Home » Eclipse Projects » Rich Client Platform (RCP) » How to view the outline and property sheet views in an RCP application?
Re: How to view the outline and property sheet views in an RCP application? [message #466870 is a reply to message #466441] |
Wed, 25 April 2007 20:24   |
Originally posted by: jweeks.neuraldk.org
valere fedronic wrote:
> Take a look at this article:
http://wiki.eclipse.org/index.php/FAQ_How_do_I_create_an_Out line_view_for_my_own_language_editor%3F
I believe there might be some problems with this article... perhaps someone
can explain to me how I should be doing this, as I used this article as a
template (and also its associated source at
http://dev.eclipse.org/viewcvs/index.cgi/org.eclipse.ui.exam ples.javaeditor/Eclipse
Java Editor
Example/org/eclipse/ui/examples/javaeditor/JavaContentOutlin ePage.java?view=markup)
and I'm still having issues.
The problem in question is that the TreeViewer is never created, because
createControl(Composite parent) is never called.
In the tutorial, createControl() is overridden, but never explicitly
executed. Even inside getAdapter(Class required) the outline page is
simply constructed, and createControl() is never called. From this, I
assumed that the requester of getAdapter() would implicitly call
createControl() but this doesn't appear to be the case.
So, long story short; who should be calling createControl()? And, if *I*
should be doing so, what should I be passing in as 'parent'?
Jeff
Re: How to view the outline and property sheet views in an RCP application? [message #466872 is a reply to message #466870] |
Wed, 25 April 2007 21:41   |
--nextPart1207067.kPSuJC0pKQ
Content-Type: text/plain; charset=utf-8
Content-Transfer-Encoding: 8Bit
It turns out that this was a red herring. The problem below wasn't that
createControl() wasn't being called, it was that update() was being called
before the control was created.
I've fixed this, however, and I'm still receiving a default Outline window
(contains only the text "An outline is not available").
I get no errors, exceptions, or any indication that something has gone
wrong. Could someone please suggest what might be wrong, or some method of
debugging this issue? So far everything looks good... I see it iterate
through all my Segment elements, but none are displayed (I've attached the
trace, if anyone's interested).
Jeff
> someone can explain to me how I should be doing this, as I used this
> article as a template (and also its associated source at
> Java Editor
> Jeff
Content-Type: text/x-java; name="LogOutlinePage.java"
Content-Disposition: attachment; filename="LogOutlinePage.java"
package tvnavtraceviewer.editors;
import org.eclipse.jface.viewers.ISelection;
import org.eclipse.jface.viewers.ISelectionChangedListener;
import org.eclipse.swt.widgets.Composite;
import org.eclipse.swt.widgets.Control;
import org.eclipse.ui.IActionBars;
import org.eclipse.ui.part.IPage;
import org.eclipse.ui.views.contentoutline.ContentOutlinePage;
import org.eclipse.ui.texteditor.IDocumentProvider;
import org.eclipse.ui.texteditor.ITextEditor;
import org.eclipse.jface.viewers.TreeViewer;
import org.eclipse.jface.text.Position;
import org.eclipse.jface.viewers.ITreeContentProvider;
import org.eclipse.jface.viewers.Viewer;
import java.util.List;
import java.util.ArrayList;
import java.text.MessageFormat;
import org.eclipse.jface.text.IPositionUpdater;
import org.eclipse.jface.text.DefaultPositionUpdater;
import org.eclipse.jface.text.IDocument;
import org.eclipse.jface.text.BadPositionCategoryException;
import org.eclipse.jface.text.BadLocationException;
import org.eclipse.jface.viewers.LabelProvider;
import org.eclipse.jface.viewers.SelectionChangedEvent;
import org.eclipse.jface.viewers.IStructuredSelection;
public class LogOutlinePage extends ContentOutlinePage
protected Object input;
protected IDocumentProvider provider;
protected ITextEditor editor;
protected static class Segment
public String name;
public Position position;
public Segment(String name, Position position)
this.name = name;
this.position = position;
public String toString()
return name;
protected class ContentProvider implements ITreeContentProvider
protected final static String SEGMENTS= IDocument.DEFAULT_CATEGORY; //"__java_segments"; //$NON-NLS-1$
protected IPositionUpdater fPositionUpdater= new DefaultPositionUpdater(SEGMENTS);
protected List fContent= new ArrayList(10);
protected void parse(IDocument document)
int lines = document.getNumberOfLines();
int increment = Math.max(Math.round(lines / 10), 10);
for (int line = 0; line < lines; line += increment)
int length = increment;
if (line + increment > lines)
length = lines - line;
try
int offset = document.getLineOffset(line);
int end = document.getLineOffset(line + length);
length = end - offset;
Position p = new Position(offset, length);
document.addPosition(SEGMENTS, p);
fContent.add(
new Segment(
MessageFormat.format(
"linenum " + line,
new Object[] { new Integer(offset) }
p
"linenum" + line, p
); //$NON-NLS-1$
} catch (BadPositionCategoryException x)
catch (BadLocationException x)
* @see IContentProvider#inputChanged(Viewer, Object, Object)
public void inputChanged(Viewer viewer, Object oldInput, Object newInput)
if (oldInput != null)
IDocument document= provider.getDocument(oldInput);
if (document != null)
try
document.removePositionCategory(SEGMENTS);
document.removePositionUpdater(fPositionUpdater);
fContent.clear();
if (newInput != null)
IDocument document= provider.getDocument(newInput);
document.addPositionCategory(SEGMENTS);
document.addPositionUpdater(fPositionUpdater);
parse(document);
* @see IContentProvider#dispose
public void dispose()
if (fContent != null)
fContent.clear();
fContent= null;
* @see IContentProvider#isDeleted(Object)
public boolean isDeleted(Object element)
return false;
* @see IStructuredContentProvider#getElements(Object)
public Object[] getElements(Object element)
return fContent.toArray();
* @see ITreeContentProvider#hasChildren(Object)
public boolean hasChildren(Object element)
boolean children = (element == input);
return children;
* @see ITreeContentProvider#getParent(Object)
public Object getParent(Object element)
if (element instanceof Segment)
return input;
else
return null;
* @see ITreeContentProvider#getChildren(Object)
public Object[] getChildren(Object element)
if (element == input)
else
return new Object[0];
public LogOutlinePage(IDocumentProvider provider, ITextEditor editor)
super();
this.provider= provider;
this.editor= editor;
/* override */
public void createControl(Composite parent)
super.createControl(parent);
System.out.println("LogOutlinePage::createControl()");
TreeViewer viewer= getTreeViewer();
viewer.setContentProvider(new ContentProvider());
viewer.setLabelProvider(new LabelProvider());
viewer.addSelectionChangedListener(this);
if (input != null)
System.out.println("Calling viewer.setInput");
viewer.setInput(input);
update();
/* override */
public void selectionChanged(SelectionChangedEvent event)
super.selectionChanged(event);
ISelection selection= event.getSelection();
if (selection.isEmpty())
editor.resetHighlightRange();
else
Segment segment= (Segment) ((IStructuredSelection) selection).getFirstElement();
int start= segment.position.getOffset();
int length= segment.position.getLength();
try
editor.setHighlightRange(start, length, true);
} catch (IllegalArgumentException x)
/* new */
public void setInput(Object input)
this.input = input;
update();
/* new */
public void update()
System.out.println("LogOutlinePage::update()");
if (viewer != null)
Control control= viewer.getControl();
if (control != null && !control.isDisposed())
control.setRedraw(false);
viewer.expandAll();
control.setRedraw(true);
else
System.out.println("tree viewer is null in LogOutlinePage::update()");
// TODO Auto-generated method stub
public Control getControl()
return null;
public void setActionBars(IActionBars actionBars)
public void setFocus()
public void addSelectionChangedListener(ISelectionChangedListener listener)
public ISelection getSelection()
return null;
public void removeSelectionChangedListener(ISelectionChangedListener listener)
public void setSelection(ISelection selection)
--nextPart1207067.kPSuJC0pKQ--
Re: How to view the outline and property sheet views in an RCP application? [message #466900 is a reply to message #466872] |
Thu, 26 April 2007 08:00   |
Originally posted by: valere.fedronic.ext.streamezzo.com
It is because you have overridden getControl() to return null.
Do not override the following methods:
listener)
valere.
> Jeff
>> Java Editor
>> Thanks,
>> Jeff
Re: How to view the outline and property sheet views in an RCP application? [message #466985 is a reply to message #466900] |
Thu, 26 April 2007 20:49  |
D'oh! I totally neglected to take into account those!
Thanks!
--Jeff
> listener) public ISelection getSelection()
> listener)
> valere.
>> called before the control was created.
>> window (contains only the text "An outline is not available").
>> of
>> the trace, if anyone's interested).
>> Thanks,
>> Jeff
>>> Java Editor
>>> *I* should be doing so, what should I be passing in as 'parent'?
>>> Thanks,
>>> Jeff
Current Time: Fri Jul 25 17:31:39 EDT 2025
Powered by FUDForum. Page generated in 0.05860 seconds
