Home » Archived » OHF » bridge's document query response not matching wsdl
| bridge's document query response not matching wsdl [message #41623] |
Wed, 19 March 2008 14:55  |
I've found that when using the bridge and issuing a document query to the
registry, the WSDL says that each document will have both an "author" and
an "authors" element. However, there is no author element returned.
Looking into this it's because in the XDSDocType.java file there is the
following method:
public void setAuthor(PatientInfoType pAuthor) {
authors = new PatientInfoType[]{pAuthor};
There is no corresponding getter method because this set method is simply
a convenience method to avoid calling setAuthors instead. However, Axis
sees this setter method as indicating there should be a field called
"author" passed so it puts that in the WSDL. When Axis is marshalling the
java objects into XML though, there is no getter method so no author
element is created- leaving the mismatch between the WSDL and what's sent
over the wire.
The only place I can find that this is being called is this line in the
IheXdsBridge.java:
xdsDocument.setAuthor(authorToPatientInfoType(documentEntry. getAuthor()));
I think the convenience method should be removed and the above line
changed to:
PatientInfoType tempAuthor =
authorToPatientInfoType(documentEntry.getAuthor());
PatientInfoType tempAuthors = new PatientInfoType[]{tempAuthor};
xdsDocument.setAuthors(tempAuthors);
It could be condensed if you like, but I separated it to multiple lines
for clarity. Do you guys agree, and if so, should I submit a bug?
thanks,
Jesse
| Re: bridge's document query response not matching wsdl [message #41672 is a reply to message #41623] |
Thu, 20 March 2008 17:47   |
Hi all,
I've fixed this and as well found that the confidentiality code has a
similar problem where the wsdl shows both a confidentiality code and codes
(with an 's'). These two problems are fixed with the following changes to
XDSDocType.java:
- remove the setAuthor method
- remove the setConfidentialityCode method
- remove the getConfidentialityCode method
- add a getConfidentialityCodes method
public CodedMetadataType[] getConfidentialityCodes(){
return confidentialityCodes;
The IheXdsBridge.java needs only the following change:
- remove this line
- replace it with this line
xdsDocument.setAuthors(new
PatientInfoType[]{authorToPatientInfoType(documentEntry.getA uthor())});
If you agree, please let me know and I'll create a bug for this. You guys
can check in the changes and that should take care of this bug. The
confidentiality codes and event codes are always blank I think because of
the other bug we talked about, but at least this fix makes the xml sent
over the wire match the WSDL.
thanks,
Jesse
Jesse Pangburn wrote:
> following method:
> over the wire.
> IheXdsBridge.java:
> changed to:
> thanks,
> Jesse
| Re: bridge's document query response not matching wsdl [message #41703 is a reply to message #41672] |
Thu, 20 March 2008 20:30   |
OK, I hope this is my last post on this, sorry I didn't realize there was
going to be a number of these. On the document retrieval (which I don't
understand why a different type is used from document query as they have
the same fields) the same problem exists with document and documents. It
is fixed with the following changes:
RetrieveDocumentResponseType.java
- remove the setDocument method
AbstractXdsBridge.java
- remove the line
response.setDocument(xdsDocument);
- replace it with
response.setDocuments(new XDSDocType[]{xdsDocument});
In this case, now the return type just has an array of documents instead
of a lone document element and an array- but where the message on the wire
just has the array.
While looking at this problem, I noticed that the
RetrieveDocumentRequestType has a request field and a requests field.
This is used in the RetrieveDocumentSet operation and it appears that the
client can use either element that they want to set a single request, or
if you want to get multiple back then you use the plural version. Since
the client is generating this, matching the schema is not a problem but it
seems like it could easily be confusing to people about how they're
supposed to use these. Is there any reason not to remove the "request"
field and just leave "requests"? It's exactly the same thing to put a
list with one element in the "requests" field.
OK, I'm done for the day ;-)
thanks,
Jesse
> Hi all,
> XDSDocType.java:
> - remove this line
> thanks,
> Jesse
>> Hi,
>> following method:
>> over the wire.
>> IheXdsBridge.java:
>> changed to:
>> thanks,
>> Jesse
| Re: bridge's document query response not matching wsdl [message #41734 is a reply to message #41703] |
Mon, 24 March 2008 16:56   |
Hi Jesse,
Sorry for the delay, was out of the country last week.
Thanks for the work and heads up. I agree with all the changes and will
commit them soon. Please submit a bug with at least a generic
description of the changes "for the record".
Thanks again,
-Matt
> was going to be a number of these. On the document retrieval (which I
> don't understand why a different type is used from document query as
> they have the same fields) the same problem exists with document and
> documents. It is fixed with the following changes:
> - remove the line
> - replace it with
> wire just has the array.
> the client can use either element that they want to set a single
> request, or if you want to get multiple back then you use the plural
> version. Since the client is generating this, matching the schema is
> not a problem but it seems like it could easily be confusing to people
> about how they're supposed to use these. Is there any reason not to
> remove the "request" field and just leave "requests"? It's exactly the
> same thing to put a list with one element in the "requests" field.
> thanks,
> Jesse
>> Hi all,
>> codes (with an 's'). These two problems are fixed with the following
>> changes to XDSDocType.java:
>> - remove this line
>> guys can check in the changes and that should take care of this bug.
>> The confidentiality codes and event codes are always blank I think
>> because of the other bug we talked about, but at least this fix makes
>> the xml sent over the wire match the WSDL.
>> thanks,
>> Jesse
>>> Hi,
>>> the registry, the WSDL says that each document will have both an
>>> "author" and an "authors" element. However, there is no author
>>> element returned.
>>> the following method:
>>> simply a convenience method to avoid calling setAuthors instead.
>>> However, Axis sees this setter method as indicating there should be a
>>> field called "author" passed so it puts that in the WSDL. When Axis
>>> is marshalling the java objects into XML though, there is no getter
>>> method so no author element is created- leaving the mismatch between
>>> the WSDL and what's sent over the wire.
>>> the IheXdsBridge.java:
>>> changed to:
>>> lines for clarity. Do you guys agree, and if so, should I submit a bug?
>>> thanks,
>>> Jesse
| Re: bridge's document query response not matching wsdl [message #41797 is a reply to message #41734] |
Mon, 24 March 2008 17:23  |
Hi Matt,
No problem, hopefully you had a fun trip! I submitted a bug with a
condensed version of the problems and the solutions that I used. You can
find it here:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=223731
Of course I'm glad to help and be able to give a little back :-)
thanks,
Jesse
Matthew Davis wrote:
> Hi Jesse,
> Thanks again,
> -Matt
>> - remove the line
>> - replace it with
>> thanks,
>> Jesse
>>> Hi all,
>>> - remove this line
>>> thanks,
>>> Jesse
>>>> Hi,
>>>> element returned.
>>>> changed to:
>>>> thanks,
>>>> Jesse
| Re: bridge's document query response not matching wsdl [message #584993 is a reply to message #41623] |
Hi all,
XDSDocType.java:
- remove this line
thanks,
Jesse
> following method:
> over the wire.
> IheXdsBridge.java:
> changed to:
> thanks,
> Jesse
| Re: bridge's document query response not matching wsdl [message #585008 is a reply to message #41672] |
- remove the line
- replace it with
just has the array.
thanks,
Jesse
> Hi all,
> XDSDocType.java:
> - remove this line
> thanks,
> Jesse
>> Hi,
>> following method:
>> over the wire.
>> IheXdsBridge.java:
>> changed to:
>> thanks,
>> Jesse
| Re: bridge's document query response not matching wsdl [message #585017 is a reply to message #41703] |
Hi Jesse,
Thanks again,
-Matt
> - remove the line
> - replace it with
> thanks,
> Jesse
>> Hi all,
>> - remove this line
>> thanks,
>> Jesse
>>> Hi,
>>> element returned.
>>> changed to:
>>> thanks,
>>> Jesse
| Re: bridge's document query response not matching wsdl [message #585041 is a reply to message #41734] |
Hi Matt,
find it here:
thanks,
Jesse
> Hi Jesse,
> Thanks again,
> -Matt
>> - remove the line
>> - replace it with
>> thanks,
>> Jesse
>>> Hi all,
>>> - remove this line
>>> thanks,
>>> Jesse
>>>> Hi,
>>>> element returned.
>>>> changed to:
>>>> thanks,
>>>> Jesse
Current Time: Tue Nov 04 18:22:15 EST 2025
Powered by FUDForum. Page generated in 0.14250 seconds
