check an attribute [message #37377] |
Wed, 19 September 2007 11:32  |
Originally posted by: briandwilliam.hotmail.com
hi,
I will like to initialize a label with the string ' emmetteur' or '
receveur' by testing the value of an attribute.
Class : Port Attribute : Direction .
If Direction = ' IN' the label takes the value ' receveur'
If Direction = ' OUT' the label takes the value ' emmetteur'
thank you
Re: check an attribute [message #37479 is a reply to message #37445] |
Thu, 20 September 2007 10:56   |
Hi, Briand,
I see. "Direction" is an enumeration type, so you need to reference its
literal values by name:
if
self.redefinitionAccrochePort.contenu.redefinitionDescripteu rDeReferencePortSyn.redefinitionRefDescSyn.direction=Directi on::IN
then
self.role='receveur'
else
self.role='emetteur'
endif
HTH,
Christian
briand wrote:
> hi,
> here a little more explanations ! to see the drawing
> The ExtremiteConnRepresentation class represents a connection between
> nodes (diagram gmf) and ExtremiteConnexion.role is a label.
> when I create my connection, I want to initialize my
> ExtremiteConnexion.role with 'emetteur' or ' receveur' according to
> InterfaceSimple.direction ! if direction='IN' then role='receveur' else
> role='emetteur' I try this :
> context ExtremiteConnRepresentation
> if
> Syn.redefinitionRefDescSyn.direction='IN' then self.role='receveur' else
> self.role='emetteur' endif
> and I had this error message :
> Invalid expression body 'if
> self.role='emetteur' endif'. Cause: Invalid expression body 'if
> self.role='emetteur' endif'. Cause: ERROR in (operationCallExpCS): (Cannot
> find operation (=(String)) for the type (Sequence(Direction)))
> thank you very much !!!
> "Christian W. Damus" <cdamus@ca.ibm.com> a �rit dans le message de
> news:fcrism$bc$1@build.eclipse.org...
>> Hi, Briand,
>> Sorry, what is your question?
>> You want to do something with a label, but I don't know what a label is
>> or
>> how OCL is supposed to fit into this picture. Are you looking to do
>> something like:
>> context Port::label : String
>> init: if self.Direction = ' IN' then ' receveur' else ' emmetter'
>> endif
>> assuming that the Direction may only have one of these two values.
> However,
>> this sounds like a case where a derived attribute is more useful:
>> derive: if self.Direction = ' IN' then ' receveur' else ' emmetter'
> endif
>> Cheers,
>> Christian
>> briand wrote:
>> > hi,
>> > thank you
Re: check an attribute [message #37940 is a reply to message #37632] |
Mon, 24 September 2007 10:03  |
Hi, Briand,
If you are having trouble with specifying connections in your UML model, you
might rather try asking about that in the UML newsgroup
(eclipse.modeling.mdt.uml2). If it is a problem of the UML2 Tools diagram
editor not creating your connections correctly, then you should ask about
it in that newsgroup (eclipse.modeling.mdt.uml2tools).
Otherwise, the MDT OCL component doesn't offer any debugging support beyond
what JDT provides. Debugging aids are in the scope of the OCL Tools
component, but the only such aid available there (perhaps soon) is Miguel's
AST View.
Christian
briand wrote:
> thank you the constraint is now valid ! I start to understand the
> mechanism of ocl ...
> this constraint is defined on a connection (ExtremiteConnRepresentation),
> my connection does not appear on the diagram !
> however it appears in the model !!! and the role property is not defined
> I manage to go up the ascent of associations ! so it would seem that all
> is correct !?
> how can I solve the problem ??? with the debbugger ? while checking
> point-to-point ?
> thanks
> news:fcup7m$lvs$1@build.eclipse.org...
>> Hi, Briand,
>> Right. The problem is, that (evidently) the following expression results
> in
>> a collection of Direction values:
>> because at least one of the following properties has multiplicity many
>> (is collection-valued):
>> - redefinitionAccrochePort
>> - contenu
>> - redefinitionDescripteurDeReferencePortSyn
>> - redefinitionRefDescSyn
>> Apply the "." operator to navigate the property of a collection value
>> implicitly iterates the collection using the "collect" iterator, so that
>> the result is another collection.
>> You will need to do either:
> Syn.redefinitionRefDescSyn.direction->forAll(d
>> | d = Direction::IN)
>> to assert that all directions are "in" or, if you expect that there will
>> only be one direction in the collection value:
> Syn.redefinitionRefDescSyn.direction->first()
>> = Direction::IN
>> HTH,
>> Christian
>> briand wrote:
>> > thank you for your assistance but it always has an error !
>> > error :
>> > Syn.redefinitionRefDescSyn.direction=Direction::IN then
>> > self.role='receveur' else self.role='emetteur' endif
>> > '. Cause: ERROR in (operationCallExpCS): (Cannot find operation
>> > (=(Direction)) for the type (Sequence(Direction)))
>> ------8<------
FUDForum. Page generated in 0.05978 seconds
