Home » Archived » M2M (model-to-model transformation) » [ATL] how to use entity reference in input model
| [ATL] how to use entity reference in input model [message #4294] |
Fri, 29 December 2006 02:35  |
Hello ,
i have a simle input model file(bpmnModel.ecore) , which is generated
by a tool , and it conform to certain metamodel(bpmn.ecore). the input
file is follwoing.
<?xml version="1.0" encoding="ISO-8859-1"?>
<xmi:XMI xmi:version="2.0"
xmlns:xmi="http://www.omg.org/XMI" xmlns:bp="bpdm"
xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance">
<bp:BusinessProcessDiagram Name="BusinessProcessDiagram1">
<Pools xmi:id="_45T0YJVvEdusYsgvXrrVmQ" Id="_uqHcgJVvEdusYsgvXrrVmQ"
Documenation="New Document" Name="Pool" >
<Process xmi:id="_45T0YZVvEdusYsgvXrrVmQ" Name="Process111">
<GraphicalElements xsi:type="bpdm:Task"
xmi:id="_45T0Y5VvEdusYsgvXrrVmQ" Id="_wQouYJVvEdusYsgvXrrVmQ"
Pool="_45T0YJVvEdusYsgvXrrVmQ" Name="task1"/>
</Process>
</Pools>
</bp:BusinessProcessDiagram>
</xmi:XMI>
i have written a simple rule for this model , which print name of
GraphicalElements that is type of bpdm:task. the rule is following.
rule bpmnSeq2bpelSeq
from input : bpdm!BusinessProcessDiagram
do {
input.Name -> println();
for(p3 in input.getGraphicalElement)
if(p3.oclIsTypeOf(bpdm!Task))
'true'->println();
p3.Name->println();
it gave this error.
An internal error occurred during: "Launching".
at
org.atl.eclipse.adt.launching.AtlLaunchConfigurationDelegate .runAtlLauncher(AtlLaunchConfigurationDelegate.java:226)
at
org.atl.eclipse.adt.launching.AtlLaunchConfigurationDelegate .runAtlLauncher(AtlLaunchConfigurationDelegate.java:154)
at
org.atl.eclipse.adt.launching.AtlLaunchConfigurationDelegate .runAtlLauncher(AtlLaunchConfigurationDelegate.java:136)
at
org.atl.eclipse.adt.launching.AtlLaunchConfigurationDelegate .runAtlLauncher(AtlLaunchConfigurationDelegate.java:117)
at
org.atl.eclipse.adt.launching.AtlLaunchConfigurationDelegate .launch(AtlLaunchConfigurationDelegate.java:95)
at
org.eclipse.debug.internal.core.LaunchConfiguration.launch(L aunchConfiguration.java:639)
at
org.eclipse.debug.internal.core.LaunchConfiguration.launch(L aunchConfiguration.java:565)
at
org.eclipse.debug.internal.ui.DebugUIPlugin.buildAndLaunch(D ebugUIPlugin.java:754)
at
org.eclipse.debug.internal.ui.DebugUIPlugin$6.run(DebugUIPlu gin.java:944)
at org.eclipse.core.internal.jobs.Worker.run(Worker.java:58)
i think it give error because of Pool and Id entity of GraphicalElements.
when i remove both of these entity then it works fine.
Id is a type of EObject and Pool is a class.
Pool is container of Process , and Process contain GraphicalElements.
pls. help me
Brajesh K.
| Re: [ATL] how to use entity reference in input model [message #4586 is a reply to message #4366] |
Fri, 29 December 2006 03:59   |
Hi ,
thanks for response Frédéric.
actually my metamodel file is too big , nevertheless i give this metamodel.
MetaModel :bpmn.ecore
<ecore:EPackage xmi:version="2.0"
xmlns:ecore="http://www.eclipse.org/emf/2002/Ecore" name="bpdm"
nsURI="bpdm" nsPrefix="bpdm">
<eClassifiers xsi:type="ecore:EClass" name="Activity"
eSuperTypes="#//FlowObject">
<eAnnotations source="http://www.eclipse.org/emf/2002/GenModel">
<details key="documentation" value=" *
 * @author
s
 * @version 5, Fri Dec 09 14:35:07 2005
 * @since
v1.0"/>
</eAnnotations>
<eStructuralFeatures xsi:type="ecore:EReference" name="InputSets"
upperBound="-1"
eType="#//Input" containment="true"/>
<eStructuralFeatures xsi:type="ecore:EReference" name="OutputSets"
upperBound="-1"
eType="#//Output" containment="true"/>
<eStructuralFeatures xsi:type="ecore:EReference" name="IORules"
upperBound="-1"
eType="#//Expression" containment="true"/>
<eStructuralFeatures xsi:type="ecore:EReference" name="Properties"
upperBound="-1"
eType="#//Property" containment="true"/>
<eStructuralFeatures xsi:type="ecore:EAttribute" name="StartQuantity"
lowerBound="1"
eType="ecore:EDataType
http://www.eclipse.org/emf/2002/Ecore#//EInt" defaultValueLiteral="1"/>
<eStructuralFeatures xsi:type="ecore:EAttribute" name="ActivityType"
lowerBound="1"
eType="#//ActivityType"/>
<eStructuralFeatures xsi:type="ecore:EAttribute" name="Status"
lowerBound="1"
eType="#//ActivityStatus"/>
<eStructuralFeatures xsi:type="ecore:EAttribute" name="LoopType"
lowerBound="1"
eType="#//ActivityLoopType"/>
</eClassifiers>
<eClassifiers xsi:type="ecore:EClass" name="FlowObject"
eSuperTypes="#//GraphicalObject">
 * @author
s
 * @version 8, Fri Dec 09 14:35:08 2005
 * @since
v1.0"/>
</eAnnotations>
<eStructuralFeatures xsi:type="ecore:EReference" name="Pool"
lowerBound="1" eType="#//Pool"
<eStructuralFeatures xsi:type="ecore:EReference" name="Lanes"
upperBound="-1"
eType="#//Lane" containment="true"/>
<eStructuralFeatures xsi:type="ecore:EReference" name="Assignments"
upperBound="-1"
eType="#//Assignment" containment="true"/>
<eStructuralFeatures xsi:type="ecore:EAttribute" name="Name"
lowerBound="1" eType="ecore:EDataType
http://www.eclipse.org/emf/2002/Ecore#//EString"/>
</eClassifiers>
<eClassifiers xsi:type="ecore:EClass" name="String"/>
<eClassifiers xsi:type="ecore:EClass" name="AdHoc">
 * @author
s
 * @version 1, Fri Dec 09 14:35:07 2005
 * @since
v1.0"/>
</eAnnotations>
</eClassifiers>
<eClassifiers xsi:type="ecore:EClass" name="Annotation"
eSuperTypes="#//Artifact">
 * @author
s
 * @version 3, Fri Dec 09 14:35:07 2005
 * @since
v1.0"/>
</eAnnotations>
<eStructuralFeatures xsi:type="ecore:EAttribute" name="Text"
</eClassifiers>
<eClassifiers xsi:type="ecore:EClass" name="Artifact"
 * @author
s
 * @since
v1.0"/>
</eAnnotations>
eType="#//Pool" containment="true"/>
<eStructuralFeatures xsi:type="ecore:EReference" name="Lane"
upperBound="-1" eType="#//Lane"
<eStructuralFeatures xsi:type="ecore:EAttribute" name="ArtifactType"
lowerBound="1"
eType="#//ArtifactType"/>
</eClassifiers>
<eClassifiers xsi:type="ecore:EClass" name="GraphicalObject"
eSuperTypes="#//BPDElement">
 * @author
s
 * @version 3, Fri Dec 09 14:35:08 2005
 * @since
v1.0"/>
</eAnnotations>
<eStructuralFeatures xsi:type="ecore:EAttribute" name="Categories"
upperBound="-1"
<eStructuralFeatures xsi:type="ecore:EAttribute" name="Documenation"
eType="ecore:EDataType http://www.eclipse.org/emf/2002/Ecore#//EString"/>
</eClassifiers>
<eClassifiers xsi:type="ecore:EClass" name="Assignment">
 * @author
s
 * @version 10, Fri Dec 09 14:35:07 2005
 * @since
v1.0"/>
</eAnnotations>
<eStructuralFeatures xsi:type="ecore:EReference" name="From"
lowerBound="1" eType="#//Expression"
<eStructuralFeatures xsi:type="ecore:EReference" name="To"
lowerBound="1" eType="#//Property"
<eStructuralFeatures xsi:type="ecore:EAttribute" name="AssignTime"
eType="#//AssignTime"/>
</eClassifiers>
<eClassifiers xsi:type="ecore:EClass" name="GraphicalConnectingObject"
 * @author
s
 * @version 2, Fri Dec 09 14:35:08 2005
 * @since
v1.0"/>
</eAnnotations>
<eStructuralFeatures xsi:type="ecore:EReference" name="source"
lowerBound="1"
eType="#//Object" containment="true"/>
<eStructuralFeatures xsi:type="ecore:EReference" name="target"
lowerBound="1"
<eStructuralFeatures xsi:type="ecore:EReference" name="Name"
eType="#//String"/>
</eClassifiers>
<eClassifiers xsi:type="ecore:EClass" name="Association"
eSuperTypes="#//GraphicalConnectingObject">
 * @author
s
 * @version 6, Fri Dec 09 14:35:07 2005
 * @since
v1.0"/>
</eAnnotations>
<eStructuralFeatures xsi:type="ecore:EAttribute" name="Direction"
lowerBound="1"
eType="#//AssociationDirection"/>
</eClassifiers>
<eClassifiers xsi:type="ecore:EClass" name="BPDElement"
eSuperTypes="#//Object">
 * @author
s
 * @version 1, Fri Dec 09 14:35:08 2005
 * @since
v1.0"/>
</eAnnotations>
</eClassifiers>
<eClassifiers xsi:type="ecore:EClass" name="Object">
 * @author
s
 * @version 11, Fri Dec 09 14:35:09 2005
 * @since
v1.0"/>
</eAnnotations>
<eStructuralFeatures xsi:type="ecore:EReference" name="Id"
lowerBound="1" eType="ecore:EClass
http://www.eclipse.org/emf/2002/Ecore#//EObject"/>
</eClassifiers>
<eClassifiers xsi:type="ecore:EClass" name="BusinessProcessDiagram">
 * @author
s
 * @since
v1.0"/>
</eAnnotations>
<eStructuralFeatures xsi:type="ecore:EReference" name="Pools"
lowerBound="1" upperBound="-1"
<eStructuralFeatures xsi:type="ecore:EAttribute" name="Id"
eType="ecore:EDataType http://www.eclipse.org/emf/2002/Ecore#//EInt"
changeable="false" defaultValueLiteral="0"/>
<eStructuralFeatures xsi:type="ecore:EAttribute" name="Documentation"
<eStructuralFeatures xsi:type="ecore:EAttribute" name="CreationDate"
eType="ecore:EDataType http://www.eclipse.org/emf/2002/Ecore#//EDate"/>
<eStructuralFeatures xsi:type="ecore:EAttribute" name="QueryLanguage"
name="ExpressionLanguage" eType="ecore:EDataType
name="ModificationDate" eType="ecore:EDataType
<eStructuralFeatures xsi:type="ecore:EAttribute" name="Version"
<eStructuralFeatures xsi:type="ecore:EAttribute" name="Author"
<eStructuralFeatures xsi:type="ecore:EAttribute" name="Language"
</eClassifiers>
<eClassifiers xsi:type="ecore:EClass" name="Date">
 * @author
s
 * @since
v1.0"/>
</eAnnotations>
</eClassifiers>
<eClassifiers xsi:type="ecore:EClass" name="Cancel"
eSuperTypes="#//Result">
 * @author
s
 * @since
v1.0"/>
</eAnnotations>
</eClassifiers>
<eClassifiers xsi:type="ecore:EClass" name="Result">
 * @author
s
 * @version 2, Fri Dec 09 14:35:09 2005
 * @since
v1.0"/>
</eAnnotations>
upperBound="-1" eType="#//String"/>
</eClassifiers>
<eClassifiers xsi:type="ecore:EClass" name="Trigger">
 * @author
s
 * @since
v1.0"/>
</eAnnotations>
</eClassifiers>
<eClassifiers xsi:type="ecore:EClass" name="CollapsedSubProcess"
eSuperTypes="#//SubProcess">
 * @author
s
 * @since
v1.0"/>
</eAnnotations>
<eStructuralFeatures xsi:type="ecore:EReference" name="Loop"
lowerBound="1" eType="#//Loop"/>
<eStructuralFeatures xsi:type="ecore:EReference" name="MultiInstance"
lowerBound="1"
eType="#//MultiInstance"/>
<eStructuralFeatures xsi:type="ecore:EReference" name="Compensation"
lowerBound="1"
eType="#//Compensation"/>
<eStructuralFeatures xsi:type="ecore:EAttribute" name="AdHoc"
http://www.eclipse.org/emf/2002/Ecore#//EBoolean"/>
</eClassifiers>
<eClassifiers xsi:type="ecore:EClass" name="SubProcess"
eSuperTypes="#//Activity">
 * @author
s
 * @version 3, Fri Dec 09 14:35:09 2005
 * @since
v1.0"/>
</eAnnotations>
<eStructuralFeatures xsi:type="ecore:EReference" name="Transaction"
eType="#//Transaction"
<eStructuralFeatures xsi:type="ecore:EAttribute" name="IsATransaction"
lowerBound="1"
defaultValueLiteral="false"/>
<eStructuralFeatures xsi:type="ecore:EAttribute" name="SubProcessType"
lowerBound="1"
eType="#//SubProcessType"/>
</eClassifiers>
<eClassifiers xsi:type="ecore:EClass" name="Collection">
 * @author
s
 * @since
v1.0"/>
</eAnnotations>
</eClassifiers>
<eClassifiers xsi:type="ecore:EClass" name="Compensation"
 * @author
s
 * @version 4, Fri Dec 09 14:35:08 2005
 * @since
v1.0"/>
</eAnnotations>
</eClassifiers>
<eClassifiers xsi:type="ecore:EClass" name="ComplexDecision_Merge"
eSuperTypes="#//Gateway">
 * @author
s
 * @since
v1.0"/>
</eAnnotations>
<eStructuralFeatures xsi:type="ecore:EReference" name="Gates"
upperBound="-1"
eType="#//Gate" containment="true"/>
name="OutgoingSequenceFlow" lowerBound="1"
eType="#//SequenceFlow" containment="true"/>
<eStructuralFeatures xsi:type="ecore:EReference" name="outgoing2"
upperBound="-1"
eType="#//SequenceFlow"/>
upperBound="-1"
name="IncomingCondition" eType="#//Expression"/>
name="OutgoingCondition" eType="#//Expression"/>
</eClassifiers>
<eClassifiers xsi:type="ecore:EClass" name="Gateway"
 * @author
s
 * @since
v1.0"/>
</eAnnotations>
<eStructuralFeatures xsi:type="ecore:EAttribute" name="GatewayType"
lowerBound="1"
eType="#//GatewayType"/>
</eClassifiers>
<eClassifiers xsi:type="ecore:EClass" name="DataBasedGateway"
 * @author
s
 * @since
v1.0"/>
</eAnnotations>
upperBound="-1"
<eStructuralFeatures xsi:type="ecore:EReference" name="DefaultGate"
eType="#//Gate"
<eStructuralFeatures xsi:type="ecore:EReference" name="Assignments1"
upperBound="-1"
<eStructuralFeatures xsi:type="ecore:EReference" name="Assignments2"
upperBound="-1"
<eStructuralFeatures xsi:type="ecore:EAttribute" name="MarkerVisible"
lowerBound="1"
<eStructuralFeatures xsi:type="ecore:EAttribute" name="XORType"
lowerBound="1"
eType="#//XORType"/>
</eClassifiers>
<eClassifiers xsi:type="ecore:EClass" name="ExclusiveDecision_Merge"
 * @author
s
 * @since
v1.0"/>
</eAnnotations>
lowerBound="1"
name="InstantiateFalse" lowerBound="1"
lowerBound="2" upperBound="-1"
eType="#//Gate"/>
upperBound="-1"
</eClassifiers>
<eClassifiers xsi:type="ecore:EClass" name="DataObject"
 * @author
s
 * @since
v1.0"/>
</eAnnotations>
upperBound="-1"
name="RequiredForStart" lowerBound="1"
defaultValueLiteral="true"/>
name="ProducedAtCompletion" lowerBound="1"
<eStructuralFeatures xsi:type="ecore:EAttribute" name="State"
</eClassifiers>
<eClassifiers xsi:type="ecore:EClass" name="EmbeddedSubProcess"
eSuperTypes="#//CollapsedSubProcess">
 * @author
s
 * @since
v1.0"/>
</eAnnotations>
name="GraphicalElements" upperBound="-1"
<eStructuralFeatures xsi:type="ecore:EAttribute" name="AdHocOrdering"
eType="#//AdHocOrdering"/>
name="AdHocCompletionCondition"
</eClassifiers>
<eClassifiers xsi:type="ecore:EClass" name="End" eSuperTypes="#//Event">
<details key="documentation" value=" * 1) Constraint on
Implementation:-
{ if (End.Result.Name == Messag
 * e)
2) Constraint on ErrorCode:-
Error)
3) Constraint on LinkId:-
{ if
(End.Result.Name == Link) }
 * @author
s
 * @since
v1.0"/>
</eAnnotations>
<eStructuralFeatures xsi:type="ecore:EReference" name="Activity"
lowerBound="1"
<eStructuralFeatures xsi:type="ecore:EReference" name="Message"
lowerBound="1"
eType="#//Message" containment="true"/>
<eStructuralFeatures xsi:type="ecore:EReference" name="ProcessRef"
lowerBound="1"
eType="#//Process" containment="true"/>
<eStructuralFeatures xsi:type="ecore:EAttribute" name="Result"
lowerBound="1"
eType="#//EndTriggers"/>
<eStructuralFeatures xsi:type="ecore:EAttribute" name="LinkId"
lowerBound="1"
<eStructuralFeatures xsi:type="ecore:EAttribute" name="ErrorCode"
lowerBound="1"
<eStructuralFeatures xsi:type="ecore:EAttribute" name="Results"
lowerBound="2"
upperBound="-1" eType="#//EndTriggers"/>
<eStructuralFeatures xsi:type="ecore:EAttribute" name="Implementation"
lowerBound="1"
</eClassifiers>
<eClassifiers xsi:type="ecore:EClass" name="Event"
 * @author
s
 * @since
v1.0"/>
</eAnnotations>
<eStructuralFeatures xsi:type="ecore:EAttribute" name="EventType"
lowerBound="1"
http://www.eclipse.org/emf/2002/Ecore#//EString" defaultValueLiteral=""/>
</eClassifiers>
<eClassifiers xsi:type="ecore:EClass" name="Entity">
 * @author
s
 * @since
v1.0"/>
</eAnnotations>
</eClassifiers>
<eClassifiers xsi:type="ecore:EClass" name="Error"
 * @author
s
 * @since
v1.0"/>
</eAnnotations>
</eClassifiers>
<eClassifiers xsi:type="ecore:EClass" name="EventBasedGateway"
eSuperTypes="#//ExclusiveDecision_Merge">
 * @author
s
 * @since
v1.0"/>
</eAnnotations>
<eStructuralFeatures xsi:type="ecore:EReference" name="Gate"
upperBound="-1" eType="#//Gate"
name="outgoingSeqFlow" lowerBound="1"
name="IncomingSeqFlow" upperBound="-1"
<eStructuralFeatures xsi:type="ecore:EReference" name="assignment3"
upperBound="-1"
<eStructuralFeatures xsi:type="ecore:EAttribute" name="Instantiate"
eType="ecore:EDataType http://www.eclipse.org/emf/2002/Ecore#//EBoolean"
<eStructuralFeatures xsi:type="ecore:EReference" name="XORType"
upperBound="-1"
eType="#//String"/>
</eClassifiers>
<eClassifiers xsi:type="ecore:EClass" name="ExpandedSubProcess"
 * @author
s
 * @since
v1.0"/>
</eAnnotations>
</eClassifiers>
<eClassifiers xsi:type="ecore:EClass" name="Expression">
 * @author
s
 * @version 11, Fri Dec 09 14:35:08 2005
 * @since
v1.0"/>
</eAnnotations>
<eStructuralFeatures xsi:type="ecore:EAttribute" name="Expression"
lowerBound="1"
</eClassifiers>
<eClassifiers xsi:type="ecore:EClass" name="Gate">
 * @author
s
 * @version 6, Fri Dec 09 14:35:08 2005
 * @since
v1.0"/>
</eAnnotations>
<eStructuralFeatures xsi:type="ecore:EReference" name="SequenceFlow"
lowerBound="1"
</eClassifiers>
<eClassifiers xsi:type="ecore:EClass" name="Group"
 * @author
s
 * @since
v1.0"/>
</eAnnotations>
</eClassifiers>
<eClassifiers xsi:type="ecore:EClass" name="InclusiveDecision_Merge"
 * @author
s
 * @since
v1.0"/>
</eAnnotations>
eType="#//Gate"
upperBound="-1"
eType="#//Gate"/>
name="OutgoingSequenceFlow2"
lowerBound="1" eType="#//SequenceFlow" containment="true"/>
upperBound="-1"
name="OutgoingSequenceFlow1"
upperBound="-1"
</eClassifiers>
<eClassifiers xsi:type="ecore:EClass" name="IndependentSubProcess"
 * @author
s
 * @since
v1.0"/>
</eAnnotations>
<eStructuralFeatures xsi:type="ecore:EReference" name="DiagramRef"
lowerBound="1"
eType="#//BusinessProcessDiagram" containment="true"/>
lowerBound="1"
name="InputPropertyMaps" upperBound="-1"
name="OutPutPropertyMaps" upperBound="-1"
</eClassifiers>
<eClassifiers xsi:type="ecore:EClass" name="Input">
 * @author
s
 * @since
v1.0"/>
</eAnnotations>
</eClassifiers>
<eClassifiers xsi:type="ecore:EClass" name="Intermediate"
Implementation:-
{ if (Intermediate.Trigger.Name
Message) }
2) Constraint on TimeDate and TimeCycle:-
if (In
 * termediate.Trigger.Name == Timer) }
3)
 * { if
(Intermediate.Trigger.Name == Error }
4) Constraint on
LinkI
 * d:-
{ if (Intermediate.Trigger.Name == Link
 * @author s
 * @version 3,
 * @since v1.0"/>
</eAnnotations>
lowerBound="1"
lowerBound="1"
<eStructuralFeatures xsi:type="ecore:EReference" name="Target"
eType="#//Object"
lowerBound="1"
<eStructuralFeatures xsi:type="ecore:EReference" name="ErrorCode"
lowerBound="1"
eType="#//String"/>
<eStructuralFeatures xsi:type="ecore:EReference" name="LinkId"
lowerBound="1"
eType="#//String"/>
lowerBound="1"
eType="#//ImplementationType"/>
<eStructuralFeatures xsi:type="ecore:EAttribute" name="Trigger"
lowerBound="1"
eType="#//IntermediateTriggers"/>
<eStructuralFeatures xsi:type="ecore:EAttribute" name="Triggers"
lowerBound="2"
upperBound="-1" eType="#//IntermediateTriggers"/>
<eStructuralFeatures xsi:type="ecore:EReference" name="RuleName"
lowerBound="1"
eType="#//Rule"/>
<eStructuralFeatures xsi:type="ecore:EAttribute" name="TimeCycle"
<eStructuralFeatures xsi:type="ecore:EAttribute" name="TimeDate"
</eClassifiers>
<eClassifiers xsi:type="ecore:EClass" name="Lane"
eSuperTypes="#//Swimlane">
 * @author
s
 * @version 5, Fri Dec 09 14:35:08 2005
 * @since
v1.0"/>
</eAnnotations>
<eStructuralFeatures xsi:type="ecore:EReference" name="parentpool"
lowerBound="1"
<eStructuralFeatures xsi:type="ecore:EReference" name="parentLane"
eType="#//Lane"
</eClassifiers>
<eClassifiers xsi:type="ecore:EClass" name="Swimlane"
 * @author
s
 * @since
v1.0"/>
</eAnnotations>
</eClassifiers>
<eClassifiers xsi:type="ecore:EClass" name="Link"
 * @author
s
 * @since
v1.0"/>
</eAnnotations>
</eClassifiers>
<eClassifiers xsi:type="ecore:EClass" name="Loop">
 * @author
s
 * @since
v1.0"/>
</eAnnotations>
</eClassifiers>
<eClassifiers xsi:type="ecore:EClass" name="ManualTask"
eSuperTypes="#//Task">
 * @author
s
 * @since
v1.0"/>
</eAnnotations>
<eStructuralFeatures xsi:type="ecore:EAttribute" name="Performers"
upperBound="-1"
</eClassifiers>
<eClassifiers xsi:type="ecore:EClass" name="Task"
 * @author
s
 * @version 4, Fri Dec 09 14:35:09 2005
 * @since
v1.0"/>
</eAnnotations>
<eStructuralFeatures xsi:type="ecore:EAttribute" name="TaskType"
lowerBound="1"
eType="#//TaskType"/>
</eClassifiers>
<eClassifiers xsi:type="ecore:EClass" name="Message"
eSuperTypes="#//Trigger">
 * @author
s
 * @version 9, Fri Dec 09 14:35:08 2005
 * @since
v1.0"/>
</eAnnotations>
lowerBound="1" eType="#//Participant"
<eStructuralFeatures xsi:type="ecore:EReference" name="Property"
upperBound="-1"
lowerBound="1" eType="#//Participant"/>
</eClassifiers>
<eClassifiers xsi:type="ecore:EClass" name="MessageFlow"
 * @author
s
 * @version 13, Fri Dec 09 14:35:08 2005
 * @since
v1.0"/>
</eAnnotations>
eType="#//Message"
</eClassifiers>
<eClassifiers xsi:type="ecore:EClass" name="MultiInstance">
 * @author
s
 * @since
v1.0"/>
</eAnnotations>
</eClassifiers>
<eClassifiers xsi:type="ecore:EClass" name="MultiInstanceLoopActivity"
 * @author
s
 * @since
v1.0"/>
</eAnnotations>
<eStructuralFeatures xsi:type="ecore:EAttribute" name="LoopCounter"
lowerBound="1"
http://www.eclipse.org/emf/2002/Ecore#//EInt" defaultValueLiteral="0"/>
<eStructuralFeatures xsi:type="ecore:EReference" name="MI_Condition"
lowerBound="1"
name="ComplexMI_FlowCondition"
name="MI_FlowCondition" lowerBound="1"
eType="#//MIFlowConditionType"/>
<eStructuralFeatures xsi:type="ecore:EAttribute" name="MI_Ordering"
lowerBound="1"
eType="#//MIOrderingType"/>
</eClassifiers>
<eClassifiers xsi:type="ecore:EClass" name="Multiple"
 * @author
s
 * @since
v1.0"/>
</eAnnotations>
</eClassifiers>
<eClassifiers xsi:type="ecore:EClass" name="Output">
 * @author
s
 * @version 1, Fri Dec 09 14:35:09 2005
 * @since
v1.0"/>
</eAnnotations>
</eClassifiers>
<eClassifiers xsi:type="ecore:EClass" name="ParallerFork_Join"
 * @author
s
 * @since
v1.0"/>
</eAnnotations>
upperBound="-1"
eType="#//Gate"/>
upperBound="-1"
</eClassifiers>
<eClassifiers xsi:type="ecore:EClass" name="Participant">
 * @author
s
 * @since
v1.0"/>
</eAnnotations>
<eStructuralFeatures xsi:type="ecore:EReference" name="Entity"
eType="#//Entity"/>
<eStructuralFeatures xsi:type="ecore:EReference" name="Role"
eType="#//Role"/>
name="ParticipantType" upperBound="-1"
</eClassifiers>
<eClassifiers xsi:type="ecore:EClass" name="Pool"
 * @author
s
 * @version 6, Fri Dec 09 14:35:09 2005
 * @since
v1.0"/>
</eAnnotations>
<eStructuralFeatures xsi:type="ecore:EReference" name="Process"
eType="#//Process"
<eStructuralFeatures xsi:type="ecore:EReference" name="Participant"
lowerBound="1"
eType="#//Participant" containment="true"/>
<eStructuralFeatures xsi:type="ecore:EReference" name="lanes"
name="BoundaryVisible" lowerBound="1"
</eClassifiers>
<eClassifiers xsi:type="ecore:EClass" name="Process">
 * @author
s
 * @version 9, Fri Dec 09 14:35:09 2005
 * @since
v1.0"/>
</eAnnotations>
upperBound="-1"
upperBound="-1"
| Re: [ATL] how to use entity reference in input model [message #4666 is a reply to message #4586] |
Fri, 29 December 2006 04:43   |
Thanks for the metamodel.
But you are right: it is big.
It would help a lot if you could find the smallest metamodel exhibiting
the problematic behavior.
Frédéric Jouault
brajesh K. wrote:
> Hi ,
 * @author
> s
 * @since
> v1.0"/>
> </eAnnotations>
> upperBound="-1"
> upperBound="-1"
> upperBound="-1"
> upperBound="-1"
> lowerBound="1"
> lowerBound="1"
> lowerBound="1"
> lowerBound="1"
> </eClassifiers>
 * @author
> s
 * @since
> v1.0"/>
> </eAnnotations>
> upperBound="-1"
> upperBound="-1"
> </eClassifiers>
 * @author
> s
 * @since
> v1.0"/>
> </eAnnotations>
> </eClassifiers>
 * @author
> s
 * @since
> v1.0"/>
> </eAnnotations>
> </eClassifiers>
 * @author
> s
 * @since
> v1.0"/>
> </eAnnotations>
> lowerBound="1"
> </eClassifiers>
 * @author
> s
 * @since
> v1.0"/>
> </eAnnotations>
> upperBound="-1"
> </eClassifiers>
 * @author
> s
 * @since
> v1.0"/>
> </eAnnotations>
> </eClassifiers>
 * @author
> s
 * @since
> v1.0"/>
> </eAnnotations>
> lowerBound="1"
> lowerBound="1"
> eType="#//String"/>
> </eClassifiers>
 * @author
> s
 * @since
> v1.0"/>
> </eAnnotations>
> lowerBound="1"
> </eClassifiers>
 * @author
> s
 * @since
> v1.0"/>
> </eAnnotations>
> </eClassifiers>
 * @author
> s
 * @since
> v1.0"/>
> </eAnnotations>
> </eClassifiers>
 * @author
> s
 * @since
> v1.0"/>
> </eAnnotations>
> </eClassifiers>
 * @author
> s
 * @since
> v1.0"/>
> </eAnnotations>
> </eClassifiers>
 * @author
> s
 * @since
> v1.0"/>
> </eAnnotations>
> </eClassifiers>
 * @author
> s
 * @since
> v1.0"/>
> </eAnnotations>
> </eClassifiers>
 * @author
> s
 * @since
> v1.0"/>
> </eAnnotations>
> </eClassifiers>
 * @author
> s
 * @since
> v1.0"/>
> </eAnnotations>
> lowerBound="1"
> lowerBound="1"
> </eClassifiers>
 * @author
> s
 * @since
> v1.0"/>
> </eAnnotations>
> name="IsATransaction" lowerBound="1"
> name="SubProcessType" lowerBound="1"
> </eClassifiers>
 * @author
> s
 * @since
> v1.0"/>
> </eAnnotations>
> </eClassifiers>
 * @author
> s
 * @since
> v1.0"/>
> </eAnnotations>
> </eClassifiers>
 * @author
> s
 * @since
> v1.0"/>
> </eAnnotations>
> upperBound="-1"
> upperBound="-1"
> upperBound="-1"
> </eClassifiers>
 * @author
> s
 * @since
> v1.0"/>
> </eAnnotations>
> lowerBound="1"
> </eClassifiers>
 * @author
> s
 * @since
> v1.0"/>
> </eAnnotations>
> upperBound="-1"
> eType="#//Gate"
> upperBound="-1"
> upperBound="-1"
> lowerBound="1"
> lowerBound="1"
> </eClassifiers>
 * @author
> s
 * @since
> v1.0"/>
> </eAnnotations>
> lowerBound="1"
> eType="#//Gate"/>
> upperBound="-1"
> </eClassifiers>
 * @author
> s
 * @since
> v1.0"/>
> </eAnnotations>
> upperBound="-1"
> </eClassifiers>
 * @author
> s
 * @since
> v1.0"/>
> </eAnnotations>
> </eClassifiers>
> Implementation:-
 * e)
> == Error)
> if (End.Result.Name == Link) }
> @author s
> @since v1.0"/>
> </eAnnotations>
> lowerBound="1"
> lowerBound="1"
> lowerBound="1"
> lowerBound="1"
> lowerBound="1"
> lowerBound="1"
> lowerBound="2"
> name="Implementation" lowerBound="1"
> </eClassifiers>
 * @author
> s
 * @since
> v1.0"/>
> </eAnnotations>
> lowerBound="1"
> </eClassifiers>
 * @author
> s
 * @since
> v1.0"/>
> </eAnnotations>
> </eClassifiers>
 * @author
> s
 * @since
> v1.0"/>
> </eAnnotations>
> </eClassifiers>
 * @author
> s
 * @since
> v1.0"/>
> </eAnnotations>
> upperBound="-1"
> upperBound="-1"
> eType="#//String"/>
> </eClassifiers>
 * @author
> s
 * @since
> v1.0"/>
> </eAnnotations>
> </eClassifiers>
 * @author
> s
 * @since
> v1.0"/>
> </eAnnotations>
> lowerBound="1"
> </eClassifiers>
 * @author
> s
 * @since
> v1.0"/>
> </eAnnotations>
> lowerBound="1"
> </eClassifiers>
 * @author
> s
 * @since
> v1.0"/>
> </eAnnotations>
> </eClassifiers>
 * @author
> s
 * @since
> v1.0"/>
> </eAnnotations>
> eType="#//Gate"
> upperBound="-1"
> eType="#//Gate"/>
> upperBound="-1"
> upperBound="-1"
> </eClassifiers>
 * @author
> s
 * @since
> v1.0"/>
> </eAnnotations>
> lowerBound="1"
> lowerBound="1"
> </eClassifiers>
 * @author
> s
 * @since
> v1.0"/>
> </eAnnotations>
> </eClassifiers>
> Implementation:-
> == Message) }
> TimeCycle:-
{ if (In
> Timer) }
3) Constraint on ErrorCode:-
> if (Intermediate.Trigger.Name == Error }
4) Constraint on
> LinkI
 * d:-
 * @author s
 * @version 3,
 * @since v1.0"/>
> </eAnnotations>
> lowerBound="1"
> lowerBound="1"
> eType="#//Object"
> lowerBound="1"
> lowerBound="1"
> eType="#//String"/>
> lowerBound="1"
> eType="#//String"/>
> lowerBound="1"
> lowerBound="2"
> lowerBound="1"
> eType="#//Rule"/>
> </eClassifiers>
 * @author
> s
 * @since
> v1.0"/>
> </eAnnotations>
> lowerBound="1"
> eType="#//Lane"
> </eClassifiers>
 * @author
> s
 * @since
> v1.0"/>
> </eAnnotations>
> </eClassifiers>
> <eClassifiers xsi:type="ecore:EClass" name="Link" eSuperTypes="#//Result">
 * @author
> s
 * @since
> v1.0"/>
> </eAnnotations>
> </eClassifiers>
 * @author
> s
 * @since
> v1.0"/>
> </eAnnotations>
> </eClassifiers>
 * @author
> s
 * @since
> v1.0"/>
> </eAnnotations>
> upperBound="-1"
> </eClassifiers>
 * @author
> s
 * @since
> v1.0"/>
> </eAnnotations>
> lowerBound="1"
> </eClassifiers>
 * @author
> s
 * @since
> v1.0"/>
> </eAnnotations>
> upperBound="-1"
> </eClassifiers>
 * @author
> s
 * @since
> v1.0"/>
> </eAnnotations>
> eType="#//Message"
> </eClassifiers>
 * @author
> s
 * @since
> v1.0"/>
> </eAnnotations>
> </eClassifiers>
 * @author
> s
 * @since
> v1.0"/>
> </eAnnotations>
> lowerBound="1"
> lowerBound="1"
> lowerBound="1"
> </eClassifiers>
 * @author
> s
 * @since
> v1.0"/>
> </eAnnotations>
> </eClassifiers>
 * @author
> s
 * @since
> v1.0"/>
> </eAnnotations>
> </eClassifiers>
 * @author
> s
 * @since
> v1.0"/>
> </eAnnotations>
> upperBound="-1"
> eType="#//Gate"/>
> upperBound="-1"
| Re: [ATL] how to use entity reference in input model [message #4874 is a reply to message #4666] |
Tue, 02 January 2007 05:59  |
Hi ,
here i am posting small meta model in km3 format.
class BusinessProcessDiagram
attribute Name:String;
reference pools[*] : Pool;
class Pool extends ObjectID
attribute Document:String;
reference Process[*] : Process;
class Process
attribute GraphicalElements:Task;
class Task extends ObjectID
class ObjectID
attribute Id:String;
my sample input model file:
<?xml version="1.0" encoding="ASCII"?>
<xmi:XMI xmi:version="2.0" xmlns:xmi="http://www.omg.org/XMI"
xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:bp="bpdm">
<bp:BusinessProcessDiagram xmi:id="_tLfiYJVvEdusYsgvXrrVmQ" Name="BPD1">
Documenation="New Document" Name="Pool1">
<Process xmi:id="_WFoRwZcqEdusf_1zRX5pHw" Name="Process1">
<GraphicalElements xsi:type="bp:Task"
xmi:id="_eK1eUJcqEdusf_1zRX5pHw" Id="_aNhUMJcqEdusf_1zRX5pHw"
Pool="_45T0YJVvEdusYsgvXrrVmQ" Name="Task1"/>
</Process>
</Pools>
</xmi:XMI>
my rule for this input model:
helper context bpdm!BusinessProcessDiagram def : getGraphicalElement :
Sequence(bpdm!Object) =
self.Pools->collect(e|e)->asSequence()->collect(process|process.Process)- >asSequence()
->collect->(g|g.GraphicalElement)-> asSequence();
rule bpmn2bpel
do {
for(p in input.GraphicalElement)
p.Name->println();
i am just trying to get all GraphicalElement but it didn't display anything
but when i removed Pool entry from GraphicalElements then it print
GraphicalElements . can you tell me how to reference Pool from
GraphicalElements .
thanks
Brajesh K
Current Time: Mon Nov 17 19:48:58 EST 2025
Powered by FUDForum. Page generated in 0.04875 seconds
