EFS Problem [message #461287] |
Mon, 08 January 2007 17:21  |
Originally posted by: florianwendland.freenet.de
Hello all,
I've tried something with the Eclipse Filesystem. I've included all
required jars and plugins, both in the runtime of plugin.xml and in the
build path, but the following code displays allways the added stack trace:
IFileSystem fs = EFS.getLocalFileSystem();
The Stack Trace:
!ENTRY org.eclipse.osgi 4 0 2007-01-08 23:16:03.796
!MESSAGE Application error
!STACK 1
java.lang.NoClassDefFoundError: org/eclipse/core/filesystem/EFS
at pingproject.Application.run(Application.java:86)
at
org.eclipse.core.internal.runtime.PlatformActivator$1.run(Pl atformActivator.java:78)
at
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:92)
at
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:68)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:400)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:177)
at org.eclipse.core.launcher.Main.invokeFramework(Main.java:336 )
at org.eclipse.core.launcher.Main.basicRun(Main.java:280)
at org.eclipse.core.launcher.Main.run(Main.java:977)
at org.eclipse.core.launcher.Main.main(Main.java:952)
!SESSION 2007-01-08 23:17:55.437
eclipse.buildId=unknown
java.version=1.5.0_06
BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=de_DE
Framework arguments: -product PingProject.product
Command-line arguments: -product PingProject.product -data C:\Dokumente
und Einstellungen\Florian Wendland.FLORIAN\Eigene Dateien\TFH
Flo\SWP\Quellcode/../runtime-ping.product(1) -dev file:C:/Dokumente und
Einstellungen/Florian Wendland.FLORIAN/Eigene Dateien/TFH
Flo/SWP/Quellcode/.metadata/.plugins/org.eclipse.pde.core/pi ng.product
(1)/dev.properties -os win32 -ws win32 -arch x86
!ENTRY org.eclipse.osgi 4 0 2007-01-08 23:17:57.625
!STACK 1
java.lang.ClassCastException:
org.eclipse.core.internal.filesystem.local.LocalFileSystem
at
org.eclipse.core.internal.filesystem.InternalFileSystemCore. getFileSystem(InternalFileSystemCore.java:70)
at
org.eclipse.core.internal.filesystem.InternalFileSystemCore. getLocalFileSystem(InternalFileSystemCore.java:89)
at org.eclipse.core.filesystem.EFS.getLocalFileSystem(EFS.java: 265)
at
at
at
at
at
Re: EFS Problem [message #461294 is a reply to message #461293] |
Mon, 08 January 2007 17:55   |
Wow,
I've forgotten to chech the dependencie tab... dam :)
Thanks, that was the problem
Jakub Jurkiewicz schrieb:
> Did you add org.eclipse.core.filesystem in Dependencies tab in plugin.xml?
> I hope this help!
> Jakub Jurkiewicz
> Florian Wendland wrote:
>> Hi Jakub,
>> here it is :)
>> <library name="lib/commons-codec-1.3.jar">
>> <export name="*"/>
>> </library>
>> <library name="lib/commons-lang-2.0.jar">
>> <export name="*"/>
>> </library>
>> <library name="lib/jdom.jar">
>> <export name="*"/>
>> </library>
>> <library name="lib/mysql_driver.jar">
>> <export name="*"/>
>> </library>
>> <library name="lib/org.eclipse.jface.text_3.2.0.v20060605-1400.jar">
>> <export name="*"/>
>> </library>
>> <library name="lib/org.eclipse.text_3.2.0.v20060605-1400.jar">
>> <export name="*"/>
>> </library>
>> <library name="lib/org.eclipse.ui_3.2.1.M20060913-0800.jar">
>> <export name="*"/>
>> </library>
>> <library name="lib/org.eclipse.ui.console_3.1.100.v20060605.jar">
>> <export name="*"/>
>> </library>
>> <library name="lib/org.eclipse.ui.editors_3.2.1.r321_v20060721.jar">
>> <export name="*"/>
>> </library>
>> <library name="lib/org.eclipse.ui.ide_3.2.1.M20060915-1030.jar">
>> <export name="*"/>
>> </library>
>> <library
>> name=" lib/org.eclipse.ui.workbench.texteditor_3.2.0.v20060605-1400 .jar ">
>> <export name="*"/>
>> </library>
>> <library name="lib/org.eclipse.core.filesystem_1.0.0.v20060603.jar">
>> <export name="*"/>
>> </library>
>> <library
>> name=" lib/org.eclipse.core.filesystem.win32.x86_1.0.0.v20060603.ja r ">
>> <export name="*"/>
>> </library>
>>> Hi Florian,
>>> Could you write which exactly plugins did you include in runtime tab
>>> of plugin.xml?
>>> regards
>>> Jakub Jurkiewicz
>>>> Hello all,
>>>> the build path, but the following code displays allways the added
>>>> stack trace:
>>>> The Stack Trace:
>>>> !STACK 1
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
>>>> at sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source)
>>>> at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source)
>>>> at java.lang.reflect.Method.invoke(Unknown Source)
>>>> C:\Dokumente und Einstellungen\Florian Wendland.FLORIAN\Eigene
>>>> Dateien\TFH Flo\SWP\Quellcode/../runtime-ping.product(1) -dev
>>>> file:C:/Dokumente und Einstellungen/Florian Wendland.FLORIAN/Eigene
>>>> Dateien/TFH
>>>> !STACK 1
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
Re: EFS Problem [message #461330 is a reply to message #461294] |
Tue, 09 January 2007 07:08  |
You can check the 'automatically validate dependencies' tab on the launch configuration. That way, it will warn you when starting if you've got missing dependencies.
Alex.
PS always good to trim down the replied message if you can :-)
FUDForum. Page generated in 0.04419 seconds
