Home » Language IDEs » ServerTools (WTP) » can't seem to move from myeclipse to WTP???
can't seem to move from myeclipse to WTP??? [message #485233] |
Thu, 10 September 2009 17:05  |
We have a seam project and currently love that server view they have where
we can deploy our application and debug it, and it hot swaps code changes
and xhtml changes(annotation changes and pages.xml file changes don't work
and require a restart but that is alright considering the other two work).
Our directory structure is so...
project
---input
------javasrc - our src code (gets put in WEB-INF/classes)
------libinclude - jsf libs, libs we need, seam libs
- basically everything that gets put in WEB-INF/lib
------libexclude - jars we don't deploy like servlet-api.jar
------webroot - all our xhtml files
---------WEB-INF - the web-inf stuff excluding classes and libs
---output - our generation directory
We would LOVE to setup WTP so it does not generate anything in input dir
on down and only uses output if that is even needed. Currently we use
myeclipse and it basicaly deploys our app to tomcat moving the above files
into the correct places. Is there a way to do this with WTP and use the
server view to start the server and debug our seam app(keeping xhtml hot
deploy and class file hot deploy intact)???
thanks for any help on this!!!
thanks,
Dean
changing project to dynamic web project fails miserbly??? [message #485391 is a reply to message #485244] |
Fri, 11 September 2009 11:19   |
I just downloaded the latest eclipse EE two days ago. I check out my seam
project from CVS(with no .project or .classpath files). I look for
convert to dynamic web project but I don't see that in the list when I
right click on project. How does one convert a project to a dynamic web
project?
I could have sworn I managed to do this two days ago(hmmm, maybe that was
with jboss tools that I could do it). The configure submenu only has
convert to JPA and convert to plugin projects :(.
How does one mount an existing dynamic web project?
Here is my second try with a workaround that also doesn't work but gets
farther.......
1. checkout and then delete the project from eclipse(but not delete source
off drive)
2. now, create a new dynamic web project and uncheck Use default for
directory and choose the directory I just checked out
3. as I go, choose /input/javasrc, input/webroot, uncheck generate
web.xml, click finish
4. Now add my EJB3 project as a dependency(ie. we add the project so we
can change code and it will hot deploy)...hmmm, does that work in WTP if
you have a subproject of a war project, will it get deployed to tomcat and
do hot swap of code like MyEclipse does? It appears not to work.
RESULT: There was no choice for where it should get my jar files from????
and now my project does not compile.
5. I try to go to build path and there is this Web App Libraries thing but
I can't seem to add jars to that at all.
Any ideas how to get this to work?
thanks,
Dean
Re: changing project to dynamic web project fails miserbly??? [message #485427 is a reply to message #485391] |
Fri, 11 September 2009 13:19   |
> seam project from CVS(with no .project or .classpath files). I look for
> project?
> was with jboss tools that I could do it). The configure submenu only
> has convert to JPA and convert to plugin projects :(.
> farther.......
> source off drive)
Dynamic Web Projects have a certain "structure". The "structure" of
other "web" type projects can be so varied that it's not practical to
automate conversion in general. It is much more practical for plug-ins
that support a particular build framework, such as maven, to implement
this conversion since the "structure" of the original project is well
known. If what you have is a general "web" type project, then what you
have done seems reasonable.
> and do hot swap of code like MyEclipse does? It appears not to work.
In WTP, adding a Java project as a dependency of a Dynamic Web Project
implies building that Java project into a jar and including that jar in
the webapp's WEB-INF/lib. This won't work with hot code replacement.
However, the WTP Tomcat supports an option to "Server modules without
publishing". Double-click the server in the Servers view and enable
this option in the Server Options section. This "installs" a custom
classloader in Tomcat that would allow the classes in the Java project
to be accessed directly, without being built into a jar.
> from???? and now my project does not compile.
> but I can't seem to add jars to that at all.
Use the Java EE Module Dependencies page to manage such jars. What you
configure there will often appear under the Web App Libraries. Web App
Libraries isn't something you interact with directly in the Java Build
Path properties page. The Web App Libraries would also automatically
pickup any jar under "input/webroot/WEB-INF/lib", if such a folder existed.
Larry
> thanks,
> Dean
Re: changing project to dynamic web project fails miserbly??? [message #485464 is a reply to message #485452] |
Fri, 11 September 2009 15:49   |
Dean Hiller wrote:
> wow! that was my missing link on the web app libs thing!! thanks!!!
> Now, I just can't seem to get my EJB3 project that the war project
> depends on to be in the classpath for some reason. I checked the xcore3
> project on the J2EE Module Depend window, but it is still not getting
> included. Usually this is so automatic on straight java projects...I
> must be missing one more simple step???
Adding a Java project as a dependency of a Dynamic Web Project will
convert the Java project to a WTP type project, i.e. one that contains a
"module". The Java project should now contain a "components" file like
the Dynamic Web Project. You might check that file to make sure it's
pulling from the correct Java source directories. In this case the
deploy-path is relative to the implied jar that will contain the
project's classes.
> Also, very strangely, I don't see the web app in tomcat/webapps like
> MyEclipse would do.
When creating a new Tomcat server, the default is to create a separate
Tomcat instance, i.e. catalina.base != catalina.home. In addition, the
default is to deploy to "wtpwebapps" to avoid various auto-deployment
issues. For details about the WTP Tomcat support, see the Tomcat FAQ:
http://wiki.eclipse.org/WTP_Tomcat_FAQ
Larry
> Where does it put the web app files? That has been
> a great MyEclipse feature as I could go look and figure stuff out and
> see what files were missing from the final deployment. Where is the
> webapp assembled to so I can view it? Sometimes there is a file missing
> or whatnot and just looking at the structure tells me my bug right away.
> thanks much, Dean
Re: changing project to dynamic web project fails miserbly??? [message #485485 is a reply to message #485478] |
Fri, 11 September 2009 18:18   |
yeah, yeah, yeah, I finally got it working without the hotswap on EJB3 jar
but works on everything else. That was the biggest unusable wizard ever.
Bug #1. After checkout from CVS, there was no way for me to convert to
Dynamic Web Project
Bug #2 I then delete the project and keep it on disk. When I create
dynamic web project and uncheck default target to mount existing source
and choose the project on the filesystem, it says project alrady
exists...well, yes, I know it exists, I want to mount existing source just
like I can with java projects.
I am sooooo happy though that I got this working...it just took forever.
Usability Bug #3 In the dynamic web project wizard, there should be a J2EE
Module Depends page in the wizard where you add the jars so that a user
knows after he is done with the wizard, he would automatically look for
that tab.
I think if the above 3 bugs were solved, this thing would rock and be very
very usable for a beginner to come in and mount an existing web project.
thanks,
Dean
Re: changing project to dynamic web project fails miserbly??? [message #485695 is a reply to message #485485] |
Mon, 14 September 2009 10:14  |
> jar but works on everything else. That was the biggest unusable wizard
> ever.
> Dynamic Web Project
> just like I can with java projects.
> J2EE Module Depends page in the wizard where you add the jars so that a
> user knows after he is done with the wizard, he would automatically look
> for that tab.
> very very usable for a beginner to come in and mount an existing web
> project.
> thanks,
> Dean
Feel free to add your comments to Bug 168538[1]. However, I believe
there are enough other issues being worked on by those responsible for
this area of WTP, that it's hard to say when there would be enough extra
cycles to deal with that Bug. It's marked "helpwanted" if you feel
motivated.
Larry
[1] https://bugs.eclipse.org/bugs/show_bug.cgi?id=168538
Current Time: Thu Oct 23 15:22:36 EDT 2025
Powered by FUDForum. Page generated in 0.07494 seconds
