Home » Archived » Java WorkFlow Tooling (JWT) » Newbie Question/Issue: JWT Hanging on startup
Newbie Question/Issue: JWT Hanging on startup [message #500805] |
Sat, 28 November 2009 17:44  |
Hi Everyone,
I'm relatively new to the Eclipse world, but I saw the potential of JWT and jumped in. However, I am having difficulties getting started with JWT. I have Snow Leopard (10.6.2) running Eclipse 3.6 (64bit) with Java 1.6 JVM (64bit). When creating a new JWT workflow I immediately run into problems. Eclipse seems to properly setup a new JWT workflow but begins to use a great deal of CPU (100%) and there doesn't seem to be any errors generated. Do I need to install Java 1.5 JVM and somehow get Eclipse to point to it. Is there something I'm missing from this installation?
Thank you very much for any help you can provide!
Ed
Re: Newbie Question/Issue: JWT Hanging on startup [message #501139 is a reply to message #500950] |
Tue, 01 December 2009 04:21   |
Thanks a lot Marc,
I just grabbed the log entry as I started a JWT project. Looks like a conflict with an existing binding:
!ENTRY org.eclipse.jface 2 0 2009-12-01 00:57:28.148
!MESSAGE Keybinding conflicts occurred. They may interfere with normal accelerator operation.
!SUBENTRY 1 org.eclipse.jface 2 0 2009-12-01 00:57:28.148
!MESSAGE A conflict occurred for ALT+COMMAND+Q P:
Binding(ALT+COMMAND+Q P,
ParameterizedCommand(Command(org.eclipse.ui.views.showView,Show View,
Shows a particular view,
Category(org.eclipse.ui.category.views,Views,Commands for opening views,true),
org.eclipse.ui.handlers.ShowViewHandler@3b54fd7a,
[Lorg.eclipse.ui.internal.commands.Parameter;@48cd7304,,true),[Lorg.eclipse.core.commands.Parameterization;@283a30f3),
org.eclipse.ui.defaultAcceleratorConfiguration,
org.eclipse.ui.contexts.window,,cocoa,system)
[Lorg.eclipse.ui.internal.commands.Parameter;@48cd7304,,true),[Lorg.eclipse.core.commands.Parameterization;@463b627),
!SESSION 2009-12-01 01:13:05.835 -----------------------------------------------
eclipse.buildId=M20090917-0800
java.version=1.6.0_15
java.vendor=Apple Inc.
BootLoader constants: OS=macosx, ARCH=x86_64, WS=cocoa, NL=en_US
Framework arguments: -product org.eclipse.epp.package.jee.product -keyring /Users/euser/.eclipse_keyring -showlocation
Command-line arguments: -os macosx -ws cocoa -arch x86_64 -product org.eclipse.epp.package.jee.product -keyring /Users/euser/.eclipse_keyring -showlocation
!ENTRY org.eclipse.core.resources 2 10035 2009-12-01 01:13:15.862
!MESSAGE The workspace exited with unsaved changes in the previous session; refreshing workspace to recover changes.
I'll also install the 32-bit versions and see if the results are the same or different. Let me know how else I can help you, help me.
Thanks!
Ed
Re: Newbie Question/Issue: JWT Hanging on startup [message #501557 is a reply to message #501139] |
Wed, 02 December 2009 14:01   |
Hi Edmund
This log seems to talk about key binding conflict, we've already seen
some as you can see at :
https://bugs.eclipse.org/bugs/show_bug.cgi?id=277436
However, I don't think that's the main problem for you.
You can change key bindings in Window > Preferences... > General > Key
by sorting them by Category.
Out of interest anyway, what's your locale ?
But I'm not sure it answers your previous problem:
"I'm relatively new to the Eclipse world, but I saw the potential of JWT
installation?"
Marc
Edmund Young a écrit :
> Thanks a lot Marc,
> ParameterizedCommand(Command(org.eclipse.ui.views.showView,S how
> View,
> [Lorg.eclipse.ui.internal.commands.Parameter;@48cd7304,,true ),[Lorg.eclipse.core.commands.Parameterization;@283a30f3),
> View,
> [Lorg.eclipse.ui.internal.commands.Parameter;@48cd7304,,true ),[Lorg.eclipse.core.commands.Parameterization;@463b627),
> same or different. Let me know how else I can help you, help me. :lol:
> Thanks!
> Ed
Re: Newbie Question/Issue: JWT Hanging on startup [message #501576 is a reply to message #501557] |
Wed, 02 December 2009 16:13   |
Hi Marc,
The binding probably aren't the issue, you're right. But after running JWT for longer, I found a runtime exception. This might be helpful. I pasted it below.
I'm located in sunny California. Well not so sunny in San Francisco today, but that's another story.
Where are you?
Ed
!ENTRY org.eclipse.jface 2 0 2009-12-01 01:37:33.396
!SUBENTRY 1 org.eclipse.jface 2 0 2009-12-01 01:37:33.400
org.eclipse.ui.handlers.ShowViewHandler@22d15c2c,
[Lorg.eclipse.ui.internal.commands.Parameter;@5efa5e8f,,true),[Lorg.eclipse.core.commands.Parameterization;@7562f00),
[Lorg.eclipse.ui.internal.commands.Parameter;@5efa5e8f,,true),[Lorg.eclipse.core.commands.Parameterization;@2b27acc3),
!ENTRY org.eclipse.core.net 1 0 2009-12-01 01:37:33.963
!MESSAGE System property http.nonProxyHosts has been set to local|*.local|169.254/16|*.169.254/16 by an external source. This value will be overwritten using the values from the preferences
!ENTRY org.eclipse.jface 2 0 2009-12-01 01:37:42.947
!MESSAGE Ignored reentrant call while viewer is busy. This is only logged once per viewer instance, but similar calls will still be ignored.
!STACK 0
java.lang.RuntimeException
at org.eclipse.jface.viewers.ColumnViewer.checkBusy(ColumnViewer.java:763)
at org.eclipse.jface.viewers.ColumnViewer.refresh(ColumnViewer.java:541)
at org.eclipse.ui.navigator.CommonViewer.refresh(CommonViewer.java:358)
at org.eclipse.ui.navigator.CommonViewer.refresh(CommonViewer.java:515)
at org.eclipse.ui.internal.navigator.resources.workbench.ResourceExtensionContentProvider$3.run(ResourceExtensionContentProvider.java:294)
at org.eclipse.ui.internal.navigator.resources.workbench.ResourceExtensionContentProvider.runUpdates(ResourceExtensionContentProvider.java:306)
at org.eclipse.ui.internal.navigator.resources.workbench.ResourceExtensionContentProvider.processDelta(ResourceExtensionContentProvider.java:116)
at org.eclipse.ui.model.WorkbenchContentProvider.resourceChanged(WorkbenchContentProvider.java:106)
at org.eclipse.core.internal.events.NotificationManager$2.run(NotificationManager.java:291)
at org.eclipse.core.internal.events.NotificationManager.notify(NotificationManager.java:285)
at org.eclipse.core.internal.events.NotificationManager.broadcastChanges(NotificationManager.java:149)
at org.eclipse.core.internal.resources.Workspace.broadcastPostChange(Workspace.java:313)
at org.eclipse.core.internal.resources.Workspace.endOperation(Workspace.java:1022)
at org.eclipse.core.internal.resources.Workspace.run(Workspace.java:1809)
at org.eclipse.jdt.internal.core.JavaModelManager.initializeAllContainers(JavaModelManager.java:2554)
at org.eclipse.jdt.internal.core.JavaModelManager.getClasspathContainer(JavaModelManager.java:1773)
at org.eclipse.jdt.core.JavaCore.getClasspathContainer(JavaCore.java:2652)
at org.eclipse.jdt.internal.core.JavaProject.resolveClasspath(JavaProject.java:2578)
at org.eclipse.jdt.internal.core.JavaProject.resolveClasspath(JavaProject.java:2679)
at org.eclipse.jdt.internal.core.JavaProject.getResolvedClasspath(JavaProject.java:1866)
at org.eclipse.jdt.internal.core.JavaProject.buildStructure(JavaProject.java:424)
at org.eclipse.jdt.internal.core.Openable.generateInfos(Openable.java:258)
at org.eclipse.jdt.internal.core.JavaElement.openWhenClosed(JavaElement.java:515)
at org.eclipse.jdt.internal.core.JavaElement.getElementInfo(JavaElement.java:252)
at org.eclipse.jdt.internal.core.JavaElement.getElementInfo(JavaElement.java:238)
at org.eclipse.jdt.internal.core.JavaElement.getChildren(JavaElement.java:193)
at org.eclipse.jdt.internal.core.JavaProject.getPackageFragmentRoots(JavaProject.java:1761)
at org.eclipse.jdt.internal.ui.packageview.PackageExplorerContentProvider.getPackageFragmentRoots(PackageExplorerContentProvider.java:316)
at org.eclipse.jdt.ui.StandardJavaElementContentProvider.getChildren(StandardJavaElementContentProvider.java:183)
at org.eclipse.jdt.internal.ui.packageview.PackageExplorerContentProvider.getChildren(PackageExplorerContentProvider.java:301)
at org.eclipse.jdt.internal.ui.navigator.JavaNavigatorContentProvider.getChildren(JavaNavigatorContentProvider.java:141)
at org.eclipse.jdt.internal.ui.navigator.JavaNavigatorContentProvider.getPipelinedChildren(JavaNavigatorContentProvider.java:162)
at org.eclipse.ui.internal.navigator.NavigatorContentServiceContentProvider.pipelineChildren(NavigatorContentServiceContentProvider.java:319)
at org.eclipse.ui.internal.navigator.NavigatorContentServiceContentProvider.internalGetChildren(NavigatorContentServiceContentProvider.java:255)
at org.eclipse.ui.internal.navigator.NavigatorContentServiceContentProvider.getChildren(NavigatorContentServiceContentProvider.java:604)
at org.eclipse.jface.viewers.AbstractTreeViewer.getRawChildren(AbstractTreeViewer.java:1346)
at org.eclipse.jface.viewers.TreeViewer.getRawChildren(TreeViewer.java:390)
at org.eclipse.jface.viewers.AbstractTreeViewer.getFilteredChildren(AbstractTreeViewer.java:636)
at org.eclipse.jface.viewers.AbstractTreeViewer.getSortedChildren(AbstractTreeViewer.java:602)
at org.eclipse.jface.viewers.AbstractTreeViewer$1.run(AbstractTreeViewer.java:797)
at org.eclipse.jface.viewers.AbstractTreeViewer.createChildren(AbstractTreeViewer.java:776)
at org.eclipse.jface.viewers.TreeViewer.createChildren(TreeViewer.java:639)
at org.eclipse.jface.viewers.AbstractTreeViewer.internalExpand(AbstractTreeViewer.java:1585)
at org.eclipse.jface.viewers.AbstractTreeViewer.setSelectionToWidget(AbstractTreeViewer.java:2463)
at org.eclipse.ui.navigator.CommonViewer.setSelectionToWidget(CommonViewer.java:451)
at org.eclipse.jface.viewers.StructuredViewer.setSelectionToWidget(StructuredViewer.java:1711)
at org.eclipse.jface.viewers.AbstractTreeViewer.setSelectionToWidget(AbstractTreeViewer.java:2903)
at org.eclipse.jface.viewers.StructuredViewer.setSelection(StructuredViewer.java:1667)
at org.eclipse.jface.viewers.TreeViewer.setSelection(TreeViewer.java:1124)
at org.eclipse.ui.navigator.CommonViewer.setSelection(CommonViewer.java:382)
at org.eclipse.ui.navigator.CommonNavigator.selectReveal(CommonNavigator.java:362)
at org.eclipse.ui.internal.navigator.actions.LinkEditorAction$3.run(LinkEditorAction.java:101)
at org.eclipse.ui.internal.navigator.actions.LinkEditorAction$2.runInUIThread(LinkEditorAction.java:89)
at org.eclipse.ui.progress.UIJob$1.run(UIJob.java:95)
at org.eclipse.swt.widgets.RunnableLock.run(RunnableLock.java:35)
at org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchronizer.java:134)
at org.eclipse.swt.widgets.Display.runAsyncMessages(Display.java:3405)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3102)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.java:2405)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2369)
at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:2221)
at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:500)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:493)
at org.eclipse.ui.internal.ide.application.IDEApplication.start(IDEApplication.java:113)
at org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandle.java:194)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:368)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:39)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:559)
!SESSION 2009-12-01 11:14:48.155 -----------------------------------------------
!ENTRY org.eclipse.core.net 1 0 2009-12-01 11:15:19.789
Re: Newbie Question/Issue: JWT Hanging on startup [message #501594 is a reply to message #501576] |
Wed, 02 December 2009 18:37  |
I also found one more error that might be related:
!ENTRY org.eclipse.jface 2 0 2009-11-28 14:12:05.089
!SUBENTRY 1 org.eclipse.jface 2 0 2009-11-28 14:12:05.089
org.eclipse.ui.handlers.ShowViewHandler@6f262671,
[Lorg.eclipse.ui.internal.commands.Parameter;@31a5fdb9,,true),[Lorg.eclipse.core.commands.Parameterization;@8b49626),
[Lorg.eclipse.ui.internal.commands.Parameter;@31a5fdb9,,true),[Lorg.eclipse.core.commands.Parameterization;@7ed9d41),
!ENTRY org.eclipse.core.net 1 0 2009-11-28 14:12:05.362
!ENTRY org.eclipse.ui.workbench 4 2 2009-11-28 14:12:18.282
!MESSAGE Problems occurred when invoking code from plug-in: "org.eclipse.ui.workbench".
!STACK 0
java.lang.ExceptionInInitializerError
at org.eclipse.dltk.ui.ProblemsLabelDecorator.decorate(ProblemsLabelDecorator.java:395)
at org.eclipse.ui.internal.decorators.LightweightDecoratorDefinition.decorate(LightweightDecoratorDefinition.java:263)
at org.eclipse.ui.internal.decorators.LightweightDecoratorManager$LightweightRunnable.run(LightweightDecoratorManager.java:81)
at org.eclipse.ui.internal.decorators.LightweightDecoratorManager.decorate(LightweightDecoratorManager.java:365)
at org.eclipse.ui.internal.decorators.LightweightDecoratorManager.getDecorations(LightweightDecoratorManager.java:347)
at org.eclipse.ui.internal.decorators.DecorationScheduler$1.ensureResultCached(DecorationScheduler.java:371)
at org.eclipse.ui.internal.decorators.DecorationScheduler$1.run(DecorationScheduler.java:331)
at org.eclipse.dltk.ui.DLTKPluginImages.create(DLTKPluginImages.java:462)
at org.eclipse.dltk.ui.DLTKPluginImages.createUnManaged(DLTKPluginImages.java:497)
at org.eclipse.dltk.ui.DLTKPluginImages.<clinit>(DLTKPluginImages.java:140)
... 9 more
!ENTRY org.eclipse.ui 4 4 2009-11-28 14:12:18.284
!MESSAGE Exception in Decorator. The 'PHP Problem Decorator' decorator will be disabled.
!ENTRY org.eclipse.ui 4 4 2009-11-28 14:12:18.297
!MESSAGE java.lang.ExceptionInInitializerError
!STACK 0
!SESSION 2009-11-30 23:33:58.602 -----------------------------------------------
Framework arguments: -product org.eclipse.epp.package.jee.product -keyring /Users/edmundyoung/.eclipse_keyring -showlocation
Command-line arguments: -os macosx -ws cocoa -arch x86_64 -product org.eclipse.epp.package.jee.product -keyring /Users/edmundyoung/.eclipse_keyring -showlocation
!ENTRY org.eclipse.core.resources 2 10035 2009-11-30 23:34:21.233
Current Time: Tue Jul 22 21:46:35 EDT 2025
Powered by FUDForum. Page generated in 0.05740 seconds
