Connecting web applications to standalone help [message #470860] |
Tue, 13 November 2007 01:23  |
I need to serve online help for a web application running in a Software
As A Service (SAAS) environment. There are several instances of the web
application running on the JBoss application server. I've got my help
content running in Eclipse and it looks great. I have a few questions
about connecting the web applications to the help system.
1. If I start an instance of standalone help, can more than one web
application instance invoke displayHelp? Will each invocation of
displayHelp start a new help server instance?
2. If I run an instance of standalone help on one server and I have a
web application running on another server, is it possible for the web
application to call the help classes on the standalone help server? Can
the web application and the help system be running on different servers?
3. I must ensure that unknown users on the Internet cannot access the
online help. If I run an instance of standalone help and have the web
applications invoke it via Java, do I need to make the help system
directly available to the internet? It looks to me that I don't but I
want to confirm.
Thanks for your help.
Peter Desjardins
Re: Connecting web applications to standalone help [message #593802 is a reply to message #470860] |
Tue, 13 November 2007 16:58  |
I'm pretty sure that each instance of standalone help would create a new
instance of the help server and therefore start help on another port.
You may want to use an infocenter rather than standalone help. This is
basically a help server which starts on a port number which you specify
and is intended for accessing help from multiple remote computers.
As for security I don't have a quick answer there, you probably want to
use another Web server as a gateway to the help system to restrict the
access. Maybe someone else reading this newsgroup has some hints on how
to set up security.
> want to confirm.
> Peter Desjardins
Re: Connecting web applications to standalone help [message #593823 is a reply to message #470865] |
Tue, 13 November 2007 17:18  |
Do you know whether an application running on one server can access
standalone help that's installed on another server?
Thanks again,
Peter Desjardins
FUDForum. Page generated in 0.11681 seconds
