Home » Archived » Riena » RAP with Riena Remote Service Support(how we can implement or consume services through Riena in RAP)
RAP with Riena Remote Service Support [message #488818] Wed, 30 September 2009 08:17 Go to next message
Hai,
We have just started to design a project using Riena as RCP and web as RAP. And we created sample project in Riena with Remote Services. And successfully implemented client and server part in RienaRCP.
Server:
IUserManagement service = new UserManagement();
context.registerService(IUserManagement.class.getName(), service, null);
Publish.service(IUserManagement.class).usingPath("/IUserManagementService ")
.withProtocol("hessian").andStart(context);
System.out.println("IUserManagementService is registered");
Client Riena:
UserManagementTarget userManagementTarget = new UserManagementTarget();
Inject.service(IUserManagement.class).into(userManagementTar get).andStart(context);
RemoteServiceFactory rsf = new RemoteServiceFactory();
rsf.createAndRegisterProxy(IUserManagement.class,
"http://127.0.0.1/hessian/IUserManagementService", "hessian",
context);
userManagement = userManagementTarget.getUserManagement();
These code are written inside Activator.start() method. And Riena RCP Activator works fine. But same code in RAP Activator is not working.
Hemanth M S
[Updated on: Wed, 30 September 2009 08:53] by Moderator
Re: RAP with Riena Remote Service Support [message #488852 is a reply to message #488818] Wed, 30 September 2009 09:48 Go to previous messageGo to next message
Hi Hemanth,
When running with RAP this means that the Riena Client code is running
on the server?
What exactly happens? Exceptions, logs, ..
Tschüß,
Stefan
Hemanth M S wrote:
> Hai,
> Server:
> service, null);
> System.out.println("IUserManagementSerice is registered");
> Client Riena:
> "hessian",
> context);
> Regards
> Hemanth M S
Re: RAP with Riena Remote Service Support [message #488981 is a reply to message #488852] Thu, 01 October 2009 00:14 Go to previous messageGo to next message
Hi Stefan,
Yes Riena client is running. Sad
org.osgi.framework.BundleException: Exception in org.user.mgmt.rap.Activator.start() of bundle org.user.mgmt.rap.
at org.eclipse.osgi.framework.internal.core.BundleContextImpl.s tartActivator(BundleContextImpl.java:805)
at org.eclipse.osgi.framework.internal.core.BundleContextImpl.s tart(BundleContextImpl.java:754)
at org.eclipse.osgi.framework.internal.core.BundleHost.startWor ker(BundleHost.java:353)
at org.eclipse.osgi.framework.internal.core.AbstractBundle.resu me(AbstractBundle.java:370)
at org.eclipse.osgi.framework.internal.core.Framework.resumeBun dle(Framework.java:1068)
at org.eclipse.osgi.framework.internal.core.StartLevelManager.r esumeBundles(StartLevelManager.java:557)
at org.eclipse.osgi.framework.internal.core.StartLevelManager.i ncFWSL(StartLevelManager.java:464)
at org.eclipse.osgi.framework.internal.core.StartLevelManager.d oSetStartLevel(StartLevelManager.java:248)
at org.eclipse.osgi.framework.internal.core.StartLevelManager.d ispatchEvent(StartLevelManager.java:445)
at org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEve nt(EventManager.java:220)
at org.eclipse.osgi.framework.eventmgr.EventManager$EventThread .run(EventManager.java:330)
Caused by: java.lang.RuntimeException: LazyProxy: missing IRemoteServiceFactory to create proxy for protocol=hessian url=http://localhost/hessian/IUserManagementService interface=org.user.mgmt.common.services.IUserManagement
at org.eclipse.riena.communication.core.factory.RemoteServiceFa ctory$LazyProxyHandler.invoke(RemoteServiceFactory.java:296)
at $Proxy11.getAllUserBeans(Unknown Source)
at org.user.mgmt.rap.Activator.start(Activator.java:46)
at org.eclipse.osgi.framework.internal.core.BundleContextImpl$1 .run(BundleContextImpl.java:782)
at org.eclipse.osgi.framework.internal.core.BundleContextImpl.s tartActivator(BundleContextImpl.java:773)
... 10 more
Root exception:
Thu Oct 01 09:34:55 IST 2009 ERROR [Framework Event Dispatcher] null FrameworkEvent ERROR
Caused by: java.lang.RuntimeException: LazyProxy: missing IRemoteServiceFactory to create proxy for protocol=hessian url=http://localhost/hessian/IUserManagementService interface=org.user.mgmt.common.services.IUserManagementThu Oct 01 09:34:55 IST 2009 INFO [Start Level Event Dispatcher] null {org.eclipse.core.runtime.content.IContentTypeManager}={serv ice.id=47} ServiceEvent REGISTERED
... 10 more
Hemanth M S
Re: RAP with Riena Remote Service Support [message #488982 is a reply to message #488981] Thu, 01 October 2009 01:47 Go to previous messageGo to next message
Hi Hemanth,
One reason for this problem could be that the bundle
org.eclipse.riena.communication.factory.hessian is missing. Can you
check that?
Tschüß,
Stefan
Hemanth M S wrote:
> Hi Stefan,
> Yes Riena client is running. :(
> at java.security.AccessController.doPrivileged(Native Method)
> ... 10 more
> Root exception:
> ... 10 more
> Regards
> Hemanth M S
Re: RAP with Riena Remote Service Support [message #488984 is a reply to message #488982] Thu, 01 October 2009 02:12 Go to previous messageGo to next message
Hi Stefan,
Smile Yes you are right. Now that error has gone. But now comes The "page cannot be displayed...". And log is as follows
osgi> Thu Oct 01 11:32:52 IST 2009 INFO [Framework Event Dispatcher] null {org.osgi.service.log.LogReaderService, org.eclipse.equinox.log.ExtendedLogReaderService}={service.i d=43} ServiceEvent REGISTERED
Thu Oct 01 11:32:52 IST 2009 INFO [Framework Event Dispatcher] null {org.osgi.service.log.LogService, org.eclipse.equinox.log.ExtendedLogService}={service.id=45} ServiceEvent REGISTERED
Thu Oct 01 11:32:52 IST 2009 INFO [Framework Event Dispatcher] org.eclipse.riena.internal.core.StartupsSafeRunnable Startup: 'org.eclipse.equinox.log' succesful.
Thu Oct 01 11:32:52 IST 2009 INFO [DeferredLoggingForwarder] org.eclipse.riena.internal.core.Activator DeferredLogEvent on Thu Oct 01 11:32:52 IST 2009 (1254376972359 ms) in thread [Start Level Event Dispatcher]:
LogLevel(INFO), Message(No stage information set.)
Thu Oct 01 11:32:52 IST 2009 INFO [DeferredLoggingForwarder] org.eclipse.riena.internal.communication.core.ssl.SSLConfigu ration DeferredLogEvent on Thu Oct 01 11:32:52 IST 2009 (1254376972406 ms) in thread [Start Level Event Dispatcher]:
LogLevel(INFO), Message(No configuration given!.)
Thu Oct 01 11:32:52 IST 2009 INFO [Framework Event Dispatcher] null BundleEvent STARTED
Thu Oct 01 11:32:52 IST 2009 INFO [Start Level Event Dispatcher] org.eclipse.riena.communication.core.factory.RemoteServiceFa ctory found protocol [hessian] org.eclipse.riena.internal.communication.factory.hessian.Rem oteServiceFactoryHessian @1162a9c
Thu Oct 01 11:32:52 IST 2009 INFO [Start Level Event Dispatcher] null {org.user.mgmt.common.services.IUserManagement}={service.url =http://localhost/hessian/IUserManagementService, service.protocol=hessian, service.id=46} ServiceEvent REGISTERED
Thu Oct 01 11:32:52 IST 2009 DEBUG [Start Level Event Dispatcher] org.eclipse.riena.internal.communication.core.registry.Remot eServiceRegistry OSGi NEW service registered id: org.user.mgmt.common.services.IUserManagement
[Lorg.user.mgmt.common.beans.UserBean;@1abcd9b
Thu Oct 01 11:32:52 IST 2009 INFO [Start Level Event Dispatcher] null {org.eclipse.core.runtime.content.IContentTypeManager}={serv ice.id=47} ServiceEvent REGISTERED
Thu Oct 01 11:32:52 IST 2009 INFO [Framework Event Dispatcher] null FrameworkEvent STARTED
Thu Oct 01 11:32:52 IST 2009 INFO [Framework Event Dispatcher] null FrameworkEvent STARTLEVEL CHANGED
ss
Framework is launched.
id State Bundle
0 ACTIVE org.eclipse.osgi_3.5.100.v20090803
Fragments=91, 92, 99
3 ACTIVE org.eclipse.equinox.app_1.2.0.v20090520-1800
5 ACTIVE org.eclipse.equinox.registry_3.4.100.v20090520-1800
Fragments=83
7 ACTIVE org.eclipse.core.expressions_3.4.100.v20090429-1800
14 ACTIVE org.eclipse.core.databinding_1.2.0.I20090630-0800
15 ACTIVE org.eclipse.rap.rwt_1.3.0.20090817-1725
Fragments=40
23 ACTIVE org.eclipse.core.jobs_3.4.100.v20090429-1800
28 ACTIVE org.eclipse.equinox.common_3.5.100.v20090727
29 ACTIVE com.ibm.icu.base_4.0.1.v20090415
32 ACTIVE org.eclipse.equinox.http.registry_1.0.200.v20090520-1800
34 ACTIVE org.eclipse.core.commands_3.5.0.I20090525-2000
37 ACTIVE org.eclipse.core.databinding.property_1.2.0.I20090630-0800
38 ACTIVE org.eclipse.rap.ui_1.3.0.20090817-1725
39 ACTIVE org.eclipse.rap.jface_1.3.0.20090817-1725
40 RESOLVED org.eclipse.rap.rwt.q07_1.3.0.20090817-1725
Master=15
44 ACTIVE org.eclipse.rap.ui.workbench_1.3.0.20090817-1725
48 ACTIVE org.eclipse.core.databinding.observable_1.2.0.I20090630-0800
54 ACTIVE org.eclipse.core.runtime_3.5.100.v20090629
55 ACTIVE org.user.mgmt.rap_1.0.0.qualifier
60 ACTIVE org.user.mgmt.common_1.0.0.qualifier
80 ACTIVE org.eclipse.help_3.4.0.v20090526
81 ACTIVE org.eclipse.swt_3.5.0.v3550b
Fragments=93
82 ACTIVE org.eclipse.ui.workbench_3.5.0.I20090603-2000
83 RESOLVED org.eclipse.core.runtime.compatibility.registry_3.2.200.v200 90429-1800
Master=5
84 ACTIVE javax.servlet_2.5.0.v200806031605
85 ACTIVE org.eclipse.ui_3.5.0.I20090604-2000
86 ACTIVE org.eclipse.core.variables_3.2.200.v20090521
87 ACTIVE org.eclipse.jface.databinding_1.3.0.I20090525-2000
88 ACTIVE org.eclipse.equinox.preferences_3.2.300.v20090520-1800
89 ACTIVE org.eclipse.core.contenttype_3.4.0.v20090429-1800
90 ACTIVE org.eclipse.jface_3.5.0.I20090525-2000
91 RESOLVED org.eclipse.persistence.jpa.equinox.weaving_1.1.2.v20090612- r4475
Master=0
92 RESOLVED org.eclipse.equinox.transforms.hook_1.0.100.v20090520-1800
Master=0
93 RESOLVED org.eclipse.swt.win32.win32.x86_3.5.0.v3550b
Master=81
94 ACTIVE org.eclipse.riena.communication.core_1.2.0.200908210731NGT
95 ACTIVE com.caucho.hessian_3.1.3
96 ACTIVE org.eclipse.riena.core_1.2.0.200908210731NGT
97 ACTIVE org.eclipse.osgi.services_3.2.0.v20090520-1800
98 ACTIVE org.eclipse.equinox.log_1.2.0.v20090520-1800
99 RESOLVED javax.transaction_1.1.1.v200909161740
Master=0
106 ACTIVE org.eclipse.riena.communication.factory.hessian_1.2.0.200908 210731NGT
And I am very thankful for your kind response...
Hemanth M S
[Updated on: Thu, 01 October 2009 02:14] by Moderator
Re: RAP with Riena Remote Service Support [message #488993 is a reply to message #488984] Thu, 01 October 2009 03:05 Go to previous messageGo to next message
Hi Hemanth,
Nice! The log looks fine so far. ;-)
But what is this "page cannot be displayed"? Is it an exception, log
message or a dialog?
Tschüß,
Stefan
Hemanth M S wrote:
> Hi Stefan,
> :) Yes you are right. Now that error has gone. But now comes The "page
> REGISTERED
> Dispatcher]:
> BundleEvent STARTED
> BundleEvent STARTED
> protocol [hessian]
> mailto: org.eclipse.riena.internal.communication.factory.hessian.Rem oteServiceFactoryHessian @1162a9c
> BundleEvent STARTED
> BundleEvent STARTED
> BundleEvent STARTED
> BundleEvent STARTED
> BundleEvent STARTED
> BundleEvent STARTED
> BundleEvent STARTED
> BundleEvent STARTED
> BundleEvent STARTED
> Regards
> Hemanth M S
Re: RAP with Riena Remote Service Support [message #489000 is a reply to message #488993] Thu, 01 October 2009 04:05 Go to previous messageGo to next message
Hi Stefan,
Ok I got it. It is because of server is not started. I forgot to select server bundle. After selection
org.eclipse.equinox.http.jetty
org.mortbay.jetty.server
org.mortbay.jetty.util
Now I got the page with following log.
osgi> Thu Oct 01 13:29:42 IST 2009 INFO [Framework Event Dispatcher] null {org.osgi.service.log.LogService, org.eclipse.equinox.log.ExtendedLogService}={service.id=48} ServiceEvent REGISTERED
Thu Oct 01 13:29:42 IST 2009 INFO [Framework Event Dispatcher] org.eclipse.riena.internal.core.StartupsSafeRunnable Startup: 'org.eclipse.equinox.log' succesful.
Thu Oct 01 13:29:42 IST 2009 INFO [Framework Event Dispatcher] null BundleEvent STARTED
Thu Oct 01 13:29:42 IST 2009 INFO [DeferredLoggingForwarder] org.eclipse.riena.internal.core.Activator DeferredLogEvent on Thu Oct 01 13:29:42 IST 2009 (1254383982453 ms) in thread [Start Level Event Dispatcher]:
Thu Oct 01 13:29:42 IST 2009 INFO [DeferredLoggingForwarder] org.eclipse.riena.internal.communication.core.ssl.SSLConfigu ration DeferredLogEvent on Thu Oct 01 13:29:42 IST 2009 (1254383982500 ms) in thread [Start Level Event Dispatcher]:
Thu Oct 01 13:29:42 IST 2009 INFO [Start Level Event Dispatcher] org.eclipse.riena.communication.core.factory.RemoteServiceFa ctory found protocol [hessian] org.eclipse.riena.internal.communication.factory.hessian.Rem oteServiceFactoryHessian @4ac216
Thu Oct 01 13:29:42 IST 2009 INFO [Start Level Event Dispatcher] null {org.user.mgmt.common.services.IUserManagement}={service.url =http://localhost/hessian/IUserManagementService, service.protocol=hessian, service.id=49} ServiceEvent REGISTERED
Thu Oct 01 13:29:42 IST 2009 DEBUG [Start Level Event Dispatcher] org.eclipse.riena.internal.communication.core.registry.Remot eServiceRegistry OSGi NEW service registered id: org.user.mgmt.common.services.IUserManagement
[Lorg.user.mgmt.common.beans.UserBean;@1758500
Thu Oct 01 13:29:42 IST 2009 INFO [Start Level Event Dispatcher] null {org.eclipse.core.runtime.content.IContentTypeManager}={serv ice.id=50} ServiceEvent REGISTERED
Thu Oct 01 13:29:42 IST 2009 INFO [Framework Event Dispatcher] null FrameworkEvent INFO
Thu Oct 01 13:29:43 IST 2009 INFO [Start Level Event Dispatcher] null {org.osgi.service.http.HttpService}={service.description=Equ inox Jetty-based Http Service, service.vendor=Eclipse.org, http.port=2401, service.id=51} ServiceEvent REGISTERED
Thu Oct 01 13:29:43 IST 2009 INFO [Start Level Event Dispatcher] null {org.osgi.service.cm.ManagedServiceFactory}={service.pid=org .eclipse.equinox.http.jetty.config, service.id=52} ServiceEvent REGISTERED
Thu Oct 01 13:29:43 IST 2009 INFO [Framework Event Dispatcher] null BundleEvent STARTED
Thu Oct 01 13:29:43 IST 2009 INFO [Framework Event Dispatcher] null FrameworkEvent STARTED
Thu Oct 01 13:29:43 IST 2009 INFO [Framework Event Dispatcher] null FrameworkEvent STARTLEVEL CHANGED
!SESSION 2009-10-01 13:29:39.937 -----------------------------------------------
eclipse.buildId=unknown
java.version=1.6.0_16
Command-line arguments: -dev file:F:/latest downloads/eclipse/workspace/.metadata/.plugins/org.eclipse.p de.core/org.user.mgmt.rap/dev.properties -os win32 -ws win32 -arch x86 -console -consolelog
!ENTRY org.eclipse.osgi 2 0 2009-10-01 13:29:43.656
!MESSAGE The following is a complete list of bundles which are not resolved, see the prior log entry for the root cause if it exists:
!SUBENTRY 1 org.eclipse.osgi 2 0 2009-10-01 13:29:43.656
!MESSAGE Bundle org.eclipse.core.runtime_3.5.100.v20090629 [168] was not resolved.
!SUBENTRY 2 org.eclipse.core.runtime 2 0 2009-10-01 13:29:43.656
!MESSAGE Missing optionally required bundle org.eclipse.core.runtime.compatibility.auth_[3.2.0,4.0.0).
!MESSAGE Missing imported package org.eclipse.core.internal.runtime.auth_0.0.0.
!ENTRY org.eclipse.rap.ui 4 0 2009-10-01 13:29:51.093
!MESSAGE Source Provider 'org.eclipse.ui.internal.services.WorkbenchSourceProvider' should extend AbstractSourceProvider
Thu Oct 01 13:29:51 IST 2009 ERROR [UIThread [12awl37xa5vk6]] Bundle org.eclipse.core.runtime Message: Source Provider 'org.eclipse.ui.internal.services.WorkbenchSourceProvider' should extend AbstractSourceProvider, Code: 0, Plugin: org.eclipse.rap.ui
Thu Oct 01 13:29:51 IST 2009 ERROR [UIThread [12awl37xa5vk6]] Bundle org.eclipse.core.runtime Message: Source Provider 'org.eclipse.ui.internal.services.ActionSetSourceProvider' should extend AbstractSourceProvider, Code: 0, Plugin: org.eclipse.rap.ui
!MESSAGE Source Provider 'org.eclipse.ui.internal.services.ActionSetSourceProvider' should extend AbstractSourceProvider
Thu Oct 01 13:29:51 IST 2009 ERROR [UIThread [12awl37xa5vk6]] Bundle org.eclipse.core.runtime Message: Source Provider 'org.eclipse.ui.internal.menus.FocusControlSourceProvider' should extend AbstractSourceProvider, Code: 0, Plugin: org.eclipse.rap.ui
Thu Oct 01 13:29:51 IST 2009 ERROR [UIThread [12awl37xa5vk6]] Bundle org.eclipse.core.runtime Message: Source Provider 'org.eclipse.ui.internal.services.MenuSourceProvider' should extend AbstractSourceProvider, Code: 0, Plugin: org.eclipse.rap.ui
!MESSAGE Source Provider 'org.eclipse.ui.internal.menus.FocusControlSourceProvider' should extend AbstractSourceProvider
!ENTRY org.eclipse.rap.ui 4 0 2009-10-01 13:29:51.109
!MESSAGE Source Provider 'org.eclipse.ui.internal.services.MenuSourceProvider' should extend AbstractSourceProvider
!MESSAGE Source Provider 'org.eclipse.ui.internal.contexts.ActiveContextSourceProvide r' should extend AbstractSourceProvider
Thu Oct 01 13:29:51 IST 2009 ERROR [UIThread [12awl37xa5vk6]] Bundle org.eclipse.core.runtime Message: Source Provider 'org.eclipse.ui.internal.contexts.ActiveContextSourceProvide r' should extend AbstractSourceProvider, Code: 0, Plugin: org.eclipse.rap.ui
!ENTRY org.eclipse.ui.workbench 2 0 2009-10-01 13:29:51.140
!MESSAGE A handler conflict occurred. This may disable some commands.
!SUBENTRY 1 org.eclipse.ui.workbench 2 0 2009-10-01 13:29:51.140
!MESSAGE Conflict for 'org.eclipse.ui.newWizard':
HandlerActivation(commandId=org.eclipse.ui.newWizard,
handler=org.eclipse.ui.internal.handlers.WizardHandler$New,
expression=,sourcePriority=0)
handler=org.eclipse.ui.internal.handlers.WizardHandler$New@177ab84,
Thu Oct 01 13:29:51 IST 2009 WARNING [UIThread [12awl37xa5vk6]] Bundle org.eclipse.core.runtime Message: A handler conflict occurred. This may disable some commands., Code: 0, Plugin: org.eclipse.ui.workbench
!ENTRY org.eclipse.ui.workbench 2 0 2009-10-01 13:29:51.156
!SUBENTRY 1 org.eclipse.ui.workbench 2 0 2009-10-01 13:29:51.156
!MESSAGE Conflict for 'org.eclipse.ui.file.import':
HandlerActivation(commandId=org.eclipse.ui.file.import,
handler=org.eclipse.ui.internal.handlers.WizardHandler$Impor t,
handler=org.eclipse.ui.internal.handlers.WizardHandler$Import@44b7f7,
expression=,sourcePriority=0)Thu Oct 01 13:29:51 IST 2009 WARNING [UIThread [12awl37xa5vk6]] Bundle org.eclipse.core.runtime Message: A handler conflict occurred. This may disable some commands., Code: 0, Plugin: org.eclipse.ui.workbench
!MESSAGE Conflict for 'org.eclipse.ui.file.export':
HandlerActivation(commandId=org.eclipse.ui.file.export,
handler=org.eclipse.ui.internal.handlers.WizardHandler$Export@ebaf12,
handler=org.eclipse.ui.internal.handlers.WizardHandler$Expor t,
!MESSAGE Conflict for 'org.eclipse.ui.file.properties':
HandlerActivation(commandId=org.eclipse.ui.file.properties,
handler=org.eclipse.ui.internal.handlers.PropertyDialogHandl er,
handler=org.eclipse.ui.internal.handlers.PropertyDialogHandler@14b03ea,
!MESSAGE Conflict for 'org.eclipse.ui.file.exit':
HandlerActivation(commandId=org.eclipse.ui.file.exit,
handler=org.eclipse.ui.internal.handlers.QuitHandler@77a748,
handler=org.eclipse.ui.internal.handlers.QuitHandler,
!ENTRY org.eclipse.ui.workbench 2 0 2009-10-01 13:29:51.234
!SUBENTRY 1 org.eclipse.ui.workbench 2 0 2009-10-01 13:29:51.234
!MESSAGE Conflict for 'org.eclipse.ui.window.switchToEditor':
HandlerActivation(commandId=org.eclipse.ui.window.switchToEd itor,
handler=org.eclipse.ui.internal.WorkbenchEditorsHandler,
handler=org.eclipse.ui.internal.WorkbenchEditorsHandler@f84b0a,
!ENTRY org.eclipse.ui.workbench 2 0 Thu Oct 01 13:29:51 IST 2009 WARNING [UIThread [12awl37xa5vk6]] Bundle org.eclipse.core.runtime Message: A handler conflict occurred. This may disable some commands., Code: 0, Plugin: org.eclipse.ui.workbench
!MESSAGE Conflict for 'org.eclipse.ui.window.minimizePart':
HandlerActivation(commandId=org.eclipse.ui.window.minimizePa rt,
handler=org.eclipse.ui.internal.handlers.MinimizePartHandler ,
handler=org.eclipse.ui.internal.handlers.MinimizePartHandler@15ee9e3,
!MESSAGE Conflict for 'org.eclipse.ui.file.closePart':
HandlerActivation(commandId=org.eclipse.ui.file.closePart,
handler=org.eclipse.ui.internal.handlers.ClosePartHandler,
handler=org.eclipse.ui.internal.handlers.ClosePartHandler@1f94a1f,
!ENTRY org.eclipse.ui.workbench 2 0 2009-10-01 13:29:51.250
!SUBENTRY 1 org.eclipse.ui.workbench 2 0 2009-10-01 13:29:51.250
!MESSAGE Conflict for 'org.eclipse.ui.window.preferences':
HandlerActivation(commandId=org.eclipse.ui.window.preference s,
handler=org.eclipse.ui.internal.handlers.ShowPreferencePageH andler,
handler=org.eclipse.ui.internal.handlers.ShowPreferencePageHandler@1d318f,
!MESSAGE Conflict for 'org.eclipse.ui.views.showView':
HandlerActivation(commandId=org.eclipse.ui.views.showView,
handler=org.eclipse.ui.handlers.ShowViewHandler@1b0c08,
handler=org.eclipse.ui.handlers.ShowViewHandler,
!MESSAGE Conflict for 'org.eclipse.ui.perspectives.showPerspective':
HandlerActivation(commandId=org.eclipse.ui.perspectives.show Perspective,
handler=org.eclipse.ui.handlers.ShowPerspectiveHandler,
handler=org.eclipse.ui.handlers.ShowPerspectiveHandler@a9509d,
!MESSAGE Conflict for 'org.eclipse.ui.navigate.showIn':
HandlerActivation(commandId=org.eclipse.ui.navigate.showIn,
handler=org.eclipse.ui.internal.ShowInHandler@16528a2,
handler=org.eclipse.ui.internal.ShowInHandler,
!ENTRY org.eclipse.ui.workbench 2 0 2009-10-01 13:29:51.281
!SUBENTRY 1 org.eclipse.ui.workbench 2 0 2009-10-01 13:29:51.281
!MESSAGE Conflict for 'org.eclipse.ui.window.activateEditor':
HandlerActivation(commandId=org.eclipse.ui.window.activateEd itor,
handler=org.eclipse.ui.internal.ActivateEditorHandler,
!MESSAGE Conflict for 'org.eclipse.ui.window.showSystemMenu':
HandlerActivation(commandId=org.eclipse.ui.window.showSystem Menu,
handler=org.eclipse.ui.internal.ShowPartPaneMenuHandler,
!SUBENTRY 1 org.eclipse.ui.workbench 2 0 2009-10-01 13:29:51.296
!MESSAGE Conflict for 'org.eclipse.ui.window.showViewMenu':
HandlerActivation(commandId=org.eclipse.ui.window.showViewMe nu,
handler=org.eclipse.ui.internal.ShowViewMenuHandler,
!ENTRY org.eclipse.ui.workbench 2 0 2009-10-01 13:29:51.296
!MESSAGE Conflict for 'org.eclipse.ui.file.close':
HandlerActivation(commandId=org.eclipse.ui.file.close,
handler=org.eclipse.ui.internal.CloseEditorHandler,
!ENTRY org.eclipse.ui.workbench 2 0 2009-10-01 13:29:51.312
!SUBENTRY 1 org.eclipse.ui.workbench 2 0 2009-10-01 13:29:51.312
!MESSAGE Conflict for 'org.eclipse.ui.file.closeAll':
HandlerActivation(commandId=org.eclipse.ui.file.closeAll,
handler=org.eclipse.ui.internal.CloseAllHandler,
!MESSAGE Conflict for 'org.eclipse.ui.file.closeOthers':
HandlerActivation(commandId=org.eclipse.ui.file.closeOthers,
handler=org.eclipse.ui.internal.CloseOthersHandler,
!SUBENTRY 1 org.eclipse.ui.workbench 2 0Thu Oct 01 13:29:51 IST 2009 WARNING [UIThread [12awl37xa5vk6]] Bundle org.eclipse.core.runtime Message: A handler conflict occurred. This may disable some commands., Code: 0, Plugin: org.eclipse.ui.workbench
!MESSAGE Conflict for 'org.eclipse.ui.ToggleCoolbarAction':
HandlerActivation(commandId=org.eclipse.ui.ToggleCoolbarActi on,
handler=org.eclipse.ui.internal.handlers.ToggleCoolbarHandle r,
!SUBENTRY 1 org.eclipse.ui.workbench 2 0 2009-10-01 13:29:51.328
!MESSAGE Conflict for 'org.eclipse.ui.window.nextEditor':
HandlerActivation(commandId=org.eclipse.ui.window.nextEditor ,
handler=org.eclipse.ui.internal.CycleEditorHandler:true,
!ENTRY org.eclipse.ui.workbench 2 0 2009-10-01 13:29:51.328
!MESSAGE Conflict for 'org.eclipse.ui.window.previousEditor':
HandlerActivation(commandId=org.eclipse.ui.window.previousEd itor,
handler=org.eclipse.ui.internal.CycleEditorHandler:false,
!MESSAGE Conflict for 'org.eclipse.ui.window.nextView':
HandlerActivation(commandId=org.eclipse.ui.window.nextView,
handler=org.eclipse.ui.internal.CycleViewHandler:true,
!MESSAGE Conflict for 'org.eclipse.ui.window.previousView':
HandlerActivation(commandId=org.eclipse.ui.window.previousVi ew,
handler=org.eclipse.ui.internal.CycleViewHandler:false,
!MESSAGE Conflict for 'org.eclipse.ui.window.nextPerspective':
HandlerActivation(commandId=org.eclipse.ui.window.nextPerspe ctive,
handler=org.eclipse.ui.internal.CyclePerspectiveHandler:true ,
!MESSAGE Conflict for 'org.eclipse.ui.window.previousPerspective':
HandlerActivation(commandId=org.eclipse.ui.window.previousPe rspective,
handler=org.eclipse.ui.internal.CyclePerspectiveHandler:fals e,
!MESSAGE Conflict for 'org.eclipse.ui.window.closeAllPerspectives':
HandlerActivation(commandId=org.eclipse.ui.window.closeAllPe rspectives,
handler=org.eclipse.ui.internal.handlers.CloseAllPerspective sHandler,
!ENTRY org.eclipse.ui.workbench 2 0 2009-10-01 13:29:51.343
!SUBENTRY 1 org.eclipse.ui.workbench 2 0 2009-10-01 13:29:51.343
!MESSAGE Conflict for 'org.eclipse.ui.window.customizePerspective':
HandlerActivation(commandId=org.eclipse.ui.window.customizeP erspective,
handler=org.eclipse.ui.internal.handlers.EditActionSetsHandl er,
!MESSAGE Conflict for 'org.eclipse.ui.window.closePerspective':
HandlerActivation(commandId=org.eclipse.ui.window.closePersp ective,
handler=org.eclipse.ui.internal.handlers.ClosePerspectiveHan dler,
!MESSAGE Conflict for 'org.eclipse.ui.window.openEditorDropDown':
HandlerActivation(commandId=org.eclipse.ui.window.openEditor DropDown,
handler=org.eclipse.ui.internal.WorkbookEditorsHandler,
!MESSAGE Conflict for 'org.eclipse.ui.window.newEditor':
HandlerActivation(commandId=org.eclipse.ui.window.newEditor,
handler=org.eclipse.ui.internal.handlers.NewEditorHandler,
!MESSAGE Conflict for 'org.eclipse.ui.window.maximizePart':
HandlerActivation(commandId=org.eclipse.ui.window.maximizePa rt,
handler=org.eclipse.ui.internal.handlers.MaximizePartHandler ,
!ENTRY org.eclipse.rap.ui 4 4 2009-10-01 13:29:51.390
!MESSAGE Could not create color factory.
Thu Oct 01 13:29:51 IST 2009 ERROR [UIThread [12awl37xa5vk6]] Bundle org.eclipse.core.runtime Message: Could not create color factory., Code: 4, Plugin: org.eclipse.rap.ui
!ENTRY org.eclipse.equinox.registry 4 1 2009-10-01 13:29:51.406
!MESSAGE Plug-in "org.eclipse.ui" was unable to instantiate class "org.eclipse.ui.internal.themes.LightColorFactory".
!STACK 0
java.lang.ExceptionInInitializerError
at sun.reflect.NativeConstructorAccessorImpl.newInstance0(Nativ e Method)
at sun.reflect.NativeConstructorAccessorImpl.newInstance(Unknow n Source)
at sun.reflect.DelegatingConstructorAccessorImpl.newInstance(Un known Source)
at java.lang.reflect.Constructor.newInstance(Unknown Source)
at java.lang.Class.newInstance0(Unknown Source)
at java.lang.Class.newInstance(Unknown Source)
at org.eclipse.core.internal.registry.osgi.RegistryStrategyOSGI .createExecutableExtension(RegistryStrategyOSGI.java:170)
at org.eclipse.core.internal.registry.ExtensionRegistry.createE xecutableExtension(ExtensionRegistry.java:874)
at org.eclipse.core.internal.registry.ConfigurationElement.crea teExecutableExtension(ConfigurationElement.java:243)
at org.eclipse.core.internal.registry.ConfigurationElementHandl e.createExecutableExtension(ConfigurationElementHandle.java: 51)
at org.eclipse.ui.internal.themes.ThemeRegistryReader.checkColo rFactory(ThemeRegistryReader.java:406)
at org.eclipse.ui.internal.themes.ThemeRegistryReader.getColorV alue(ThemeRegistryReader.java:183)
at org.eclipse.ui.internal.themes.ThemeRegistryReader.readColor (ThemeRegistryReader.java:139)
at org.eclipse.ui.internal.themes.ThemeRegistryReader.readEleme nt(ThemeRegistryReader.java:239)
at org.eclipse.ui.internal.registry.RegistryReader.readElements (RegistryReader.java:144)
at org.eclipse.ui.internal.registry.RegistryReader.readExtensio n(RegistryReader.java:155)
at org.eclipse.ui.internal.registry.RegistryReader.readRegistry (RegistryReader.java:176)
at org.eclipse.ui.internal.themes.ThemeRegistryReader.readTheme s(ThemeRegistryReader.java:458)
at org.eclipse.ui.internal.WorkbenchPlugin$ThemeRegistryStore.<init >(WorkbenchPlugin.java:149)
at org.eclipse.rwt.SessionSingletonBase.getInstanceInternal(Ses sionSingletonBase.java:154)
at org.eclipse.rwt.SessionSingletonBase.getInstance(SessionSing letonBase.java:91)
at org.eclipse.ui.internal.WorkbenchPlugin$ThemeRegistryStore.g etInstance(WorkbenchPlugin.java:142)
at org.eclipse.ui.internal.WorkbenchPlugin.getThemeRegistry(Wor kbenchPlugin.java:876)
at org.eclipse.ui.internal.Workbench$29.runWithException(Workbe nch.java:1428)
at org.eclipse.ui.internal.StartupThreading$StartupRunnable.run (StartupThreading.java:32)
at org.eclipse.rwt.internal.lifecycle.UICallBackManager.addSync (UICallBackManager.java:115)
at org.eclipse.swt.widgets.Display$2.run(Display.java:696)
at org.eclipse.rwt.internal.lifecycle.UICallBackServiceHandler. runNonUIThreadWithFakeContext(UICallBackServiceHandler.java: 460)
at org.eclipse.rwt.lifecycle.UICallBack.runNonUIThreadWithFakeC ontext(UICallBack.java:44)
at org.eclipse.swt.widgets.Display.syncExec(Display.java:694)
at org.eclipse.ui.internal.StartupThreading.runWithoutException s(StartupThreading.java:110)
at org.eclipse.ui.internal.Workbench.initializeFonts(Workbench. java:1424)
at org.eclipse.ui.internal.Workbench.init(Workbench.java:1304)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2320)
at org.eclipse.ui.internal.Workbench.access$5(Workbench.java:22 09)
at org.eclipse.ui.internal.Workbench$4.run(Workbench.java:427)
at org.eclipse.ui.internal.RealmAdapterHook.runWithDefault(Real mAdapterHook.java:48)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:430)
at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.j ava:157)
at org.user.mgmt.rap.Application.createUI(Application.java:17)
at org.eclipse.rwt.internal.lifecycle.EntryPointManager.createU I(EntryPointManager.java:92)
at org.eclipse.rwt.internal.lifecycle.RWTLifeCycle.createUI(RWT LifeCycle.java:231)
at org.eclipse.rwt.internal.lifecycle.RWTLifeCycle$UIThreadCont roller.run(RWTLifeCycle.java:119)
at org.eclipse.ui.themes.ColorUtil.getSystemColor(ColorUtil.jav a:152)
at org.eclipse.ui.themes.ColorUtil.process(ColorUtil.java:47)
at org.eclipse.ui.themes.ColorUtil.getColorValue(ColorUtil.java :172)
at org.eclipse.ui.internal.themes.LightColorFactory.<clinit>(LightColorFactory.java:33)
... 48 more
Thu Oct 01 13:29:51 IST 2009 ERROR [UIThread [12awl37xa5vk6]] Bundle org.eclipse.core.runtime Message: Plug-in "org.eclipse.ui" was unable to instantiate class "org.eclipse.ui.internal.themes.LightColorFactory"., Code: 1, Plugin: org.eclipse.equinox.registry
!ENTRY org.eclipse.rap.ui 4 4 2009-10-01 13:29:51.406
!MESSAGE Plugin org.eclipse.ui, extension org.eclipse.ui.themes, id org.eclipse.ui.workbench.ACTIVE_TAB_TEXT_COLOR: Only one of value or defaultMapping may be set.
... 48 more
Thu Oct 01 13:29:51 IST 2009 ERROR [UIThread [12awl37xa5vk6]] Bundle org.eclipse.core.runtime Message: Plugin org.eclipse.ui, extension org.eclipse.ui.themes, id org.eclipse.ui.workbench.ACTIVE_TAB_TEXT_COLOR: Only one of value or defaultMapping may be set., Code: 4, Plugin: org.eclipse.rap.ui
!STACK 0
java.lang.NoClassDefFoundError: Could not initialize class org.eclipse.ui.internal.themes.LightColorFactory
Thu Oct 01 13:29:51 IST 2009 ERROR [UIThread [12awl37xa5vk6]] Bundle org.eclipse.core.runtime Message: Plugin org.eclipse.ui, extension org.eclipse.ui.themes, id org.eclipse.ui.workbench.ACTIVE_TAB_BG_END: Only one of value or defaultMapping may be set., Code: 4, Plugin: org.eclipse.rap.ui
!ENTRY org.eclipse.rap.ui 4 4 2009-10-01 13:29:51.421
!MESSAGE Plugin org.eclipse.ui, extension org.eclipse.ui.themes, id org.eclipse.ui.workbench.ACTIVE_TAB_BG_END: Only one of value or defaultMapping may be set.
!ENTRY org.eclipse.equinox.registry 4 1 2009-10-01 13:29:51.421
!STACK 0
at
[Updated on: Thu, 01 October 2009 04:09] by Moderator
Re: RAP with Riena Remote Service Support [message #489019 is a reply to message #489000] Thu, 01 October 2009 04:55 Go to previous messageGo to next message
it looks like you have both org.eclipse.rap.ui.workbench and
org.eclipse.ui.workbench in your launc configuration. Please be sure to
either have the RCP plugins *or* the RAP plugins in your target / launch
config to prevent these errors. Due to the architecture of Equinox it's
not possible to have them run in the same configuration together.
Ben
Hemanth M S wrote:
> Hi Stefan,
> REGISTERED
> BundleEvent STARTED
> BundleEvent STARTED
> BundleEvent STARTED
> Dispatcher]:
> protocol [hessian]
> mailto: org.eclipse.riena.internal.communication.factory.hessian.Rem oteServiceFactoryHessian @4ac216
> BundleEvent STARTED
> BundleEvent STARTED
> BundleEvent STARTED
> BundleEvent STARTED
> BundleEvent STARTED
> BundleEvent STARTED
> BundleEvent STARTED
> BundleEvent STARTED
> BundleEvent STARTED
> BundleEvent STARTED
> FrameworkEvent INFO
> BundleEvent STARTED
> BundleEvent STARTED
> BundleEvent STARTED
> BundleEvent STARTED
> BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=en_US
> resolved.
> handler=org.eclipse.ui.internal.handlers.WizardHandler$mailt o:New@177ab84,
> handler=org.eclipse.ui.internal.handlers.WizardHandler$mailt o:Import@44b7f7,
> handler=org.eclipse.ui.internal.handlers.WizardHandler$mailt o:Export@ebaf12,
> handler=mailto:org.eclipse.ui.internal.handlers.PropertyDialogHandler@14b03ea,
> handler=mailto:org.eclipse.ui.internal.handlers.QuitHandler@77a748,
> handler=mailto:org.eclipse.ui.internal.WorkbenchEditorsHandler@f84b0a,
> handler=mailto:org.eclipse.ui.internal.handlers.MinimizePartHandler@15ee9e3,
> handler=mailto:org.eclipse.ui.internal.handlers.ClosePartHandler@1f94a1f,
> handler=mailto:org.eclipse.ui.internal.handlers.ShowPreferencePageHandler@1d318f,
> handler=mailto:org.eclipse.ui.handlers.ShowViewHandler@1b0c08,
> handler=mailto:org.eclipse.ui.handlers.ShowPerspectiveHandler@a9509d,
> handler=mailto:org.eclipse.ui.internal.ShowInHandler@16528a2,
> !STACK 0
> Method)
> Source)
> known Source)
> Method)
> Source)
> known Source)
> letonBase.java:91)
> nch.java:1428)
> java:1424)
> bench.java:430)
> ava:157)
> LifeCycle.java:231)
> at
> ... 48 more
> Method)
> Source)
> known Source)
> Method)
> Source)
> known Source)
> letonBase.java:91)
> nch.java:1428)
> java:1424)
> bench.java:430)
> ava:157)
> LifeCycle.java:231)
> at
> ... 48 more
> !STACK 0
> Method)
> Source)
> known Source)
> Method)
> Source)
> known Source)
> letonBase.java:91)
> nch.java:1428)
> java:1424)
> bench.java:430)
> ava:157)
> LifeCycle.java:231)
> Method)
> Source)
> known Source)
> Method)
> Source)
> known Source)
> letonBase.java:91)
> nch.java:1428)
> java:1424)
Re: RAP with Riena Remote Service Support [message #489037 is a reply to message #489000] Thu, 01 October 2009 05:40 Go to previous messageGo to next message
Hi Hemanth,
Hemanth M S wrote:
> Hi Stefan,
Argh, I didn´t see that! It is so easy to forget it ;-)
Tschüß,
Stefan
Re: RAP with Riena Remote Service Support [message #489057 is a reply to message #489037] Thu, 01 October 2009 07:51 Go to previous messageGo to next message
Hi Ben & Stefan,
First of all hearty thanks for your great support Smile
Now I have created two work space and two Target Platform one for RCP and one for RAP.
And I have invoked Web Service successfully from RAP. But I got another exception while showing page.
2009-10-01 17:09:41.484::WARN: ERROR: /rap
java.lang.IllegalArgumentException: An entry point named 'userMgmt' does not exist.
at org.eclipse.rwt.internal.lifecycle.EntryPointManager.createU I(EntryPointManager.java:77)
My plugin.xml looks like this
<extension
point="org.eclipse.rap.ui.entrypoint">
<entrypoint
class="org.user.mgmt.rap.Application"
parameter="userMgmt"
id="org.user.mgmt.rap.Application">
</entrypoint>
</extension>
<extension
point="org.eclipse.ui.perspectives">
<perspective
name="RAP Perspective"
class="org.user.mgmt.rap.Perspective"
id="org.user.mgmt.rap.perspective">
</perspective>
</extension>
I am not able to find out, why its coming? Sad
Hemanth M S
[Updated on: Thu, 01 October 2009 08:17] by Moderator
Re: RAP with Riena Remote Service Support [message #489083 is a reply to message #489057] Thu, 01 October 2009 09:19 Go to previous messageGo to next message
Hi Hemanth,
are you sure you have your application bundle in the launch config?
You said you get the exception *and* the RAP app is running? Because the
exceptions only says that there is no entrypoint - so naturally this
means you can't even access the application.
Ben
Hemanth M S wrote:
> Hi Ben & Stefan,
> First of all hearty thanks for your great support :)
> Now I have created two work space and Target Platform one for RCP and
> one for RAP.
> not exist.
> LifeCycle.java:231)
> <extension
> <entrypoint
> </entrypoint>
> </extension>
> <extension
> <perspective
> </perspective>
> </extension>
> I am not able to find out, why its coming? :(
> Regards
> Hemanth M S
Benjamin Muskalla | EclipseSource Karlsruhe
http://www.eclipsesource.com | http://twitter.com/eclipsesource
Re: RAP with Riena Remote Service Support [message #489106 is a reply to message #489083] Thu, 01 October 2009 10:14 Go to previous messageGo to next message
Hi Ben,
RAP Activator worked fine and even started to load page, then got exception
This is the launch config
<?xml version="1.0" encoding="UTF-8" standalone="no"?>
<launchConfiguration type="org.eclipse.rap.ui.launch.RAPLauncher">
<booleanAttribute key="append.args" value="true"/>
<booleanAttribute key="automaticAdd" value="true"/>
<booleanAttribute key="automaticValidate" value="false"/>
<stringAttribute key="bootstrap" value=""/>
<stringAttribute key="checked" value="[NONE]"/>
<booleanAttribute key="clearConfig" value="false"/>
<stringAttribute key="configLocation" value=" ${workspace_loc}/.metadata/.plugins/org.eclipse.pde.core/org .user.mgmt.rap "/>
<booleanAttribute key="default_auto_start" value="true"/>
<intAttribute key="default_start_level" value="4"/>
<booleanAttribute key="includeOptional" value="true"/>
<stringAttribute key="org.eclipse.jdt.launching.PROGRAM_ARGUMENTS" value="-os ${target.os} -ws ${target.ws} -arch ${target.arch} -nl ${target.nl} -console"/>
<stringAttribute key="org.eclipse.jdt.launching.SOURCE_PATH_PROVIDER" value="org.eclipse.pde.ui.workbenchClasspathProvider"/>
<stringAttribute key="org.eclipse.jdt.launching.VM_ARGUMENTS" value="-Declipse.ignoreApp=true -Dosgi.noShutdown=true"/>
<stringAttribute key="org.eclipse.rap.launch.browserMode" value="INTERNAL"/>
<stringAttribute key="org.eclipse.rap.launch.entryPoint" value="userMgmt"/>
<stringAttribute key="org.eclipse.rap.launch.libraryVariant" value="STANDARD"/>
<stringAttribute key="org.eclipse.rap.launch.logLevel" value="OFF"/>
<booleanAttribute key="org.eclipse.rap.launch.openBrowser" value="true"/>
<intAttribute key="org.eclipse.rap.launch.port" value="10080"/>
<stringAttribute key="org.eclipse.rap.launch.servletName" value="rap"/>
<booleanAttribute key="org.eclipse.rap.launch.terminatePrevious" value="true"/>
<booleanAttribute key="org.eclipse.rap.launch.useManualPort" value="false"/>
<stringAttribute key="pde.version" value="3.3"/>
<booleanAttribute key="show_selected_only" value="false"/>
<stringAttribute key="target_bundles" value="org.eclipse.swt@default:default,org.eclipse.core.commands*
3.5.0.I20090525-2000@default:default,org.eclipse.osgi*3.5.0.v20090520@-
1
:true,org.eclipse.core.databinding.observable*
1.2.0.I20090604-2000@default:default,org.eclipse.equinox.registry*
3.4.100.v20090520-1800@default:default,
org.eclipse.jface.databinding@default:default,org.eclipse.equinox.http.servlet*
1.0.200.v20090520-1800@default:default,org.eclipse.osgi*3.5.100.v20090803@-
1
:true,org.eclipse.core.runtime*3.5.0.v20090525@default:true,
org.eclipse.equinox.transforms.hook@default:false,org.eclipse.swt.win32.win32.x86@default:false,
org.eclipse.help@default:default,org.eclipse.equinox.preferences*
3.2.300.v20090520-1800@default:default,org.eclipse.core.jobs*
3.4.100.v20090429-1800@default:default,
org.eclipse.rap.ui@default:default,org.eclipse.core.databinding.observable*
1.2.0.I20090630-0800@default:default,
org.eclipse.equinox.log@default:default,org.eclipse.core.jobs*3.4.100.v20090429-1800@default:default,
org.eclipse.rap.rwt@default:default,org.apache.log4j@default:default,com.ibm.icu.base@default:default,org.eclipse.jface@default:default,org.eclipse.core.expressions*
3.4.100.v20090429-1800@default:default,org.eclipse.equinox.http.registry*
1.0.200.v20090520-1800@default:default,org.eclipse.core.databinding*
1.2.0.I20090630-0800@default:default,org.eclipse.core.commands*
org.eclipse.rap.jface.databinding@default:default,org.eclipse.core.expressions*
3.4.100.v20090429-1800@default:default,org.eclipse.rap.jface@default:default,
com.ibm.icu@default:default,org.eclipse.core.contenttype*3.4.0.v20090429-1800@default:default,
org.user.mgmt.common@default:default,org.eclipse.equinox.http.jetty*
2.0.0.v20090520-1800@default:default,org.eclipse.osgi.services*
3.2.0.v20090520-1800@default:default,org.eclipse.equinox.http.jetty*
org.eclipse.riena.communication.factory.hessian@default:default,org.eclipse.core.databinding*
1.2.0.I20090604-2000@default:default,org.mortbay.jetty.util*6.1.15.v200905182336@default:default
,org.user.mgmt.ws@default:default,org.eclipse.equinox.app*
1.2.0.v20090520-1800@default:default,org.eclipse.core.databinding.property*
1.2.0.I20090630-0800@default:default,org.eclipse.equinox.http.registry*
1.0.200.v20090520-1800@default:default,org.eclipse.rap.ui.workbench@default:default,
com.caucho.hessian@default:default,org.eclipse.equinox.common*3.5.100.v20090727@2:true,
org.eclipse.rap.rwt.q07@default:false,org.eclipse.core.contenttype*
3.4.0.v20090429-1800@default:default,javax.servlet*
2.5.0.v200806031605@default:default,org.eclipse.equinox.registry*
3.4.100.v20090520-1800@default:default,org.mortbay.jetty.server*
6.1.15.v200905151201@default:default,javax.servlet*2.5.0.v200806031605@default:default,
org.eclipse.equinox.security@default:default,
org.eclipse.core.runtime.compatibility.auth@default:default,org.eclipse.equinox.common*
3.5.0.v20090520-1800@2:true,org.mortbay.jetty.server*6.1.15.v200905151201@default:default,
org.eclipse.riena.core@default:default,org.eclipse.core.databinding.property*
1.2.0.I20090526-2000@default:default,org.eclipse.core.net@default:default,
javax.servlet.jsp@default:default,org.eclipse.equinox.app*
1.2.0.v20090520-1800@default:default,org.eclipse.osgi.services*
org.eclipse.equinox.security.win32.x86@default:false,org.eclipse.equinox.preferences*
3.2.300.v20090520-1800@default:default,org.eclipse.equinox.http.servlet*
1.0.200.v20090520-1800@default:default,org.mortbay.jetty.util*
6.1.15.v200905182336@default:default,org.eclipse.core.variables@default:default,
org.eclipse.riena.communication.core@default:default"/>
<booleanAttribute key="tracing" value="false"/>
<booleanAttribute key="useDefaultConfigArea" value="true"/>
<stringAttribute key="workspace_bundles" value="org.user.mgmt.rap@default:default"/>
</launchConfiguration>
What should I do other than this? Sad
Hemanth M S
[Updated on: Thu, 01 October 2009 11:21] by Moderator
Re: RAP with Riena Remote Service Support [message #489166 is a reply to message #489106] Thu, 01 October 2009 12:38 Go to previous messageGo to next message
Hi Ben & Stefan,
Now its working, Selected bundles freshly. Thank you for your kind support....
Hemanth M S
Re: RAP with Riena Remote Service Support [message #583689 is a reply to message #488852] Thu, 01 October 2009 00:14 Go to previous messageGo to next message
Hi Stefan,
... 10 more
Root exception:
... 10 more
Hemanth M S
Re: RAP with Riena Remote Service Support [message #583709 is a reply to message #583689] Thu, 01 October 2009 01:47 Go to previous messageGo to next message
Hi Hemanth,
check that?
Tschüß,
Stefan
Hemanth M S wrote:
> Hi Stefan,
> ... 10 more
> Root exception:
> ... 10 more
> Regards
> Hemanth M S
Re: RAP with Riena Remote Service Support [message #583729 is a reply to message #488982] Thu, 01 October 2009 02:12 Go to previous messageGo to next message
Hi Stefan,
:) Yes you are right. Now that error has gone. But now comes The "page cannot be displayed...". And log is as follows
Thu Oct 01 11:32:52 IST 2009 INFO [Start Level Event Dispatcher] org.eclipse.riena.communication.core.factory.RemoteServiceFa ctory found protocol [hessian] mailto: org.eclipse.riena.internal.communication.factory.hessian.Rem oteServiceFactoryHessian @1162a9c
Hemanth M S
Re: RAP with Riena Remote Service Support [message #583740 is a reply to message #583729] Thu, 01 October 2009 03:05 Go to previous messageGo to next message
Hi Hemanth,
Tschüß,
Stefan
Hemanth M S wrote:
> Hi Stefan,
> REGISTERED
> Dispatcher]:
> BundleEvent STARTED
> BundleEvent STARTED
> protocol [hessian]
> BundleEvent STARTED
> BundleEvent STARTED
> BundleEvent STARTED
> BundleEvent STARTED
> BundleEvent STARTED
> BundleEvent STARTED
> BundleEvent STARTED
> BundleEvent STARTED
> BundleEvent STARTED
> Regards
> Hemanth M S
Re: RAP with Riena Remote Service Support [message #583757 is a reply to message #488993] Thu, 01 October 2009 04:05 Go to previous messageGo to next message
Hi Stefan,
Thu Oct 01 13:29:42 IST 2009 INFO [Start Level Event Dispatcher] org.eclipse.riena.communication.core.factory.RemoteServiceFa ctory found protocol [hessian] mailto: org.eclipse.riena.internal.communication.factory.hessian.Rem oteServiceFactoryHessian @4ac216
!STACK 0
... 48 more
... 48 more
!STACK 0
!STACK 0
Re: RAP with Riena Remote Service Support [message #583774 is a reply to message #583757] Thu, 01 October 2009 04:55 Go to previous messageGo to next message
Ben
Hemanth M S wrote:
> Hi Stefan,
> REGISTERED
> BundleEvent STARTED
> BundleEvent STARTED
> BundleEvent STARTED
> Dispatcher]:
> protocol [hessian]
> BundleEvent STARTED
> BundleEvent STARTED
> BundleEvent STARTED
> BundleEvent STARTED
> BundleEvent STARTED
> BundleEvent STARTED
> BundleEvent STARTED
> BundleEvent STARTED
> BundleEvent STARTED
> BundleEvent STARTED
> FrameworkEvent INFO
> BundleEvent STARTED
> BundleEvent STARTED
> BundleEvent STARTED
> BundleEvent STARTED
> resolved.
> !STACK 0
> Method)
> Source)
> known Source)
> Method)
> Source)
> known Source)
> letonBase.java:91)
> nch.java:1428)
> java:1424)
> bench.java:430)
> ava:157)
> LifeCycle.java:231)
> at
> ... 48 more
> Method)
> Source)
> known Source)
> Method)
> Source)
> known Source)
> letonBase.java:91)
> nch.java:1428)
> java:1424)
> bench.java:430)
> ava:157)
> LifeCycle.java:231)
> at
> ... 48 more
> !STACK 0
> Method)
> Source)
> known Source)
> Method)
> Source)
> known Source)
> letonBase.java:91)
> nch.java:1428)
> java:1424)
> bench.java:430)
> ava:157)
> LifeCycle.java:231)
> Method)
> Source)
> known Source)
> Method)
> Source)
> known Source)
> letonBase.java:91)
> nch.java:1428)
> java:1424)
Re: RAP with Riena Remote Service Support [message #583794 is a reply to message #583757] Thu, 01 October 2009 05:40 Go to previous messageGo to next message
Hi Hemanth,
Hemanth M S wrote:
> Hi Stefan,
Tschüß,
Stefan
Re: RAP with Riena Remote Service Support [message #583809 is a reply to message #489037] Thu, 01 October 2009 07:51 Go to previous messageGo to next message
Hi Ben & Stefan,
Now I have created two work space and Target Platform one for RCP and one for RAP.
<extension
<entrypoint
</entrypoint>
</extension>
<extension
<perspective
</perspective>
</extension>
Hemanth M S
Re: RAP with Riena Remote Service Support [message #583815 is a reply to message #489057] Thu, 01 October 2009 09:19 Go to previous messageGo to next message
Hi Hemanth,
Ben
Hemanth M S wrote:
> Hi Ben & Stefan,
> one for RAP.
> not exist.
> LifeCycle.java:231)
> <extension
> <entrypoint
> </entrypoint>
> </extension>
> <extension
> <perspective
> </perspective>
> </extension>
> Regards
> Hemanth M S
Re: RAP with Riena Remote Service Support [message #583834 is a reply to message #489083] Thu, 01 October 2009 10:14 Go to previous messageGo to next message
Hi Ben,
This is the launch config which used to run
<stringAttribute key="target_bundles" value="mailto:org.eclipse.swt@default:default,org.eclipse.core.commands*mailto:3.5.0.I20090525-2000@default:default,org.eclipse.osgi*mailto:3.5.0.v20090520@-1:true,org.eclipse.core.databinding.observable*mailto:1.2.0.I20090604-2000@default:default,org.eclipse.equinox.registry*mailto:3.4.100.v20090520-1800@default:default,mailto:org.eclipse.jface.databinding@default:default,org.eclipse.equinox.http.servlet*mailto:1.0.200.v20090520-1800@default:default,org.eclipse.osgi*mailto:3.5.100.v20090803@-1:true,org.eclipse.core.runtime*mailto:3.5.0.v20090525@default:true,mailto:org.eclipse.equinox.transforms.hook@default:false,mailto:org.eclipse.swt.win32.win32.x86@default:false,mailto:org.eclipse.help@default:default,org.eclipse.equinox.preferences*mailto:3.2.300.v20090520-1800@default:default,org.eclipse.core.jobs*mailto:3.4.100.v20090429-1800@default:default,mailto:org.eclipse.rap.ui@default:default,org.eclipse.core.databinding.observable*mailto:1.2.0.I20090630-0800@default:default,mailto:org.eclipse.equinox.log@default:default,org.eclipse.core.jobs*mailto:3.4.100.v20090429-1800@default:default,mailto:org.eclipse.rap.rwt@default:default,mailto:org.apache.log4j@default:default,mailto:com.ibm.icu.base@default:default,mailto:org.eclipse.jface@default:default,org.eclipse.core.expressions*mailto:3.4.100.v20090429-1800@default:default,org.eclipse.equinox.http.registry*mailto:1.0.200.v20090520-1800@default:default,org.eclipse.core.databinding*mailto:1.2.0.I20090630-0800@default:default,org.eclipse.core.commands*mailto:3.5.0.I20090525-2000@default:default,mailto:org.eclipse.rap.jface.databinding@default:default,org.eclipse.core.expressions*mailto:3.4.100.v20090429-1800@default:default,mailto:org.eclipse.rap.jface@default:default,mailto:com.ibm.icu@default:default,org.eclipse.core.contenttype*mailto:3.4.0.v20090429-1800@default:default,mailto:org.user.mgmt.common@default:default,org.eclipse.equinox.http.jetty*mailto:2.0.0.v20090520-1800@default:default,org.eclipse.osgi.services*mailto:3.2.0.v20090520-1800@default:default,org.eclipse.equinox.http.jetty*mailto:2.0.0.v20090520-1800@default:default,mailto:org.eclipse.riena.communication.factory.hessian@default:default,org.eclipse.core.databinding*mailto:1.2.0.I20090604-2000@default:default,org.mortbay.jetty.util*mailto:6.1.15.v200905182336@default:default,mailto:org.user.mgmt.ws@default:default,org.eclipse.equinox.app*mailto:1.2.0.v20090520-1800@default:default,org.eclipse.core.databinding.property*mailto:1.2.0.I20090630-0800@default:default,org.eclipse.equinox.http.registry*mailto:1.0.200.v20090520-1800@default:default,mailto:org.eclipse.rap.ui.workbench@default:default,mailto:com.caucho.hessian@default:default,org.eclipse.equinox.common*mailto:3.5.100.v20090727@2:true,mailto:org.eclipse.rap.rwt.q07@default:false,org.eclipse.core.contenttype*mailto:3.4.0.v20090429-1800@default:default,javax.servlet*mailto:2.5.0.v200806031605@default:default,org.eclipse.equinox.registry*mailto:3.4.100.v20090520-1800@default:default,org.mortbay.jetty.server*mailto:6.1.15.v200905151201@default:default,javax.servlet*mailto:2.5.0.v200806031605@default:default,mailto:org.eclipse.equinox.security@default:default,mailto:org.eclipse.core.runtime.compatibility.auth@default:default,org.eclipse.equinox.common*mailto:3.5.0.v20090520-1800@2:true,org.mortbay.jetty.server*mailto:6.1.15.v200905151201@default:default,mailto:org.eclipse.riena.core@default:default,org.eclipse.core.databinding.property*mailto:1.2.0.I20090526-2000@default:default,mailto:org.eclipse.core.net@default:default,mailto:javax.servlet.jsp@default:default,org.eclipse.equinox.app*mailto:1.2.0.v20090520-1800@default:default,org.eclipse.osgi.services*mailto:3.2.0.v20090520-1800@default:default,mailto:org.eclipse.equinox.security.win32.x86@default:false,org.eclipse.equinox.preferences*mailto:3.2.300.v20090520-1800@default:default,org.eclipse.equinox.http.servlet*mailto:1.0.200.v20090520-1800@default:default,org.mortbay.jetty.util*mailto:6.1.15.v200905182336@default:default,mailto:org.eclipse.core.variables@default:default,mailto:org.eclipse.riena.communication.core@default:default"/>
<stringAttribute key="workspace_bundles" value="mailto:org.user.mgmt.rap@default:default"/>
What should I do other than this? :(
Hemanth M S
Re: RAP with Riena Remote Service Support [message #583845 is a reply to message #489106] Thu, 01 October 2009 12:38 Go to previous message
Hi Ben & Stefan,
Hemanth M S
Previous Topic:Riena Remote with org.eclipse.ui dependency
Next Topic:Can the imagepath check for PNG then GIF or tell me if an image exists?
Current Time: Sat Jul 19 23:05:48 EDT 2025
Powered by FUDForum. Page generated in 0.07583 seconds
