Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc)  » Equality operation contract in OCL expressions?
Equality operation contract in OCL expressions? [message #30717] Mon, 10 April 2006 15:20 Go to next message
I can see that semantics of the '=' operation has changed in EMFT OCL
1.0.0M6.
The difference is in applying '=' operation when the source or the argument
is 'null' /* OclVoid 'null' instance in OCL2.0 */.
Consider the following expression in the context of ecore::EClass instance
with the 'name' attribute set to 'null' value.
context ecore::EClass inv: 'value' = self.name
Currently, this expression results in OclInvalid while the implementation
prior to M6 returned false.
Actually, I think that according to the older OCL spec it was wrong (but
practical ;-)) as the spec (see A.2.2) is fairly strict about the equality
contract requiring all parts be defined.
However, I'm a bit in doubts about the latest OCL2.0 compliant
implementation.
The latest OCL2.0 spec says that any property call applied on the 'null'
instance of OclVoid results in OclInvalid.
I'm not sure that this is explanatory enough to justify the expression above
evaluated to OclInvalid,
because the '=' operation was performed on a valid String object only taking
the valid 'null' value as an argument.
I believe this should not result in OclInvalid, AFAIU, the concept of
'absent value' based on OclVoid was
introduced to enable passing 'null' values to collection operations as
collections now can contain 'null' values.
Is not this analogical situation?
Moreover, when looking at some pre:, post: conditions for several
operations defined in the latest OCL2.0 spec, it looks like
the equality operation on 'null' values should allways result in a boolean
value.
For instance,
Sequence::append (object: T) : Sequence(T)
post: result->size() = self->size() + 1
post: result->at(result->size() ) = object
post: Sequence{1..self->size() }->forAll(index : Integer |
result->at(index) = self ->at(index))
In my opinion, the second post condition could never hold true in case the
'null' value is added and we are not able to produce boolean value from
'null = null'.
Perhaps, I have missed something in the specification and this case is
correct.
If it is this way, I find it quite impractical when writing expressions
which must check for 'null' values explicitly. ;-(
/Radek
Re: Equality operation contract in OCL expressions? [message #30786 is a reply to message #30717] Mon, 10 April 2006 18:27 Go to previous messageGo to next message
Hi, Radek,
The Invalid and OclVoid types both define "=" and "<>" operations, so these
should never return OclInvalid.
I am also a little perplexed as to why 'value' = self.name should have
apparently turned the evaluation around to produce OclInvalid.
This is definitely a bug in the implementation. Care to raise a bugzilla
(sounds like a serious problem)?
Christian
Radek Dvorak wrote:
> 1.0.0M6.
> argument is 'null' /* OclVoid 'null' instance in OCL2.0 */.
> implementation.
> above evaluated to OclInvalid,
> taking the valid 'null' value as an argument.
> value.
> For instance,
> 'null = null'.
> correct.
> Regards,
> /Radek
Re: Equality operation contract in OCL expressions? [message #30856 is a reply to message #30786] Tue, 11 April 2006 04:16 Go to previous message
Raised request https://bugs.eclipse.org/bugs/show_bug.cgi?id=136068
"Christian W. Damus" <cdamus@ca.ibm.com> wrote in message
news:e1em42$q5p$1@utils.eclipse.org...
> Hi, Radek,
> these
> Christian
> Radek Dvorak wrote:
>> Hi,
>> 1.0.0M6.
>> instance
>> equality
>> implementation.
>> boolean
>> value.
>> For instance,
>> the
>> 'null = null'.
>> correct.
>> Regards,
>> /Radek
Re: Equality operation contract in OCL expressions? [message #574065 is a reply to message #30717] Mon, 10 April 2006 18:27 Go to previous message
Hi, Radek,
Christian
Radek Dvorak wrote:
> 1.0.0M6.
> implementation.
> value.
> For instance,
> 'null = null'.
> correct.
> Regards,
> /Radek
Re: Equality operation contract in OCL expressions? [message #574127 is a reply to message #30786] Tue, 11 April 2006 04:16 Go to previous message
> Hi, Radek,
> these
> Christian
> Radek Dvorak wrote:
>> Hi,
>> 1.0.0M6.
>> instance
>> equality
>> implementation.
>> boolean
>> value.
>> For instance,
>> the
>> 'null = null'.
>> correct.
>> Regards,
>> /Radek
Previous Topic:API Changes in EMFT OCL This Week
Next Topic:migrating CDO data from old to new schema
Current Time: Thu Jul 24 22:45:10 EDT 2025
Powered by FUDForum. Page generated in 0.07551 seconds
