Home » Language IDEs » Java Development Tools (JDT) » Using FreeTTS with Eclipse
Using FreeTTS with Eclipse [message #505086] Sat, 26 December 2009 12:18 Go to next message
I am using the following book to learn Eclipse 3.5;
Professional Eclipse 3 for Java Developers by Berthold Daum.
I get the following error when I compile an example that illustrates the use of FreeTTS and the JSAPI:
System property "mbrola.base" is undefined. Will not use MBROLA voices.
How would I define "mbrola.base" for FreeTTS through Eclipse. The book did not mention anything about setting up mbrola.
Please help.
Thank you.
Re: Using FreeTTS with Eclipse [message #505118 is a reply to message #505086] Sun, 27 December 2009 01:53 Go to previous message
sarahlish18@gmail.com wrote:
> Please help.
> Thank you.
I don't know anything about that book or about MBROLA; you might want to contact
the author of the book.
But to set a system property when running a Java app, you typically pass a "-D"
argument on the command line, or in the Eclipse launch configuration. For
instance, -Dmbrola.base or -Dmbrola.base=whatever .
Re: Using FreeTTS with Eclipse [message #505120 is a reply to message #505118] Sat, 26 December 2009 22:32 Go to previous message
Hi Walter,
Thank you, comment you made regarding the configuration file has assisted me in solving the issue.
Thank you very much.
Previous Topic:Completion on FQCN for JAXB ObjectFactory doesn't do the completion
Next Topic:Apache server, Tomcat server, Spring
Current Time: Sat Jul 19 20:40:45 EDT 2025
Powered by FUDForum. Page generated in 0.04058 seconds
