Home » Eclipse Projects » Plugin Development Environment (PDE) » Installed plugin application is unable to display icons and images
Installed plugin application is unable to display icons and images [message #30243] Thu, 30 October 2008 05:22 Go to next message
Originally posted by: prashanto.chatterjee.gmail.com
I have created an update site for my features. I install the feature using
Eclipse' update manager. I initially faced problems with plugins containing
jars that are themselves bundled as a jar. I used the unpack="true" option
in feature.xml to resolve this issue. This is not well documented and I am
not sure which is the right way to go about this. However, that is a
completely different discussion thread.
When I install the feature and restart the workbench, I am unable to see any
icons associated with editors, views, perspective etc. In addition I do not
see any images that I use in my label providers. I have all my images and
icons inside the Java source folder 'src' under an 'images' subdirectory.
Appreciate your help,
Prashanto Chatterjee
Re: Installed plugin application is unable to display icons and images [message #30279 is a reply to message #30243] Thu, 30 October 2008 08:03 Go to previous message
I guess I did answer my own question - moved all icons outside src directory
to an icons directory. Actually the src directory ceases to exist in the
deployed plugins.
"Prashanto Chatterjee" <prashanto.chatterjee@gmail.com> wrote in message
news:gebucr$r2t$1@build.eclipse.org...
> containing jars that are themselves bundled as a jar. I used the
> unpack="true" option in feature.xml to resolve this issue. This is not
> well documented and I am not sure which is the right way to go about this.
> However, that is a completely different discussion thread.
> any icons associated with editors, views, perspective etc. In addition I
> do not see any images that I use in my label providers. I have all my
> images and icons inside the Java source folder 'src' under an 'images'
> subdirectory.
Re: Installed plugin application is unable to display icons and images [message #583868 is a reply to message #30243] Thu, 30 October 2008 08:03 Go to previous message
deployed plugins.
> subdirectory.
Previous Topic:Installed plugin application is unable to display icons and images
Next Topic:How to use the HyperlinkManager
Current Time: Fri Sep 05 23:04:05 EDT 2025
Powered by FUDForum. Page generated in 0.03398 seconds
