Home » Archived » OHF » IHE Bridge deserialization error (XDS.a)
IHE Bridge deserialization error (XDS.a) [message #40142] Fri, 11 January 2008 03:27 Go to next message
Hello all,
Today I've been looking for a public XDS registry which has pdf-embedded
documents to see if my doc consumer works, and tried IBM registry
( http://lswin10.dfw.ibm.com:9081/IBMXDSRegistry/XDSa/Registry) but the
latest IHE Bridge
(org.eclipse.ohf.bridge.install_0.3.0.v20080108120654.zip) failed to
deserialize the message returned from the server. The query was
<query:AdhocQueryRequest
xmlns:query="urn:oasis:names:tc:ebxml-regrep:query:xsd:2.1" ><query:ResponseOption
returnComposedObjects="true" returnType="LeafClass"
/><query:SQLQuery>SELECT doc.id FROM ExtrinsicObject doc,
ExternalIdentifier patId WHERE doc.objectType =
'urn:uuid:7edca82f-054d-47f2-a032-9b2a5b5186c1' AND (patId.registryObject
= doc.id AND patId.identificationScheme =
'urn:uuid:58a6f841-87b3-4a3e-92fd-a8ffeff98427' AND patId.value =
'139158^^^&amp;10.1&amp;ISO') AND (doc.status IN ('Approved',
'Deprecated')) </query:SQLQuery></query:AdhocQueryRequest>
and here's the stack trace excerpt.
index=0,
size=0/norg.eclipse.emf.common.util.BasicEList$BasicIndexOut OfBoundsException:
index=0, size=0
at org.eclipse.emf.common.util.BasicEList.get(BasicEList.java:5 35)
at
org.eclipse.ohf.bridge.ihe.IheXdsBridge.sourcePatientInfoToP atientInfoType(IheXdsBridge.java:520)
at
org.eclipse.ohf.bridge.ihe.IheXdsBridge.createXdsDocument(Ih eXdsBridge.java:547)
at
org.eclipse.ohf.bridge.ihe.IheXdsBridge.goQueryDocuments(Ihe XdsBridge.java:480)
at
org.eclipse.ohf.bridge.xds.AbstractXdsBridge.queryDocuments( AbstractXdsBridge.java:124)
at
org.eclipse.ohf.bridge.ws.OHFBridge.QueryDocumentsFind(OHFBr idge.java:154)
At first glance it looks some elements Bridge requires are not contained
in the returned query result, which seems to have a couple of documents.
Is it a bridge bug, or is the query result invalid?
Takeo
Re: IHE Bridge deserialization error (XDS.a) [message #40199 is a reply to message #40142] Fri, 11 January 2008 13:43 Go to previous messageGo to next message
Hi Takeo,
This is a bug in the Bridge and will be fixed in the next build.
-Matt
Takeo Satomi wrote:
> Hello all,
> latest IHE Bridge
> (patId.registryObject = doc.id AND patId.identificationScheme =
> index=0,
> index=0, size=0
> at
> at
> at
> at
> at
> Takeo
Re: IHE Bridge deserialization error (XDS.a) [message #40493 is a reply to message #40199] Thu, 24 January 2008 03:49 Go to previous messageGo to next message
Hello Matt,
Thanks to your fix, I could successfully retrieve documents a couple of
days ago, but today I got different errors. When I made non-stored SQL
query for pid=139158 and aaid=1.3.6.1.4.1.21367.2005.3.7 the following
error returned.
ull/njava.util.NoSuchElementException
at java.util.StringTokenizer.nextToken(Unknown Source)
at
org.eclipse.ohf.ihe.xds.metadata.extract.EbXML_2_1DocumentEn tryExtractor.extractExtrinsicObjectSlots(EbXML_2_1DocumentEn tryExtractor.java:486)
at
org.eclipse.ohf.ihe.xds.metadata.extract.EbXML_2_1DocumentEn tryExtractor.extract(EbXML_2_1DocumentEntryExtractor.java:20 8)
at
org.eclipse.ohf.ihe.xds.consumer.AbstractConsumer.processEbX ML_2_1QueryResults(AbstractConsumer.java:400)
at org.eclipse.ohf.ihe.xds.consumer.Consumer.query(Consumer.jav a:142)
at
org.eclipse.ohf.bridge.ihe.IheXdsBridge.goQueryDocuments(Ihe XdsBridge.java:424)
at
at
And with the stored query, I got the error below.
Java heap space/njava.lang.OutOfMemoryError: Java heap space
at java.lang.AbstractStringBuilder.expandCapacity(Unknown Source)
at java.lang.AbstractStringBuilder.append(Unknown Source)
at java.lang.StringBuffer.append(Unknown Source)
at
org.apache.log4j.helpers.PatternParser$LiteralPatternConvert er.format(PatternParser.java:412)
at org.apache.log4j.PatternLayout.format(PatternLayout.java:495 )
at org.apache.log4j.WriterAppender.subAppend(WriterAppender.jav a:293)
at
org.apache.log4j.RollingFileAppender.subAppend(RollingFileAp pender.java:249)
at org.apache.log4j.WriterAppender.append(WriterAppender.java:1 50)
at org.apache.log4j.AppenderSkeleton.doAppend(AppenderSkeleton. java:221)
at
org.apache.log4j.helpers.AppenderAttachableImpl.appendLoopOn Appenders(AppenderAttachableImpl.java:57)
at org.apache.log4j.Category.callAppenders(Category.java:187)
at org.apache.log4j.Category.forcedLog(Category.java:372)
at org.apache.log4j.Category.debug(Category.java:241)
at
org.eclipse.ohf.ihe.xds.soap.AbstractXDSSoapClient.send(Abst ractXDSSoapClient.java:184)
at
org.eclipse.ohf.ihe.xds.soap.AbstractXDSSoapClient.send(Abst ractXDSSoapClient.java:104)
at org.eclipse.ohf.ihe.xds.consumer.Consumer.sendQuery(Consumer .java:533)
at
org.eclipse.ohf.ihe.xds.consumer.Consumer.invokeStoredQuery( Consumer.java:314)
at
org.eclipse.ohf.bridge.ihe.IheXdsBridge.goQueryDocuments(Ihe XdsBridge.java:410)
at
at
As for the latter it looks modifying log4j configuration would fix the
problem as suggested in
https://bugs.eclipse.org/bugs/show_bug.cgi?id=211941 - wouldn't it?
I wish it can be fixed easily or is not a showstopper.
Takeo
Matthew Davis wrote:
> Hi Takeo,
> -Matt
> Takeo Satomi wrote:
>> Hello all,
>> latest IHE Bridge
>> index=0,
>> index=0, size=0
>> at
>> at
>> at
>> at
>> at
>> Thanks,
>> Takeo
Re: IHE Bridge deserialization error (XDS.a) [message #40529 is a reply to message #40493] Thu, 24 January 2008 16:10 Go to previous message
Hi Takeo,
The logger issue - I think the only way you'll be able to resolve that
is to decrease the sensitivity in the log4j.xml configuration file.
We'll take a look at the ebXML 2.1 issue and get back to you on that.
-Matt
Takeo Satomi wrote:
> Hello Matt,
> error returned.
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> Takeo
>> Hi Takeo,
>> Thanks,
>> -Matt
>> Takeo Satomi wrote:
>>> Hello all,
>>> pdf-embedded documents to see if my doc consumer works, and tried IBM
>>> registry
>>> the latest IHE Bridge
>>> index=0,
>>> index=0, size=0
>>> at
>>> at
>>> at
>>> at
>>> at
>>> contained in the returned query result, which seems to have a couple
>>> of documents.
>>> Thanks,
>>> Takeo
Re: IHE Bridge deserialization error (XDS.a) [message #584356 is a reply to message #40142] Fri, 11 January 2008 13:43 Go to previous message
Hi Takeo,
-Matt
Takeo Satomi wrote:
> Hello all,
> latest IHE Bridge
> index=0,
> index=0, size=0
> at
> at
> at
> at
> at
> Takeo
Re: IHE Bridge deserialization error (XDS.a) [message #584484 is a reply to message #40199] Thu, 24 January 2008 03:49 Go to previous message
Hello Matt,
error returned.
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
Takeo
> Hi Takeo,
> -Matt
> Takeo Satomi wrote:
>> Hello all,
>> latest IHE Bridge
>> index=0,
>> index=0, size=0
>> at
>> at
>> at
>> at
>> at
>> Thanks,
>> Takeo
Re: IHE Bridge deserialization error (XDS.a) [message #584498 is a reply to message #40493] Thu, 24 January 2008 16:10 Go to previous message
Hi Takeo,
-Matt
Takeo Satomi wrote:
> Hello Matt,
> error returned.
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> Takeo
>> Hi Takeo,
>> Thanks,
>> -Matt
>> Takeo Satomi wrote:
>>> Hello all,
>>> registry
>>> index=0,
>>> index=0, size=0
>>> at
>>> at
>>> at
>>> at
>>> at
>>> of documents.
>>> Thanks,
>>> Takeo
Previous Topic:PDQ limit
Next Topic:OHF Support at Connectathon - Please Read
Current Time: Thu Jul 24 22:11:08 EDT 2025
Powered by FUDForum. Page generated in 0.27661 seconds
