Home » Eclipse Projects » Rich Client Platform (RCP) » Maintaining state of an AbstractSourceProvider
Maintaining state of an AbstractSourceProvider [message #481068] Wed, 19 August 2009 09:49 Go to next message
I use an implementation of the ISourceProvider to maintain the state of certain variables that I would like to use in the Extensions and in my code.
The problem is that the state of these variables isn't maintained between sessions of the RCP application.
To resolve this, I tried serialization, but I gave up on this because I couldn't find a way to reregister the class in the application since classes of this sort are instantiated by the Eclipse RCP framework.
Any suggestions on how I might resolve this problem?
Re: Maintaining state of an AbstractSourceProvider [message #481111 is a reply to message #481068] Wed, 19 August 2009 12:28 Go to previous messageGo to next message
In an RCP app if you want to save state and restore state, you can either have your ASP implementation interact with your activator to save state on Activator#stop(BundleContext) or try and retrieve the information on org.eclipse.ui.application.WorkbenchAdvisor.saveState(IMemen to) so you can write it out.
PW
Re: Maintaining state of an AbstractSourceProvider [message #481216 is a reply to message #481068] Thu, 20 August 2009 03:41 Go to previous messageGo to next message
Thanks for answering this, Paul.
I was under the impression that IMemento is there to maintain the state of widgets inside a ViewPart. But if I understand you correctly, you are saying that I can use it for much more than that. I can't seem to find much about this on the internet. Can you get into a bit more detail here?
I know how to use IMemento to store widget related things. But how would I address this object outside of a ViewPart context?
Re: Maintaining state of an AbstractSourceProvider [message #481834 is a reply to message #481216] Mon, 24 August 2009 09:50 Go to previous message
IMemento is used to store state information. Most commonly, a view can store session data when the view is open and eclipse is stopped/restarted. This saveState/restoreState code is not called for simply closing the view and re-opening it, however.
RCP apps have an opportunity to also save/restore application state from their WorkbenchAdvisor. your application would have to find the information to save, or your producer of the information would have to post it somewhere useful the workbench advisor can find it. But it's up to you to figure out how to save your state to an IMemento
For example, a common pattern is to have a view save information in its activator, ex: Activator.getDefault().getInfoMap().put("useName", "Paul Webster").
In the Activator#stop(*) method, info map is written out to the plugin state location. In the Activator#start(*) method, the state location file is read and the info map is populated.
PW
Previous Topic:Minimize Event on a View
Next Topic:Headless build on Windows using a Linux Galileo platform + Delta Pack
Current Time: Wed Jun 18 19:26:10 EDT 2025
Powered by FUDForum. Page generated in 0.04275 seconds
