Home » Archived » OHF » Using org.eclipse.ohf.ihe.common.cdar2 to Create CDA Document?
Using org.eclipse.ohf.ihe.common.cdar2 to Create CDA Document? [message #48078] Wed, 17 September 2008 01:52 Go to next message
I want to create CDA using org.eclipse.ohf.ihe.common.cdar2.I need help.
I do not known how to use it.For example,I add the author element,if
the element is exist,I can add the value of the author,but if the author
is not exist,how can I do?
How can I get the exist element value by code if the CDA document
created?
Thanks in advance!
Re: Using org.eclipse.ohf.ihe.common.cdar2 to Create CDA Document? [message #48182 is a reply to message #48078] Wed, 17 September 2008 16:02 Go to previous messageGo to next message
Hi Robert,
There is some sample code in the src_tests folder of this plugin that
documents ... a little bit ... how to use this model.
regards,
- Sarah
> created?
> Thanks in advance!
Re: Using org.eclipse.ohf.ihe.common.cdar2 to Create CDA Document? [message #48237 is a reply to message #48182] Wed, 17 September 2008 22:53 Go to previous messageGo to next message
I want some codes.For example:
<recordTarget>
<patientRole>
<id extension="REPLACE ME" root="0.0.0.0.0"/>
<addr>
<country>USA</country>
</addr>
<patient>
<name>
<given>REPLACE ME</given>
<family>REPLACE ME</family>
</name>
<administrativeGenderCode code="REPLACE_ME"
codeSystem="2.16.840.1.113883.5.1"/>
<birthTime value="0000"/>
</patient>
</patientRole>
</recordTarget>
<author>
<time value="0000"/>
<assignedAuthor>
<id root="0.0.0.0.0"/>
<assignedAuthoringDevice>
<code code="CAPTURE" codeSystem="1.2.840.10008.2.16.4"
displayName="Image Capture"/>
<manufacturerModelName>REPLACE_ME</manufacturerModelName>
<softwareName>REPLACE_ME</softwareName>
</assignedAuthoringDevice>
<representedOrganization>
</representedOrganization>
</assignedAuthor>
</author>
If i want set values,how can I do?
If the element values were setted,how can I get the values?
I see the OHF APIs,but I do not find the way.
Can someone give some codes?
Thanks!
Re: Using org.eclipse.ohf.ihe.common.cdar2 to Create CDA Document? [message #48267 is a reply to message #48237] Thu, 18 September 2008 05:45 Go to previous messageGo to next message
<recordTarget>
<patientRole>
<id extension="12345" root="2.16.840.1.113883.19.5"/>
<patient>
<name>
<given>Henry</given>
<family>Levin</family>
<suffix>the 7th</suffix>
</name>
<administrativeGenderCode code="M"
<birthTime value="19320924"/>
</patient>
<providerOrganization>
<id root="2.16.840.1.113883.19.5"/>
</providerOrganization>
</patientRole>
</recordTarget>
//recordTarget
EList recordTarget=root.getClinicalDocument().getRecordTarget();
How can I get the value in the EList?
What's the element type in the EList?
I was able to use code to get the templateId'value ,but how can use code
to set the templateId?
root.getClinicalDocument().setTemplateId is not exist.
Re: Using org.eclipse.ohf.ihe.common.cdar2 to Create CDA Document? [message #48329 is a reply to message #48267] Thu, 18 September 2008 12:26 Go to previous messageGo to next message
Hi Robert,
Did you see the code in the src_tests of this plugin. If this is not
sufficient for you .. you may also look at the CDAExtractor.java in
org.eclipse.ohf.ihe.xds.metadata.extract.cdar2
Hope these help.
Additionally -- This code is generated using EMF (Eclipse Modeling
Framework). There are many sample code examples out there for EMF on the
Eclipse website. This may also help you in using the CDA model by
knowing abit more about how EMF generated code works.
regards,
Sarah
RobertHua wrote:
> <recordTarget>
> <patientRole>
> <patient>
> <name>
> </name>
> </patient>
> </patientRole>
> </recordTarget>
> //recordTarget
> How can I get the value in the EList? What's the element type in the EList?
Re: Using org.eclipse.ohf.ihe.common.cdar2 to Create CDA Document? [message #48359 is a reply to message #48078] Fri, 19 September 2008 05:35 Go to previous messageGo to next message
Thanks for the reply, some stuck were solved ,but I still need more
clarification...
How to create a metadata file that not is exist?
Thanks in Advance for both your time and your knowledge!
Greetings!
RobertHua
Re: Using org.eclipse.ohf.ihe.common.cdar2 to Create CDA Document? [message #48389 is a reply to message #48359] Mon, 22 September 2008 12:43 Go to previous message
When you submit a CDA document, metadata extraction from that document
happeds automatically for you. See the "Option 2" tests for document
submission for an example. Otherwise, there are many, many functions for
building the metadata you need in a number of different ways. See the
javadoc on the SubmitTransactionData.java in the xds.source plugin.
- Sarah
> clarification...
> Greetings!
> RobertHua
Re: Using org.eclipse.ohf.ihe.common.cdar2 to Create CDA Document? [message #587695 is a reply to message #48078] Wed, 17 September 2008 16:02 Go to previous message
Hi Robert,
regards,
- Sarah
> created?
> Thanks in advance!
Re: Using org.eclipse.ohf.ihe.common.cdar2 to Create CDA Document? [message #587716 is a reply to message #48182] Wed, 17 September 2008 22:53 Go to previous message
<recordTarget>
<patientRole>
<addr>
</addr>
<patient>
<name>
</name>
</patient>
</patientRole>
</recordTarget>
<author>
<assignedAuthor>
</assignedAuthor>
</author>
Thanks!
Re: Using org.eclipse.ohf.ihe.common.cdar2 to Create CDA Document? [message #587720 is a reply to message #48237] Thu, 18 September 2008 05:45 Go to previous message
<recordTarget>
<patientRole>
<patient>
<name>
</name>
</patient>
</patientRole>
</recordTarget>
//recordTarget
Re: Using org.eclipse.ohf.ihe.common.cdar2 to Create CDA Document? [message #587737 is a reply to message #48267] Thu, 18 September 2008 12:26 Go to previous message
Hi Robert,
Hope these help.
regards,
Sarah
RobertHua wrote:
> <recordTarget>
> <patientRole>
> <patient>
> <name>
> </name>
> </patient>
> </patientRole>
> </recordTarget>
> //recordTarget
Re: Using org.eclipse.ohf.ihe.common.cdar2 to Create CDA Document? [message #587746 is a reply to message #48078] Fri, 19 September 2008 05:35 Go to previous message
clarification...
Greetings!
RobertHua
Re: Using org.eclipse.ohf.ihe.common.cdar2 to Create CDA Document? [message #587755 is a reply to message #48359] Mon, 22 September 2008 12:43 Go to previous message
- Sarah
> clarification...
> Greetings!
> RobertHua
Previous Topic:RetrieveDocumentSet - Serious Memory Problem
Next Topic:STEM New Feature Requests Discussion
Current Time: Fri Jul 25 22:10:06 EDT 2025
Powered by FUDForum. Page generated in 0.80530 seconds
