Home » Eclipse Projects » Platform - User Assistance (UA) » Centralized Eclipse Help-System
Centralized Eclipse Help-System [message #473577] Fri, 18 April 2008 05:45 Go to next message
Hi all,
I'm trying to centralize the help-system of our rcp application and was
wondering if there is any possibility to move the whole helpsystem to a
server. There I was trying help in infocenter-mode, which works fine, but
in this case I couldn't get my F1-context-help to work. Since context-help
is an absolute must-have for me I was wondering if there is any way to
store help-content on a server but still use context-help?
On top of that I am also searching for a wiki-like way to maintain the
help-contents so people who are not developers can maintain the help
contents.
Has anyone ever done anything like this or any idea how to achive my goals?
Thanks in advance for any help.
Christian
Re: Centralized Eclipse Help-System [message #473586 is a reply to message #473577] Wed, 23 April 2008 12:46 Go to previous messageGo to next message
Originally posted by: nospam_kowalskilee.gmail.com
Hi Christian,
> but in this case I couldn't get my F1-context-help to work.
What version of Eclipse are you using?
> contents.
Are you envisioning a practice where:
a. Help content is served in infocenter mode.
b. People maintain the help content directly inside the running
infocenter by editing directly in the infocenter?
Or something multi-step:
a. Developers create the help contents and put into a wiki-like structure.
b. People in the developers' company, but not developers, maintain the
help contents in the wiki-like structure.
c. At scheduled times, the help contents gets piped out to the running
infocenter, where the final users see it?
I've seen some ideas floating around on how to do the multi-step
process. I haven't seen any implementation yet of direct wiki-like
function in Eclipse infocenter mode yet.
Lee Anne
Re: Centralized Eclipse Help-System [message #473588 is a reply to message #473577] Wed, 23 April 2008 20:58 Go to previous messageGo to next message
One thing you might consider is using remote help, which allows the
content from one infocenter to be included in the help content for an
instance of Eclipse, see
http://help.eclipse.org/help33/topic/org.eclipse.platform.do c.isv/guide/ua_help_content_remote.htm
This allows you to keep one central set of documents so that every
client will get their help data, including context help from that one
server.
Re: Centralized Eclipse Help-System [message #473589 is a reply to message #473586] Thu, 24 April 2008 03:34 Go to previous messageGo to next message
Hi Lee Anne
I'm using Eclipse 3.3.2
This would be the perfect solution
But something multistep would be better than nothing. Do you have any
advice or links how this can be done?
Christian
Re: Centralized Eclipse Help-System [message #473590 is a reply to message #473588] Thu, 24 April 2008 03:55 Go to previous message
Hi Chris,
thanks for the tip. I did already try running an Infocenter but I didn't
put the the context.xml in the Infocenter. I tried it and it works fine.
So now I only have to bind the contextual help to the widgets.
Christian
Re: Centralized Eclipse Help-System [message #612020 is a reply to message #473577] Wed, 23 April 2008 12:46 Go to previous message
Hi Christian,
> contents.
Lee Anne
Re: Centralized Eclipse Help-System [message #612024 is a reply to message #473577] Wed, 23 April 2008 20:58 Go to previous message
server.
Re: Centralized Eclipse Help-System [message #612025 is a reply to message #473586] Thu, 24 April 2008 03:34 Go to previous message
Hi Lee Anne
Christian
Re: Centralized Eclipse Help-System [message #612027 is a reply to message #473588] Thu, 24 April 2008 03:55 Go to previous message
Hi Chris,
Christian
Previous Topic:Minimal required components for SA Help
Next Topic:Open Help in External-Browser
Current Time: Wed Jul 23 07:25:44 EDT 2025
Powered by FUDForum. Page generated in 0.26026 seconds
