Home » Eclipse Projects » Dynamic Languages Toolkit (DLTK) » (DLTK Newbie) Creating new script editor: NPE
(DLTK Newbie) Creating new script editor: NPE [message #496073] Sat, 07 November 2009 20:10 Go to next message
Hi All,
I'm writing a new development environment for UnrealScript (Epic just released a free version of Unreal Engine 3), following the really helpful guide http://wiki.eclipse.org/A_guide_to_building_a_DLTK-based_lan guage_IDE . I've really hit a wall creating the editor with a NPE when I try to open a new .uc file using my UnrealScriptEditor.
The NPE is posted at the bottom of this message. I've tried to attach all of the relevant classes (there are more as you can see from plugin.xml). I've been stuck on this for days now to no avail, I hope it's a simple config thing that is easy to spot either in plugin.xml or UnrealScriptEditor.java, but I'm at my wits' end Sad
Any help is hugely appreciated, thanks in advance.
***** plugin.xml *****
<?eclipse version="3.4"?>
<plugin>
  <extension
        id="nature"
        point="org.eclipse.core.resources.natures">
     <runtime>
        <run
           class="org.eclipse.dltk.unrealscript.UnrealScriptNature">
        </run>
     </runtime>
  </extension>
  <extension
        point="org.eclipse.core.runtime.contentTypes">
     <content-type
           base-type="org.eclipse.core.runtime.text"
           describer="org.eclipse.dltk.unrealscript.UnrealScriptContentDescriber"
           file-extensions="uc"
           id="org.eclipse.dltk.unrealscript.content-type"
           name="UnrealScript File"
           priority="high">
     </content-type>
  </extension>
  <extension
        point="org.eclipse.dltk.core.language">
     <language
           class="org.eclipse.dltk.unrealscript.UnrealScriptLanguageToolkit"
           nature="org.eclipse.dltk.unrealscript.nature"
           priority="0">
     </language>
  </extension>
  <extension
        point="org.eclipse.ui.newWizards">
     <wizard
           category="org.eclipse.dltk.unrealscript.category"
           class="org.eclipse.dltk.unrealscript.UnrealScriptProjectWizard:org.eclipse.dltk.unrealscript.nature"
           icon="unreal_logo_small.png"
           id="org.eclipse.dltk.unrealscript.wizard"
           name="UnrealScript Project"
           project="true">
     </wizard>
     <category
           id="org.eclipse.dltk.unrealscript.category"
           name="UnrealScript">
     </category>
  </extension>
  <extension
        point="org.eclipse.dltk.ui.language">
     <language
           class="org.eclipse.dltk.unrealscript.UnrealScriptUILanguageToolkit"
           priority="0">
     </language>
  </extension>
  <extension
        point="org.eclipse.ui.editors">
     <editor
           class="org.eclipse.dltk.unrealscript.UnrealScriptEditor"
           default="false"
           id="org.eclipse.dltk.unrealscript.editor"
           name="UnrealScript Editor">
        <contentTypeBinding
              contentTypeId="org.eclipse.dltk.unrealscript.content-type">
        </contentTypeBinding>
     </editor>
  </extension>
</plugin>
***** UnrealScriptEditor.java *****
package org.eclipse.dltk.unrealscript;
import org.eclipse.dltk.core.IDLTKLanguageToolkit;
import org.eclipse.dltk.internal.ui.editor.ScriptEditor;
import org.eclipse.jface.preference.IPreferenceStore;
public class UnrealScriptEditor extends ScriptEditor {
       public static final String EDITOR_ID = "org.eclipse.dltk.unrealscript.editor";
       public static final String EDITOR_CONTEXT = "#UnrealScriptEditorContext";
       protected void initialiseEditor() {
               super.initializeEditor();
               setEditorContextMenuId(EDITOR_CONTEXT);
       public String getEditorId() {
               return EDITOR_ID;
       public IDLTKLanguageToolkit getLanguageToolkit() {
               return UnrealScriptLanguageToolkit.getDefault();
       protected IPreferenceStore getScriptPreferenceStore() {
               return UnrealScript.getDefault().getPreferenceStore();
***** UnrealScriptContentDescriber.java *****
import java.util.regex.Pattern;
import org.eclipse.dltk.core.ScriptContentDescriber;
public class UnrealScriptContentDescriber extends ScriptContentDescriber {
       public UnrealScriptContentDescriber() {
       protected static Pattern[] header_patterns = {
               Pattern.compile("^#!.*unrealscript.*", Pattern.MULTILINE)
       protected Pattern[] getHeaderPatterns() {
               return header_patterns;
***** UnrealScript.java *****
import org.eclipse.ui.plugin.AbstractUIPlugin;
import org.osgi.framework.BundleContext;
 * The activator class controls the plug-in life cycle
public class UnrealScript extends AbstractUIPlugin {
       // The plug-in ID
       public static final String PLUGIN_ID = "org.eclipse.dltk.unrealscript";
       // The shared instance
       private static UnrealScript plugin;
        * The constructor
       public UnrealScript() {
        * (non-Javadoc)
        * @see org.eclipse.ui.plugin.AbstractUIPlugin#start(org.osgi.framework.BundleContext)
       public void start(BundleContext context) throws Exception {
               super.start(context);
               plugin = this;
        * (non-Javadoc)
        * @see org.eclipse.ui.plugin.AbstractUIPlugin#stop(org.osgi.framework.BundleContext)
       public void stop(BundleContext context) throws Exception {
               plugin = null;
               super.stop(context);
        * Returns the shared instance
        * @return the shared instance
       public static UnrealScript getDefault() {
               return plugin;
***** UnrealScriptLanguageToolkit.java *****
import org.eclipse.dltk.core.AbstractLanguageToolkit;
public class UnrealScriptLanguageToolkit extends AbstractLanguageToolkit {
       private static UnrealScriptLanguageToolkit toolkit;
       public static IDLTKLanguageToolkit getDefault() {
               if (toolkit == null) {
                       toolkit = new UnrealScriptLanguageToolkit();
               return toolkit;
       public String getLanguageContentType() {
               return "org.eclipse.dltk.unrealscript.content-type";
       public String getLanguageName() {
               return "UnrealScript";
       public String getNatureId() {
               return UnrealScriptNature.UNREALSCRIPT_NATURE;
***** UnrealScriptNature.java *****
import org.eclipse.dltk.core.ScriptNature;
public class UnrealScriptNature extends ScriptNature {
       public static final String UNREALSCRIPT_NATURE =
UnrealScript.PLUGIN_ID + ".nature";
***** .log *****
!ENTRY org.eclipse.ui 4 0 2009-11-08 10:21:57.019
!MESSAGE An unexpected exception was thrown.
!STACK 0
       at org.eclipse.dltk.internal.ui.editor.ScriptEditor$AdaptedSourceViewer.unconfigure(ScriptEditor.java:408)
       at org.eclipse.jface.text.source.SourceViewer.handleDispose(SourceViewer.java:667)
       at org.eclipse.jface.text.source.projection.ProjectionViewer.handleDispose(ProjectionViewer.java:1362)
       at org.eclipse.dltk.internal.ui.editor.ScriptSourceViewer.handleDispose(ScriptSourceViewer.java:450)
       at org.eclipse.jface.text.TextViewer$2.widgetDisposed(TextViewer.java:1788)
       at org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListener.java:117)
       at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1003)
       at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1027)
       at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1012)
       at org.eclipse.swt.widgets.Widget.notifyListeners(Widget.java:770)
       at org.eclipse.swt.custom.StyledText.handleDispose(StyledText.java:5712)
       at org.eclipse.swt.custom.StyledText$7.handleEvent(StyledText.java:5540)
       at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1008)
       at org.eclipse.swt.widgets.Widget.release(Widget.java:804)
       at org.eclipse.swt.widgets.Composite.releaseChildren(Composite.java:756)
       at org.eclipse.swt.widgets.Canvas.releaseChildren(Canvas.java:174)
       at org.eclipse.swt.widgets.Widget.release(Widget.java:807)
       at org.eclipse.swt.widgets.Widget.dispose(Widget.java:441)
       at org.eclipse.ui.internal.EditorReference.createPartHelper(EditorReference.java:687)
       at org.eclipse.ui.internal.EditorReference.createPart(EditorReference.java:462)
       at org.eclipse.ui.internal.WorkbenchPartReference.getPart(WorkbenchPartReference.java:595)
       at org.eclipse.ui.internal.PartPane.setVisible(PartPane.java:313)
       at org.eclipse.ui.internal.presentations.PresentablePart.setVisible(PresentablePart.java:180)
       at org.eclipse.ui.internal.presentations.util.PresentablePartFolder.select(PresentablePartFolder.java:270)
       at org.eclipse.ui.internal.presentations.util.LeftToRightTabOrder.select(LeftToRightTabOrder.java:65)
       at org.eclipse.ui.internal.presentations.util.TabbedStackPresentation.selectPart(TabbedStackPresentation.java:473)
       at org.eclipse.ui.internal.PartStack.refreshPresentationSelection(PartStack.java:1256)
       at org.eclipse.ui.internal.PartStack.setSelection(PartStack.java:1209)
       at org.eclipse.ui.internal.PartStack.showPart(PartStack.java:1608)
       at org.eclipse.ui.internal.PartStack.add(PartStack.java:499)
       at org.eclipse.ui.internal.EditorStack.add(EditorStack.java:103)
       at org.eclipse.ui.internal.PartStack.add(PartStack.java:485)
       at org.eclipse.ui.internal.EditorStack.add(EditorStack.java:112)
       at org.eclipse.ui.internal.EditorSashContainer.addEditor(EditorSashContainer.java:63)
       at org.eclipse.ui.internal.EditorAreaHelper.addToLayout(EditorAreaHelper.java:225)
       at org.eclipse.ui.internal.EditorAreaHelper.addEditor(EditorAreaHelper.java:213)
       at org.eclipse.ui.internal.EditorManager.createEditorTab(EditorManager.java:778)
       at org.eclipse.ui.internal.EditorManager.openEditorFromDescriptor(EditorManager.java:677)
       at org.eclipse.ui.internal.EditorManager.openEditor(EditorManager.java:638)
       at org.eclipse.ui.internal.WorkbenchPage.busyOpenEditorBatched(WorkbenchPage.java:2854)
       at org.eclipse.ui.internal.WorkbenchPage.busyOpenEditor(WorkbenchPage.java:2762)
       at org.eclipse.ui.internal.WorkbenchPage.access$11(WorkbenchPage.java:2754)
       at org.eclipse.ui.internal.WorkbenchPage$10.run(WorkbenchPage.java:2705)
       at org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPage.java:2701)
       at org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPage.java:2685)
       at org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPage.java:2676)
       at org.eclipse.ui.ide.IDE.openEditor(IDE.java:651)
       at org.eclipse.ui.ide.IDE.openEditor(IDE.java:610)
       at org.eclipse.jdt.internal.ui.javaeditor.EditorUtility.openInEditor(EditorUtility.java:361)
       at org.eclipse.jdt.internal.ui.javaeditor.EditorUtility.openInEditor(EditorUtility.java:168)
       at org.eclipse.jdt.ui.actions.OpenAction.run(OpenAction.java:229)
       at org.eclipse.jdt.ui.actions.OpenAction.run(OpenAction.java:208)
       at org.eclipse.jdt.ui.actions.SelectionDispatchAction.dispatchRun(SelectionDispatchAction.java:274)
       at org.eclipse.jdt.ui.actions.SelectionDispatchAction.run(SelectionDispatchAction.java:250)
       at org.eclipse.jdt.internal.ui.packageview.PackageExplorerActionGroup.handleOpen(PackageExplorerActionGroup.java:373)
       at org.eclipse.jdt.internal.ui.packageview.PackageExplorerPart$4.open(PackageExplorerPart.java:526)
       at org.eclipse.ui.OpenAndLinkWithEditorHelper$InternalListener.open(OpenAndLinkWithEditorHelper.java:48)
       at org.eclipse.jface.viewers.StructuredViewer$2.run(StructuredViewer.java:842)
       at org.eclipse.core.runtime.Platform.run(Platform.java:888)
       at org.eclipse.ui.internal.JFaceUtil$1.run(JFaceUtil.java:48)
       at org.eclipse.jface.util.SafeRunnable.run(SafeRunnable.java:175)
       at org.eclipse.jface.viewers.StructuredViewer.fireOpen(StructuredViewer.java:840)
       at org.eclipse.jface.viewers.StructuredViewer.handleOpen(StructuredViewer.java:1101)
       at org.eclipse.jface.viewers.StructuredViewer$6.handleOpen(StructuredViewer.java:1205)
       at org.eclipse.jface.util.OpenStrategy.fireOpenEvent(OpenStrategy.java:264)
       at org.eclipse.jface.util.OpenStrategy.access$2(OpenStrategy.java:258)
       at org.eclipse.jface.util.OpenStrategy$1.handleEvent(OpenStrategy.java:298)
       at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.java:3880)
       at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3473)
       at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.java:2405)
       at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2369)
       at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:2221)
       at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:500)
       at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:493)
       at org.eclipse.ui.internal.ide.application.IDEApplication.start(IDEApplication.java:113)
       at org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandle.java:194)
       at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:368)
       at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:559)
       at org.eclipse.equinox.launcher.Main.main(Main.java:1287)
!ENTRY org.eclipse.ui 4 0 2009-11-08 10:21:57.021
!MESSAGE Unable to create editor ID
org.eclipse.dltk.unrealscript.editor: An unexpected exception was
thrown.
!STACK 0
       at org.eclipse.dltk.internal.ui.editor.ScriptEditor$AdaptedSourceViewer.configure(ScriptEditor.java:403)
       at org.eclipse.ui.texteditor.AbstractTextEditor.createPartControl(AbstractTextEditor.java:3322)
       at org.eclipse.ui.texteditor.StatusTextEditor.createPartControl(StatusTextEditor.java:53)
       at org.eclipse.ui.texteditor.AbstractDecoratedTextEditor.createPartControl(AbstractDecoratedTextEditor.java:427)
       at org.eclipse.dltk.internal.ui.editor.ScriptEditor.createPartControl(ScriptEditor.java:1750)
       at org.eclipse.ui.internal.EditorReference.createPartHelper(EditorReference.java:662)
Re: (DLTK Newbie) Creating new script editor: NPE [message #496326 is a reply to message #496073] Mon, 09 November 2009 12:41 Go to previous messageGo to next message
Hi Michael,
You should also implement the "public ScriptTextTools getTextTools()"
method of your editor.
I'll update the manual shortly.
Alex
Michael Alexander wrote:
> Hi All,
> helpful guide
> UnrealScriptEditor.java, but I'm at my wits' end :(
> <plugin>
> <extension
> id="nature"
> <runtime>
> <run
> </run>
> </runtime>
> </extension>
> <extension
> <content-type
> describer="org.eclipse.dltk.unrealscript.UnrealScriptContentDescriber "
> priority="high">
> </content-type>
> </extension>
> <extension
> <language
> class="org.eclipse.dltk.unrealscript.UnrealScriptLanguageToolkit "
> priority="0">
> </language>
> </extension>
> <extension
> <wizard
> class=" org.eclipse.dltk.unrealscript.UnrealScriptProjectWizard:org. eclipse.dltk.unrealscript.nature "
> project="true">
> </wizard>
> <category
> </category>
> </extension>
> <extension
> <language
> class="org.eclipse.dltk.unrealscript.UnrealScriptUILanguageToolkit "
> priority="0">
> </language>
> </extension>
> <extension
> <editor
> default="false"
> <contentTypeBinding
> </editor>
> </extension>
> </plugin>
> @Override
> return EDITOR_ID;
> @Override
> @Override
> @Override
> // The plug-in ID
> * The constructor
> * (non-Javadoc)
> * @see
> org.eclipse.ui.plugin.AbstractUIPlugin#start(org.osgi.framew ork.BundleContext)
> plugin = this;
> * (non-Javadoc)
> * @see
> org.eclipse.ui.plugin.AbstractUIPlugin#stop(org.osgi.framewo rk.BundleContext)
> plugin = null;
> return plugin;
> return toolkit;
> @Override
> @Override
> @Override
> ***** .log *****
> !STACK 0
> at
> org.eclipse.dltk.internal.ui.editor.ScriptEditor$AdaptedSour ceViewer.unconfigure(ScriptEditor.java:408)
> at
> org.eclipse.jface.text.source.SourceViewer.handleDispose(Sou rceViewer.java:667)
> at
> org.eclipse.jface.text.source.projection.ProjectionViewer.ha ndleDispose(ProjectionViewer.java:1362)
> at
> org.eclipse.dltk.internal.ui.editor.ScriptSourceViewer.handl eDispose(ScriptSourceViewer.java:450)
> at
> org.eclipse.jface.text.TextViewer$2.widgetDisposed(TextViewe r.java:1788)
> at
> org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListe ner.java:117)
> at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java :84)
> at org.eclipse.swt.widgets.Widget.notifyListeners(Widget.java:7 70)
> at
> org.eclipse.swt.custom.StyledText.handleDispose(StyledText.j ava:5712)
> at
> org.eclipse.swt.custom.StyledText$7.handleEvent(StyledText.j ava:5540)
> at
> org.eclipse.swt.widgets.Composite.releaseChildren(Composite. java:756)
> at org.eclipse.swt.widgets.Canvas.releaseChildren(Canvas.java:1 74)
> at
> at
> at
> at
> org.eclipse.ui.internal.EditorReference.createPartHelper(Edi torReference.java:687)
> at
> org.eclipse.ui.internal.EditorReference.createPart(EditorRef erence.java:462)
> at
> org.eclipse.ui.internal.WorkbenchPartReference.getPart(Workb enchPartReference.java:595)
> at org.eclipse.ui.internal.PartPane.setVisible(PartPane.java:31 3)
> at
> org.eclipse.ui.internal.presentations.PresentablePart.setVis ible(PresentablePart.java:180)
> at
> org.eclipse.ui.internal.presentations.util.PresentablePartFo lder.select(PresentablePartFolder.java:270)
> at
> org.eclipse.ui.internal.presentations.util.LeftToRightTabOrd er.select(LeftToRightTabOrder.java:65)
> at
> org.eclipse.ui.internal.presentations.util.TabbedStackPresen tation.selectPart(TabbedStackPresentation.java:473)
> at
> org.eclipse.ui.internal.PartStack.refreshPresentationSelecti on(PartStack.java:1256)
> at
> org.eclipse.ui.internal.PartStack.setSelection(PartStack.jav a:1209)
> at org.eclipse.ui.internal.PartStack.showPart(PartStack.java:16 08)
> at org.eclipse.ui.internal.EditorStack.add(EditorStack.java:103 )
> at org.eclipse.ui.internal.EditorStack.add(EditorStack.java:112 )
> at
> org.eclipse.ui.internal.EditorSashContainer.addEditor(Editor SashContainer.java:63)
> at
> org.eclipse.ui.internal.EditorAreaHelper.addToLayout(EditorA reaHelper.java:225)
> at
> org.eclipse.ui.internal.EditorAreaHelper.addEditor(EditorAre aHelper.java:213)
> at
> org.eclipse.ui.internal.EditorManager.createEditorTab(Editor Manager.java:778)
> at
> org.eclipse.ui.internal.EditorManager.openEditorFromDescript or(EditorManager.java:677)
> at
> org.eclipse.ui.internal.EditorManager.openEditor(EditorManag er.java:638)
> at
> org.eclipse.ui.internal.WorkbenchPage.busyOpenEditorBatched( WorkbenchPage.java:2854)
> at
> org.eclipse.ui.internal.WorkbenchPage.busyOpenEditor(Workben chPage.java:2762)
> at
> org.eclipse.ui.internal.WorkbenchPage.access$11(WorkbenchPag e.java:2754)
> at
> org.eclipse.ui.internal.WorkbenchPage$10.run(WorkbenchPage.j ava:2705)
> at
> org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator .java:70)
> at
> org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPa ge.java:2701)
> at
> org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPa ge.java:2685)
> at
> org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPa ge.java:2676)
> at
> org.eclipse.jdt.internal.ui.javaeditor.EditorUtility.openInE ditor(EditorUtility.java:361)
> at
> org.eclipse.jdt.internal.ui.javaeditor.EditorUtility.openInE ditor(EditorUtility.java:168)
> at org.eclipse.jdt.ui.actions.OpenAction.run(OpenAction.java:22 9)
> at org.eclipse.jdt.ui.actions.OpenAction.run(OpenAction.java:20 8)
> at
> org.eclipse.jdt.ui.actions.SelectionDispatchAction.dispatchR un(SelectionDispatchAction.java:274)
> at
> org.eclipse.jdt.ui.actions.SelectionDispatchAction.run(Selec tionDispatchAction.java:250)
> at
> org.eclipse.jdt.internal.ui.packageview.PackageExplorerActio nGroup.handleOpen(PackageExplorerActionGroup.java:373)
> at
> org.eclipse.jdt.internal.ui.packageview.PackageExplorerPart$ 4.open(PackageExplorerPart.java:526)
> at
> org.eclipse.ui.OpenAndLinkWithEditorHelper$InternalListener. open(OpenAndLinkWithEditorHelper.java:48)
> at
> org.eclipse.jface.viewers.StructuredViewer$2.run(StructuredV iewer.java:842)
> at org.eclipse.core.runtime.SafeRunner.run(SafeRunner.java:42)
> at org.eclipse.jface.util.SafeRunnable.run(SafeRunnable.java:17 5)
> at
> org.eclipse.jface.viewers.StructuredViewer.fireOpen(Structur edViewer.java:840)
> at
> org.eclipse.jface.viewers.StructuredViewer.handleOpen(Struct uredViewer.java:1101)
> at
> org.eclipse.jface.viewers.StructuredViewer$6.handleOpen(Stru cturedViewer.java:1205)
> at
> org.eclipse.jface.util.OpenStrategy.fireOpenEvent(OpenStrate gy.java:264)
> at
> org.eclipse.jface.util.OpenStrategy.access$2(OpenStrategy.ja va:258)
> at
> org.eclipse.jface.util.OpenStrategy$1.handleEvent(OpenStrate gy.java:298)
> at
> org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:3880)
> at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :3473)
> at
> org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:2405)
> at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:22 21)
> at
> org.eclipse.core.databinding.observable.Realm.runWithDefault (Realm.java:332)
> at
> org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:493)
> at
> org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.j ava:149)
> at
> org.eclipse.ui.internal.ide.application.IDEApplication.start (IDEApplication.java:113)
> at
> org.eclipse.equinox.internal.app.EclipseAppHandle.run(Eclips eAppHandle.java:194)
> at
> org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:110)
> at
> org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:79)
> at
> org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:368)
> at
> org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:179)
> at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java: 559)
> thrown.
> !STACK 0
> at
> org.eclipse.dltk.internal.ui.editor.ScriptEditor$AdaptedSour ceViewer.configure(ScriptEditor.java:403)
> at
> org.eclipse.ui.texteditor.AbstractTextEditor.createPartContr ol(AbstractTextEditor.java:3322)
> at
> org.eclipse.ui.texteditor.StatusTextEditor.createPartControl (StatusTextEditor.java:53)
> at
> org.eclipse.ui.texteditor.AbstractDecoratedTextEditor.create PartControl(AbstractDecoratedTextEditor.java:427)
> at
> org.eclipse.dltk.internal.ui.editor.ScriptEditor.createPartC ontrol(ScriptEditor.java:1750)
> at
> org.eclipse.ui.internal.EditorReference.createPartHelper(Edi torReference.java:662)
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
Re: (DLTK Newbie) Creating new script editor: NPE [message #548045 is a reply to message #496073] Tue, 20 July 2010 10:03 Go to previous message
Did you make any progress with this? I am interested in using/helping, although I don't have any experience writing plugins for eclipse.
Previous Topic:How manage Completion for Java Model with Freemarker script.
Next Topic:DLTK indexing annoyance in Zend Studio 7.2.1.v20100704
Current Time: Wed Jul 30 14:19:21 EDT 2025
Powered by FUDForum. Page generated in 0.02993 seconds
