Home » Eclipse Projects » Eclipse Platform » Mixing Platform Command and Action Set frameworks
Mixing Platform Command and Action Set frameworks [message #333571] Wed, 17 December 2008 09:31 Go to next message
In short: is it possible for a Menu Contribution to specify a menu
identifier from an ActionSet?
We are looking at whether or not it is possible to feather in the command
framework approach (which we like quite a bit!), or if we will need to just
perform a complete replacement of all of our existing ActionSet based
platform contributions (a somewhat lengthy effort that we'd like to defer,
if possible).
Thanks for any feedback/pointers on this,
-Pete
Re: Mixing Platform Command and Action Set frameworks [message #333573 is a reply to message #333571] Wed, 17 December 2008 09:48 Go to previous messageGo to next message
> if possible).
> -Pete
My experience is that you can mix them. But you cannot contribute
declarative made menues by the old actions. That is the only pitfall I
know about.
Adam
Re: Mixing Platform Command and Action Set frameworks [message #333576 is a reply to message #333571] Wed, 17 December 2008 14:12 Go to previous messageGo to next message
As mentioned, they can co-exist. For something like the main menu bar,
first the programmatic items are added (like WorkbenchActionBuilder)
then the org.eclipse.ui.menus contributions. Then finally, any
org.eclipse.ui.actionSets are processed. Action sets cannot see menus
defined in each other, but then can see menus defined in
org.eclipse.ui.menus.
PW
Paul Webster
http://help.eclipse.org/ganymede/index.jsp?topic=/org.eclips e.platform.doc.isv/guide/workbench.htm
Re: Mixing Platform Command and Action Set frameworks [message #333614 is a reply to message #333576] Thu, 18 December 2008 09:09 Go to previous messageGo to next message
Adam and Paul - thank you for the feedback.
> first the programmatic items are added (like WorkbenchActionBuilder) then
Based on this order, it may make sense why I have not been successful thus
far... I am trying to add a org.eclipse.ui.menus contribution to a menu
defined in an existing action set. However, if the action set is not
evaluated until after ui.menus, than ui.menus will come up empty when
looking up an action set menu identifier. Perhaps I'm missing something
here. When I attempt something simple such as:
<extension point="org.eclipse.ui.actionsSets">
<actionSet
id="actionSet1"
visible="true"
<menu
id="menu1" label="TestMenu">
<groupMarker name="group1"/> </menu>
... actions ...
</actionSet> </extension>
<extension point="org.eclipse.ui.menus">
<menuContribution
locationURI="menu:menu1?after=group1">
<command
commandId="aCommandId"> </command>
</menuContribution> </extension>
the menu contribution for "aCommandId" does not appear in the menu specified
in action set "actionSet1".
Am I omitting a step here? Should I expect this to work/not work?
Thanks, -Pete
Re: Mixing Platform Command and Action Set frameworks [message #333620 is a reply to message #333614] Thu, 18 December 2008 10:32 Go to previous messageGo to next message
Right, you cannot do this. actionSet menus are "local" to that action
set, nothing else can see them.
You can add your menu definition to your menu contribution as well, then
it would be visible to action sets and menu contributions.
And example is:
<menuContribution
<!-- this places the menu, you can fool with the location-->
locationURI="menu:org.eclipse.ui.main.menu?after=additions" >
<menu id="my.menu1" label="TestMenu">
<separator visible="false" name="group1"/>
</menu>
</menuContribution>
You can even roll up your command menu contribution and simply place it
in the structure. You also need to make sure that your IDs match
(my.menu1) in the menu contributions and action sets.
PW
Paul Webster
Re: Mixing Platform Command and Action Set frameworks [message #333628 is a reply to message #333620] Thu, 18 December 2008 12:13 Go to previous message
Great! This aproach works well, and will allow us to gradually add support
for the command framework without disrupting our entire existing ActionSet
implementation.
Many thanks, Paul! -Pete
Previous Topic:Inconsistent behaviour in TextEditor
Next Topic:p2: problem with permissions.properties on linux
Current Time: Wed Sep 03 16:25:52 EDT 2025
Powered by FUDForum. Page generated in 0.04644 seconds
