Home » Eclipse Projects » Eclipse Platform » Add a cascade menu to a contex menu item
Add a cascade menu to a contex menu item [message #325680] Mon, 25 February 2008 11:54 Go to next message
does somebody know, how can i add a cascade menu to a contex menu item?
Greetings
Re: Add a cascade menu to a contex menu item [message #325684 is a reply to message #325680] Mon, 25 February 2008 11:59 Go to previous messageGo to next message
--------------010801010705000906040506
J
Re: Add a cascade menu to a contex menu item [message #325686 is a reply to message #325684] Mon, 25 February 2008 12:01 Go to previous messageGo to next message
Ah sorry for the bad description. No i meant to a context menu in a
jface tableviewer.
Ed Merks schrieb:
> Jörg,
> You mean declaratively in the plugin.xml?
> <extension point="org.eclipse.ui.popupMenus">
> <objectContribution id="org.eclipse.emf.ecore.editor.Open"
> objectClass="org.eclipse.core.resources.IFile">
> <visibility>
> <systemProperty name="org.eclipse.emf.ecore.editor.Open"
> value="true"/>
> </visibility>
> <menu id="org.eclipse.emf.ecore.editor.Open"
> label="%_UI_OpenAs_menu_item" path="org.eclipse.ui.OpenWithSubMenu">
> <separator name="additions" />
> </menu>
> <action
> id="org.eclipse.emf.ecore.editor.OpenXMLReflectiveEditorAction "
> label="%_UI_EMFXML_menu_item"
> menubarPath="org.eclipse.emf.ecore.editor.Open/additions"
> class="org.eclipse.emf.ecore.action.OpenEditorAction" enablesFor="1">
> </action>
> <action
> id="org.eclipse.emf.ecore.editor.OpenReflectiveEditorAction "
> label="%_UI_EMFXMI_menu_item"
> </action>
> </objectContribution>
> <objectContribution
> id="org.eclipse.emf.ecore.editor.CreateDynamicInstance"
> objectClass="org.eclipse.emf.ecore.EClass">
> <action
> id="org.eclipse.emf.ecore.editor.CreateDynamicInstanceAction "
> label="%_UI_CreateDynamicInstance_menu_item" menubarPath="additions"
> class="org.eclipse.emf.ecore.action.CreateDynamicInstanceAction "
> enablesFor="1">
> </action>
> </extension>
> Jörg wrote:
>> Hello,
>> Greetings
Re: Add a cascade menu to a contex menu item [message #325695 is a reply to message #325686] Mon, 25 February 2008 12:41 Go to previous message
--------------050701020104010904070804
J
Previous Topic:problem in deployed plugin
Next Topic:can't start deployed plugin
Current Time: Mon Oct 27 02:57:50 EDT 2025
Powered by FUDForum. Page generated in 0.05429 seconds
