Home » Eclipse Projects » Platform - User Assistance (UA) » Standalone Eclipse help won't run from fileserver ClassNotFound - EclipseStarter(Standalone Eclipse help won't run from fileserver java.lang.ClassNotFoundException: org.eclipse.core.runtime.adaptor.EclipseStarter)
Standalone Eclipse help won't run from fileserver ClassNotFound - EclipseStarter [message #498562] Tue, 17 November 2009 09:26 Go to next message
Hi all, I'm having trouble getting my Standalone Eclipse help to run from anywhere other than the server on which it was created.
Ideally we want to put it on a fileserver - just for the review by a few colleagues. We are reviewing the full functionality, and so it needs to be the standalone help. Unfortunately, once copied to a network drive, it refuses to run. It also refuses to run wherever it is copied such as to people's local disks. We get the following error:
Since I posted this on eclipse_tw list, I've discovered that it is perfectly OK to unzip a new install of Eclipse to a fileserver and place our documentation plug-in inside it. Why is that different to when I copy the files for our minimal set of plug-ins?
Thanks in advance for any help you can give me.
Richard
Re: Standalone Eclipse help won't run from fileserver ClassNotFound - EclipseStarter [message #499087 is a reply to message #498562] Thu, 19 November 2009 13:42 Go to previous messageGo to next message
My guess is that you are not copying all of the files needed to start standalone help. This class comes from org.eclipse.osgi.
Re: Standalone Eclipse help won't run from fileserver ClassNotFound - EclipseStarter [message #499171 is a reply to message #499087] Fri, 20 November 2009 04:22 Go to previous messageGo to next message
Hi Chris.
I found that by downloading and extracting a full install, copying in my doc plugin and using my start and stop scripts I could get the help to work.
I then used this working install to copy parts (including at one point all the plugins) in and out of my cutdown standalone help install. I didn't have any joy until I copied the following folder from the configuration folder:
org.eclipse.equinox.simpleconfigurator
This contains a file called bundles.info which lists the plugins.
Once this file is in place, my standalone help worked.
The question is, do I need to remove lines from this as I remove plugins to make my minimal set?
Richard
[Updated on: Fri, 20 November 2009 04:23] by Moderator
Re: Standalone Eclipse help won't run from fileserver ClassNotFound - EclipseStarter [message #499745 is a reply to message #499171] Mon, 23 November 2009 17:22 Go to previous message
As far as I know you don't need to remove any lines from that file.
Previous Topic:Possible to display image in cheat sheets?
Next Topic:Eclipse Internal Web Browser and Applets
Current Time: Thu Jul 31 03:14:53 EDT 2025
Powered by FUDForum. Page generated in 0.06287 seconds
