF,
line 9: The JRE container on the classpath is not a perfect match to the 'J2SE-1.5' execution environment
In the configuration of the build I have set java 5.0 jdk. I have a feeling that it has something to do with the setting
in the workspace. What did you do with the buckminster build to solve/prevent this?
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Cell: +31 (0)6 288 48 943
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Re: How to prevent: JRE container on the classpath is not a perfect match to the 'J2SE-1.5' [message #514874 is a reply to message #514858] Tue, 16 February 2010 18:27 Go to previous messageGo to next message
On 02/16/2010 10:51 PM, Martin Taal wrote:
> feeling that it has something to do with the setting in the workspace.
We install the needed JRE in our workspace prior to building. In the ant build.xml that drives our build, you'll find this:
<buckminster command="installJRE">
<cmdargs>
<arg value="--location" />
<arg value="${jdk1.4.dir}" />
</cmdargs>
</buckminster>
The ${jdk1.4.dir} is the absolute path of the JRE. You can install any number of JRE's this way.
Thomas Hallgren
Re: How to prevent: JRE container on the classpath is not a perfect match to the 'J2SE-1.5' [message #515021 is a reply to message #514874] Wed, 17 February 2010 08:36 Go to previous messageGo to next message
Hi Thomas,
I am still getting this exception. I have this in the log (when running in debug mode):
[echo] Using workspace /opt/users/hudsonbuild/.hudson/jobs/emf-teneo-nightly/worksp ace/build/build/workspace
[echo] Setting jre to /shared/common/ibm-java2-ppc-50
[java] installJRE '-P' '/tmp/build-709667201.properties' '--location' '/shared/common/ibm-java2-ppc-50'
[java] Downloading file:/tmp/build-709667201.properties
[java] Doing full workspace refresh
[java] Waiting for jobs to end
This is part of the build script:
<echo message="Setting jre to ${env.JAVA_HOME}"/>
<buckminster command="installJRE" workspace="${workspacePath}">
<cmdargs>
<arg value="${env.JAVA_HOME}" />
</cmdargs>
</buckminster>
I do this before setting the target path, is that correct?
Does the 'doing full workspace refresh' have any influence on this?
See here for the complete log:
https://build.eclipse.org/hudson/job/emf-teneo-nightly/76/co nsoleFull
gr. Martin
>> Hi,
> <cmdargs>
> </cmdargs>
> </buckminster>
> Regards,
> Thomas Hallgren
The Netherlands
Re: How to prevent: JRE container on the classpath is not a perfect match to the 'J2SE-1.5' [message #515022 is a reply to message #515021] Wed, 17 February 2010 08:37 Go to previous messageGo to next message
To be more precise in my wording :-), it is not an exception but a warning ofcourse.
gr. Martin
Martin Taal wrote:
> Hi Thomas,
> in debug mode):
> <cmdargs>
> </cmdargs>
> </buckminster>
> gr. Martin
>>> Hi,
>> <cmdargs>
>> </cmdargs>
>> </buckminster>
>> Regards,
>> Thomas Hallgren
The Netherlands
Re: How to prevent: JRE container on the classpath is not a perfect match to the 'J2SE-1.5' [message #515085 is a reply to message #515021] Wed, 17 February 2010 11:40 Go to previous messageGo to next message
Hi Martin,
Perhaps you need to update the classpath for the project in question (the button just below where you add EE's in the
PDE manifest editor).
The "doing full workspace refresh" is not related. It's just an information that Buckminster ensures that your workspace
is in sync with the file system prior to exit.
- thomas
On 02/17/2010 02:36 PM, Martin Taal wrote:
> Hi Thomas,
> in debug mode):
> <cmdargs>
> </cmdargs>
> </buckminster>
> gr. Martin
>>> Hi,
>> <cmdargs>
>> </cmdargs>
>> </buckminster>
>> Regards,
>> Thomas Hallgren
Re: How to prevent: JRE container on the classpath is not a perfect match to the 'J2SE-1.5' [message #515145 is a reply to message #515085] Wed, 17 February 2010 16:24 Go to previous messageGo to next message
Thanks Thomas, this indeed solved it!
gr. Martin
> Hi Martin,
> (the button just below where you add EE's in the PDE manifest editor).
> information that Buckminster ensures that your workspace is in sync with
> - thomas
>> Hi Thomas,
>> in debug mode):
>> <cmdargs>
>> </cmdargs>
>> </buckminster>
>> gr. Martin
>>>> Hi,
>>>> the
>>> <cmdargs>
>>> </cmdargs>
>>> </buckminster>
>>> Regards,
>>> Thomas Hallgren
The Netherlands
Re: How to prevent: JRE container on the classpath is not a perfect match to the 'J2SE-1.5' [message #515528 is a reply to message #514874] Fri, 19 February 2010 04:29 Go to previous message
>> Hi,
> <cmdargs>
> </cmdargs>
> </buckminster>
Is installJRE supposed to support IBM's j9 as well? If I try to set it
to j9 it results with an exception.
ecf2:/opt/toolbox/eclipse.org/buckminster/r11191 # ./buckminster
installJRE --location /opt/toolbox/ibm.com/j9/j9_6.1.1.20061110-161633/
ERROR: Exception occurred executing command line.
org.eclipse.core.runtime.CoreException: Exception occurred executing
command line.
at org.eclipse.debug.core.DebugPlugin.exec(DebugPlugin.java:814 )
at
org.eclipse.jdt.internal.launching.StandardVMType.generateLi braryInfo(StandardVMType.java:500)
at
org.eclipse.jdt.internal.launching.StandardVMType.getLibrary Info(StandardVMType.java:122)
at
org.eclipse.jdt.internal.launching.StandardVMType.getDefault LibraryLocations(StandardVMType.java:290)
at
org.eclipse.jdt.internal.launching.StandardVMType.canDetectD efaultSystemLibraries(StandardVMType.java:140)
at
org.eclipse.jdt.internal.launching.StandardVMType.validateIn stallLocation(StandardVMType.java:452)
at
org.eclipse.buckminster.jdt.commands.InstallJRE.internalRun( InstallJRE.java:82)
at
org.eclipse.buckminster.core.commands.WorkspaceCommand.run(W orkspaceCommand.java:191)
at
org.eclipse.buckminster.cmdline.AbstractCommand.basicRun(Abs tractCommand.java:155)
at org.eclipse.buckminster.cmdline.Headless.run(Headless.java:3 41)
at org.eclipse.buckminster.cmdline.Headless.run(Headless.java:1 35)
at org.eclipse.buckminster.cmdline.Headless.start(Headless.java :189)
at
org.eclipse.equinox.internal.app.EclipseAppHandle.run(Eclips eAppHandle.java:194)
at
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:110)
at
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:79)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:368)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:179)
at
at
at java.lang.reflect.Method.invoke(Method.java:585)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java: 559)
at org.eclipse.equinox.launcher.Main.main(Main.java:1287)
Caused by: java.io.IOException: java.io.IOException:
/opt/toolbox/ibm.com/j9/j9_6.1.1.20061110-161633/bin/j9: cannot execute
at java.lang.UNIXProcess.<init>(UNIXProcess.java:148)
at java.lang.ProcessImpl.start(ProcessImpl.java:65)
at java.lang.ProcessBuilder.start(ProcessBuilder.java:451)
at java.lang.Runtime.exec(Runtime.java:591)
at java.lang.Runtime.exec(Runtime.java:507)
at org.eclipse.debug.core.DebugPlugin.exec(DebugPlugin.java:808 )
... 24 more
The directory layout of the j9 is like:
ecf2:/opt/toolbox/ibm.com/j9/j9_6.1.1.20061110-161633 # ls -la
total 36
drwxr-xr-x 6 root root 4096 Jan 22 2009 .
drwxr-xr-x 3 root root 4096 Jan 22 2009 ..
-rw-r--r-- 1 mkuppe cimasters 939 Jan 22 2009 CDC1-1_Foundation1-1.ee
drwxr-xr-x 5 mkuppe cimasters 4096 Jan 22 2009 bin
-rw-r--r-- 1 mkuppe cimasters 710 Nov 10 2006 buildinfo.xml
-rw-r--r-- 1 mkuppe cimasters 222 Nov 10 2006 copyright.txt
drwxr-xr-x 2 mkuppe cimasters 4096 Jan 22 2009 doc
drwxr-xr-x 2 mkuppe cimasters 4096 Jan 22 2009 examples
drwxr-xr-x 4 mkuppe cimasters 4096 Jan 22 2009 lib
Markus
Previous Topic:More bucky 3.6 p2 agent trouble...
Next Topic:Is there support form properties in an Aggregator model?
Current Time: Sat Jul 26 03:54:33 EDT 2025
Powered by FUDForum. Page generated in 0.05460 seconds
