Error Log filling up [message #486215] |
Wed, 16 September 2009 14:56  |
I've been using visual editor for a while now and it's been working fine. However , starting today I noticed that I am getting errors in the error log with vague descriptions that I'm not sure how to fix. My visual component is a simple window with a text area and a few buttons. The errors happen when I'm editing the code. Here are two of them and I'm hoping someone can help.
1. Exception Thrown
Plugin - org.eclipse.ve. java.core
at org.eclipse.ve.internal.java.codegen.util.CodeGenUtil.create Instance(CodeGenUtil.java:103)
at org.eclipse.ve.internal.java.codegen.util.CodeGenUtil.create Instance(CodeGenUtil.java:116)
at org.eclipse.ve.internal.java.codegen.model.BeanPart.createEO bject(BeanPart.java:809)
2. Exception Thrown
plugin - org.eclipse.ve. java.core
java.lang.ArrayIndexOutOfBoundsException: -1
at org.eclipse.emf.common.util.BasicEList.get(BasicEList.java:5 14)
at org.eclipse.emf.ecore.resource.impl.ResourceImpl.getEObjectF orURIFragmentRootSegment(ResourceImpl.java:642)
at org.eclipse.emf.ecore.resource.impl.ResourceImpl.getEObject( ResourceImpl.java:692)
Thanks in advance
Re: Error Log filling up [message #486641 is a reply to message #486633] |
Fri, 18 September 2009 09:40  |
If the VE is working otherwise, I guess it is ok.
cjob68@shaw.ca wrote:
> Are there any issues with just leaving my code as is and let VE generate
> those errors ?
> My concern with adding the code as described is it will make the code
> harder to read and also what happens if in a future release the issue is
> fixed ?
Rich Kulp
Re: Error Log filling up [message #617423 is a reply to message #486245] |
Wed, 16 September 2009 17:20  |
I thought that might be the issue because Eclipse opened with an error today so I did run a -clean on it when I opened it again but that didn't fix this error. I'm not sure what the issue could be.
Re: Error Log filling up [message #617425 is a reply to message #486247] |
Thu, 17 September 2009 09:17  |
Not -clean. That clears only the plugin configurations. It doesn't clear
cached metadata. You need to use the procedure I outlined to clear the
cached metadata.
Actually -clean should rarely be needed except if you are just putting
plugins directly into the eclipse configuration without using the
install manager or the dropins folder.
Rich Kulp
Re: Error Log filling up [message #617426 is a reply to message #486371] |
Thu, 17 September 2009 11:44  |
Thanks , I tried that but it didn't seem to fix it. I think I may know what the problem is. I have modified the section where the visual editor creates the jTable and the visual editor doesn't like this.
Visual Editor likes this:
String[] columnNames = {"Column1", "Column2"};
Vector<String> columnNamesV = new Vector<String>(Arrays.asList(columnNames));
jTable = new JTable(getRowData(),columnNamesV);
My modified code which it doesn't like:
jTable = new JTable(getRowData(),columnNamesV){
...custom table code here including creating a rendered to modify the color of the rows
Any ideas ?
Re: Error Log filling up [message #617427 is a reply to message #486432] |
Thu, 17 September 2009 11:58  |
Yeah, I could see that being a problem. The VE needs to be able to
instantiate a visual component. A non-static inner class can't be
instantiated.
> color of the rows
> Any ideas ?
Rich Kulp
Re: Error Log filling up [message #617428 is a reply to message #486441] |
Thu, 17 September 2009 12:57  |
I'm also getting errors in another class that doesn't have any tables and for the most part it's got the same code that VE inserted.
The error is :
Is this something I should be worried about ? Could my install of VE be corrupted ?
Any suggestions ?
Re: Error Log filling up [message #617429 is a reply to message #486452] |
Thu, 17 September 2009 15:24  |
I think I may have found the issue. I removed GUI components one by one from the frame to see when I could add a space in the source and watch the GUI sync and generate an error. When I removed the jTextArea I no longer get the error when the GUI syncs. I'm not sure why this is happening but at least I am getting somewhere.
Re: Error Log filling up [message #617431 is a reply to message #486482] |
Thu, 17 September 2009 16:50  |
I'm not sure why either but there is a workaround you can use to have VE
ignore the line. It's kind of kludgy. We never got to put in an
annotation that would tell VE to ignore something when I was working on
VE. :-(
if(false)
else
jTextArea.getDocument().addDocumentListener(new MyDocumentListener());
This will work because VE is designed to ignore the else block of an if
statement.
> I found the line that is causing the problem.
> I'm not sure why VE doesn't like this line. The code compiles fine and
> it also runs fine but when syncing the GUI it generates an error in the
> Error Log.
Rich Kulp
Re: Error Log filling up [message #617432 is a reply to message #486495] |
Thu, 17 September 2009 16:58  |
> VE. :-(
A little bit of grammar problem there. It is not that we never put in
code to have something ignored only when I was working on VE! And so by
corollary when I'm not working on the VE it wouldn't ignore something. :-)
Rich Kulp
Re: Error Log filling up [message #617433 is a reply to message #486495] |
Fri, 18 September 2009 09:35  |
Are there any issues with just leaving my code as is and let VE generate those errors ?
My concern with adding the code as described is it will make the code harder to read and also what happens if in a future release the issue is fixed ?
Re: Error Log filling up [message #617434 is a reply to message #617433] |
> those errors ?
> fixed ?
Rich Kulp
FUDForum. Page generated in 0.09222 seconds
