Home » Eclipse Projects » Platform - User Assistance (UA) » Automatically load html file as context?
Automatically load html file as context? [message #470862] Tue, 13 November 2007 13:09 Go to next message
I am implementing context sensitive help in my RCP application. The technical writers are using
Flare to generate their help content, and they wish to generate their own list of contexts
associated with a dialog/view in a html file, instead of defining them in a contexts.xml file.
Is there any way to automatically load this html file as the context sensitive help for a
dialog/view when F1 is pressed? I made a contexts.xml file, and defined each context with a single
topic corresponding to the html file generated by the technical writers, but when I press F1 this
displays the "Related Topics" page in the help view, with the single topic pointing to the html
file. I want to bypass the "Related Topics" page and instead directly load the html file generated
by the technical writers into the help view.
Does anyone know if this is possible to do this?
Also, is it possible to turn off/remove the "Dynamic Help/ Search Results" from the Context
sensitive view?
Many thanks,
Conor
Re: Automatically load html file as context? [message #470864 is a reply to message #470862] Tue, 13 November 2007 16:56 Go to previous messageGo to next message
Starting in 3.3, the "Related Topics" dialog is *supposed* to be
suppressed when there's only one target topic:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=88822
I haven't had a chance to test that yet myself.
Conor O'Mahony wrote:
> technical writers are using Flare to generate their help content, and
> they wish to generate their own list of contexts associated with a
> file.
> sensitive help for a dialog/view when F1 is pressed? I made a
> contexts.xml file, and defined each context with a single topic
> when I press F1 this displays the "Related Topics" page in the help
> view, with the single topic pointing to the html file. I want to bypass
> generated by the technical writers into the help view.
> Results" from the Context sensitive view?
> Many thanks,
> Conor
Re: Automatically load html file as context? [message #470925 is a reply to message #470864] Wed, 14 November 2007 06:13 Go to previous message
Thanks for your help, we are currently using Eclipse 3.2 so I'm not sure what we'll do about this...
As for the "Dynamic Help/ search results" automatically generated in this window, does anyone know
if there is any way to turn this off?
Many thanks,
>> Hi,
>> file.
>> file generated by the technical writers into the help view.
>> Many thanks,
>> Conor
Re: Automatically load html file as context? [message #593796 is a reply to message #470862] Tue, 13 November 2007 16:56 Go to previous message
> file.
> Many thanks,
> Conor
Re: Automatically load html file as context? [message #594272 is a reply to message #470864] Wed, 14 November 2007 06:13 Go to previous message
Many thanks,
>> Hi,
>> file.
>> Many thanks,
>> Conor
Previous Topic:Connecting web applications to standalone help
Next Topic:Strange error from
Current Time: Wed Jun 18 04:43:24 EDT 2025
Powered by FUDForum. Page generated in 0.05852 seconds
