Using JNI with Eclipse+MTJ [message #32116] |
Mon, 13 July 2009 06:23  |
I'm having trouble trying to use JNI with Eclipse and MTJ. My VM
implementation supports JNI so I am trying to create a Midlet that uses
it. I have included the external libraries that implement JNI in the
project build path (but not exported them). Also, in the "Native Library
Location" I give the folder that contains the native libraries (.dll and
h). I am able to compile my project successfully, however I get a
preverification error in the class that declares the native method.
Please, does anyone has some ideas that could help me solve this problem?
Thanks a lot in advance.
María
Re: Using JNI with Eclipse+MTJ [message #574693 is a reply to message #32116] |
Mon, 13 July 2009 07:08  |
Maria,
What SDK are you using that supports JNI?
Craig
Maria Amor wrote:
> Hello,
> Best regards,
> María
Re: Using JNI with Eclipse+MTJ [message #574716 is a reply to message #32151] |
Mon, 13 July 2009 07:31  |
Hello Craig,
Thanks for your quick answer.
Well, I'm using Sun's Wireless Toolkit 2.5.2. I donŽt have any specific
SDK that supports JNI, but my VM does support it (I use IBM's J9).
María
Re: Using JNI with Eclipse+MTJ [message #574886 is a reply to message #32184] |
Wed, 15 July 2009 07:22  |
Given that MIDP doesn't, by default, allow for JNI you aren't going to
be able to use Sun's toolkit for this work. The preverification will fail.
Maria Amor wrote:
> Hello Craig,
> Regards,
> María
Re: Using JNI with Eclipse+MTJ [message #574935 is a reply to message #32459] |
Wed, 15 July 2009 07:30  |
To answer your question via email...
I have no idea what SDK you could use for this testing. It would have
to look like a standard ME SDK for MTJ to be able to use it.
> Maria Amor wrote:
>> Hello Craig,
>> Regards,
>> María
FUDForum. Page generated in 0.08576 seconds
