Home » Archived » XML Schema Definition (XSD) » Schema has not been resolved
Schema has not been resolved [message #46178] |
Thu, 27 May 2004 03:54  |
Originally posted by: invalid.soft-gems.net
Hi all,
I've got a problem when I moved my schemas from local harddisk to a web
server. There is this root schema (imported via an absolute path), which
includes 3 other schemas (which in turn import yet a couple of other
schemas). All the schemas are located in the same folder on the web server
(an IBM AIX machine with Apache). This works mostly well and fine except
for one schema, which does not get loaded. It is one of the schemas
imported by the root schema and I can't for my life find any reason for
the failing load. Using Internet Explorer or XML Spy the schema can be
accessed without problems. I checked exact spelling at least half a dozen
times as well as the user rights. The schema itself is not yet used, just
imported, but did not produce any error message when it was stored
locally, so I assume this is not the reason for the problem.
Any useful hint would be much appreciated.
Mike
www.soft-gems.net
Re: Schema has not been resolved [message #46238 is a reply to message #46178] |
Thu, 27 May 2004 06:17   |
--------------1E31CD7086335D0070BBEE9D
Content-Type: text/plain; charset=us-ascii
Mike,
Imported schemas are loaded on demand when the first name lookup requires it
to be resolved in order to search that namespace for the name. If the schema
isn't used, it won't be imported.
In the XSDEcoreBuilder, in order to force the lookups to happen, I used the
following:
for (Iterator i = xsdSchema.getContents().iterator(); i.hasNext(); )
Object content = i.next();
if (content instanceof XSDImport)
XSDImport xsdImport = (XSDImport)content;
xsdImport.resolveTypeDefinition(xsdImport.getNamespace(), "");
(Note that because of substitution groups, it's possible that resolving an
import can cause the importing schema to become invalid by virtue of the
substitution group contributions of the imported schema.)
Mike Lischke wrote:
> Hi all,
> Mike
> www.soft-gems.net
Content-Type: text/html; charset=us-ascii
<!doctype html public "-//w3c//dtd html 4.0 transitional//en">
<html>
Mike,
<p>Imported schemas are loaded on demand when the first name lookup requires
it to be resolved in order to search that namespace for the name.
If the schema isn't used, it won't be imported.
<p>In the XSDEcoreBuilder, in order to force the lookups to happen, I used
the following:
<blockquote>for (Iterator i = xsdSchema.getContents().iterator(); i.hasNext();
<br>{
<br> Object content = i.next();
<br> if (content instanceof XSDImport)
<br> {
<br> XSDImport xsdImport = (XSDImport)content;
<br> xsdImport.resolveTypeDefinition(xsdImport.getNamespace(),
<br> }
<br>}</blockquote>
an import can cause the importing schema to become invalid by virtue of
the substitution group contributions of the imported schema.)
<br>
<p>Mike Lischke wrote:
<blockquote TYPE=CITE>Hi all,
<p>I've got a problem when I moved my schemas from local harddisk to a
web
<br>server. There is this root schema (imported via an absolute path),
which
<br>includes 3 other schemas (which in turn import yet a couple of other
<br>schemas). All the schemas are located in the same folder on the web
server
<br>(an IBM AIX machine with Apache). This works mostly well and fine except
<br>for one schema, which does not get loaded. It is one of the schemas
<br>imported by the root schema and I can't for my life find any reason
for
<br>the failing load. Using Internet Explorer or XML Spy the schema can
be
<br>accessed without problems. I checked exact spelling at least half a
dozen
<br>times as well as the user rights. The schema itself is not yet used,
just
<br>imported, but did not produce any error message when it was stored
<br>locally, so I assume this is not the reason for the problem.
<p>Any useful hint would be much appreciated.
<p>Mike
<br>--
<br>www.soft-gems.net</blockquote>
</html>
--------------1E31CD7086335D0070BBEE9D--
Re: Schema has not been resolved [message #46265 is a reply to message #46238] |
Thu, 27 May 2004 07:07  |
Thank you for that tip Ed. I only wonder why I didn't get a warning when I
had the schemas on my local harddisk, but this may have a total unrelated
reason.
Mike
www.soft-gems.net
Re: Schema has not been resolved [message #587762 is a reply to message #46178] |
Mike,
following:
Mike Lischke wrote:
> Hi all,
> Mike
> www.soft-gems.net
<html>
Mike,
the following:
<br>{
<br> {
<br> }
<br>}</blockquote>
<br>
web
which
server
for
be
dozen
just
<p>Mike
<br>--
</html>
Re: Schema has not been resolved [message #587776 is a reply to message #46238] |
reason.
Mike
www.soft-gems.net
Current Time: Sat Jul 19 21:31:03 EDT 2025
Powered by FUDForum. Page generated in 0.03651 seconds
