Home » Archived » Buckminster » Problem with SVN auth from headless buckminster
Problem with SVN auth from headless buckminster [message #513921] Thu, 11 February 2010 11:34 Go to next message
I`m trying to set up the buckminster to work with a svn repository which
requires an authentication.
At my rmap i`ve tried to use the scheme like this:
<uri format="svn://user:password@host/..
but it didn`t work.
I`m using Subclipse headless adapter
(org.eclipse.buckminster.subclipse.headless 1.0.0.r10759)
After some debugging, I see that m_clientAdapter (in
org.eclipse.buckminster.subclipse.internal.SvnSession) isn`t initialized
by username and password from initial svn repo url.
Is it a bug?
or where am I wrong?
Thanks in advance.
Re: Problem with SVN auth from headless buckminster [message #514046 is a reply to message #513921] Fri, 12 February 2010 04:42 Go to previous messageGo to next message
Hi Andrey,
One way of doing this is to create a template workspace where you have added the repository location with credentials. I.e.
1. Start your IDE on a new workspace.
2. Add the repository location with credentials in the SVN repository view
3. Exit your IDE.
4. Create a zip of the workspace.
5. Use the zip as template workspace (i.e. -T <zip file>) when you import.
Buckminster will match the location found in the RMAP against any existing repository locations and thus, make use of
the credentials that you have added.
HTH,
Thomas Hallgren
On 02/11/2010 05:34 PM, Chicherin Andrey wrote:
> but it didn`t work.
> Is it a bug?
> Thanks in advance.
Re: Problem with SVN auth from headless buckminster [message #514053 is a reply to message #514046] Fri, 12 February 2010 00:20 Go to previous messageGo to next message
One thing that I forgot to add. You must use Subclipse with SVNKit in your IDE since SVNKit is used by the headless
environment. SVNKit and JavaHL will not store the credentials in the same place.
- thomas
On 02/12/2010 10:42 AM, Thomas Hallgren wrote:
> Hi Andrey,
> 3. Exit your IDE.
> existing repository locations and thus, make use of the credentials that
> you have added.
> HTH,
> Thomas Hallgren
>> Hi,
>> but it didn`t work.
>> Is it a bug?
>> Thanks in advance.
Re: Problem with SVN auth from headless buckminster [message #514446 is a reply to message #514053] Mon, 15 February 2010 06:44 Go to previous messageGo to next message
Thank you Thomas.
But this solution is not suitable for me.
I'm trying to make a general build script for several similar projects.
I think that specifying SVN user credentials by using properties when
calling the script (via the command-line) will be more convenient.
> your IDE since SVNKit is used by the headless environment. SVNKit and
> - thomas
>> Hi Andrey,
>> view
>> 3. Exit your IDE.
>> import.
>> you have added.
>> HTH,
>> Thomas Hallgren
>>> Hi,
>>> but it didn`t work.
>>> Is it a bug?
>>> Thanks in advance.
Re: Problem with SVN auth from headless buckminster [message #533196 is a reply to message #514053] Wed, 12 May 2010 10:22 Go to previous messageGo to next message
Thomas,
I am having the same problem as the OP. I tried your solution of pre-populating a workspace with credentials, but it doesn't appear to have had any effect. Are there any other options? Is this a Subclipse bug, or intended behavior?
Re: Problem with SVN auth from headless buckminster [message #533210 is a reply to message #513921] Wed, 12 May 2010 10:47 Go to previous messageGo to next message
Using username and password in the repository URL is one way of defining
the credentials, but there is a much better way that both works and is
more secure.
Switch to using svn+ssh access scheme, and configure ssh access to the
machine with the repository. This way, the public key for the user-id
that is executing the process will be used. No userid or password needs
to be stored in clear text anywhere.
- henrik
On 2/11/10 5:34 PM, Chicherin Andrey wrote:
> but it didn`t work.
> Is it a bug?
> Thanks in advance.
Re: Problem with SVN auth from headless buckminster [message #533233 is a reply to message #533210] Wed, 12 May 2010 12:03 Go to previous messageGo to next message
For mine, our team is currently just using anonymous/anonymous, so security isn't a huge problem. I will see if I can get SSH access set up any time soon (we're not in charge of the repo), but basic https access would be much simpler. Is it known and accepted that https doesn't work in a headless environment?
Re: Problem with SVN auth from headless buckminster [message #533238 is a reply to message #533233] Wed, 12 May 2010 12:25 Go to previous messageGo to next message
afaik, it should work (deferring to Thomas here...)
- the advice is simply to use svn+ssh if possible as it is more secure
and does not require advanced property gymnastics trying to hide
user/password in clear text in properties files.
- henrik
Re: Problem with SVN auth from headless buckminster [message #533241 is a reply to message #533238] Wed, 12 May 2010 12:43 Go to previous messageGo to next message
Ok - good to know I'm not going down a path that doesn't work, at least Smile
Re: Problem with SVN auth from headless buckminster [message #533250 is a reply to message #533238] Wed, 12 May 2010 13:06 Go to previous message
https works, but you might need to use it from a browser or wget first to accept a certificate exception.
- thomas
> Regards
> - henrik
Previous Topic:building buckminster from source
Next Topic:failing to create target definition against aggregated site
Current Time: Wed Jul 23 17:31:22 EDT 2025
Powered by FUDForum. Page generated in 0.08617 seconds
