Home » Newcomers » Newcomers » Debian testing, Gnome and Eclipse
Debian testing, Gnome and Eclipse [message #492089] Sun, 18 October 2009 10:18 Go to next message
Originally posted by: gunnar.stahl.gunnarstahl.org
since yesterday my eclipse installation is somewhat broken. The system I
use is a debian testing. After the most recent debian package updates,
performed yesterday, which included some gtk updates, eclipse has some
serious user interface issues.
Within some of the settings dialogs the buttons receive the "mouse
pressed" event, but no "mouse released" event. Which results in
clickable but unresponsive buttons.
For instance go into Windows -> preferences, and select the node "web ->
javascript -> include path -> user libraries". Create a new library via
the "New" button. A dialog window pops up. In this dialog window enter a
name for the new library. Then try to click the "OK" button. The button
gets pressed down, but after releasing the mouse button the ok-button
stays pressed down as long as the mouse pointer hovers above this button.
A workaround is to press the space bar after clicking the button. At
least this results in the click getting finished.
I guess some things changed in the way that gtk behaves and since swt
relies on gtk this results in the event handling being broken.
Any ideas?
Yt,
Gunnar
Re: Debian testing, Gnome and Eclipse [message #492094 is a reply to message #492089] Sun, 18 October 2009 11:23 Go to previous messageGo to next message
Hello
It's a well known issue with GTK 2.18 (from which the users of the
upcoming Ubuntu 2009.10 stable release will suffer too). The issues
in that area can easily be found using this bugzilla query:
https://bugs.eclipse.org/bugs/buglist.cgi?quicksearch=gtk+2. 18
The bug
describes a workaround, but I have no clue whether it really helps.
HTH
Michael
Re: Debian testing, Gnome and Eclipse [message #492101 is a reply to message #492094] Sun, 18 October 2009 13:02 Go to previous message
Hello Michael,
thanks for the info! That solution actually did the trick!
Yt,
Gunnar
Michael Pellaton schrieb:
> Hello
> The bug
> HTH
> Michael
Previous Topic:eclipse 3.0 FAQ code examples
Next Topic:Adding external jars to a plug-in properly
Current Time: Tue Sep 09 16:03:06 EDT 2025
Powered by FUDForum. Page generated in 0.07711 seconds
